wiilydog
Everything posted by wiilydog
  1. Aircon issue could be the compressor or a hole in the condenser, usual common failure with age and not usually worth repairing unless you plan to keep the car for a while.
  2. Airbag connectors can be easily swapped over if you are handy with a soldering iron.
  3. The Skoda will have a rear beam Vs independent suspension on the golf mk6, so will be inferior to the mk6 even with sound proofing.
  4. Agree with MicMac L&K seats are not that comfortable and same as normal Octavia ones apart from the leather and the electric adjustment. I would go for Audi front seats as the quality of the materials will be better than VW golf. Ive tried Audi A3 and Vw Eos front seats and both are superior to the stock Skoda ones.
  5. 24-229920 will be the correct b8 one for solid rear suspension, go to the original bilstein site to get the right ones for your car. http://web1.carparts-cat.com/default.aspx?34=0,100011,100121&240=0&32=58767&230=29&1271=48&1272=772250fa-c189-4129-b61c-f0ff58ace9f0&1273=1&10=FFFC0AA82165484DAAFE0CA91C6E95EA018001&14=1&12=130
  6. I would trying taking off the plastic pipe which the MAF goes into as there should be part number there as some of the Bosch replacement ones come pre-installed, so you replace the complete pipe rather than just the insert.
  7. As above it makes no sense not to put a new dmf and clutch in while the gearbox is out especially if it is still the original at 145k as you will save on future labour costs
  8. I would go for 5w40 VW spec 505.01 for annual changes as it's cheaper and offers better protection as oil was design for PD engines without DPF.
  9. go for varta E44 096 battery as they are top notch and made by same company that makes them for Bosch https://www.tayna.co.uk/car-batteries/varta/e44/
  10. No coding required unless you are getting a new key fob as the immobilizer chip is in the fob and communicates with the ECU. I ended up changing the lock mechanism but reusing the key barrel. If you are use a key barrel from another car you can swop the key blade over to your old key fob so the immobilizer and remote locking still works. I think you can also order key barrels to match your existing key from Skoda.
  11. The intercooler hose might be worn out as there are aluminium tabs that keeps the hose in place, once these are worn the hose will need to be replaced to stop them popping out under boost.
  12. The previous owner might of just cut the sensor wire and coded them out. Have a look at front nearside to see if there is any sensor lead left unplugged.
  13. go for 2.0PD 140 (not 4x4) as these does not have a DPF also oil pump issues did not affect Octavia as only affect longitude mounted engines such as those on the passat or skoda superb
  14. Try eBay https://www.ebay.co.uk/itm/124569628534 https://www.ebay.co.uk/itm/254595630544
  15. the tabs will face inwards towards the car so will not be a problem
  16. No, should fit either side
  17. wiilydog replied to yeti2012's topic in Skoda Yeti
    I would replace the fuel filter and drain the fuel from the fuel filter housing and replace it with some new stuff as fuel does go off with age.
  18. Also try with someone inside pressing on the brake pedal together with the breaker bar
  19. You just need someone with vcds to activate Scandinavian DRL mode for you
  20. It is worth checking if the rear track control wishbone arms bushes are not worn as if worn will cause the rear end to feel loose. These are the parts I'm referring to https://www.ebay.co.uk/itm/333755851447
  21. that's fine as I thought you meant putting extra grease on the bolt as there will be always some grease in the cv joint where the bolt goes through
  22. it will be dry as it is not common practice to put grease on your hub bolts - just remember always use new bolts as they are stretch bolts and are one time use only
  23. Might just need a quick drive to clear the lights as when you disconnect the battery the dash will light up like a Christmas tree until you go for short drive.
  24. If it hasn't had its dsg oil changed at 160k then it needs doing as it needs changing every 40k
