Chazzy
Everything posted by Chazzy
  1. Not been in here for a while... hit the magjc number last month. This is a 2016 CJXA 280. Just been to la rochelle in france and back, averaged 36 on the Autoroutes, cruise set to 132km/h. 4 up and lots of luggage. It used about half a litre of oil on the way down. It seems to use about a litre between services so around 6000 miles of town tootling and odd m-way trips as the uni- home taxi service. So 10 years nealry and 100k miles and still on original dsg shocks and springs, but getting slight rattles from the front on the awful roads we have so thinking about what bits might need replacing soon. Assuming the big lower wishbone with the big bushing, any other likely bits to do while we're in there? (All standard spec)
  2. Thanks, Very possible. Managed to avoid the open windows mystery although the open bootlid poltergeist was common when I first got the car. Maybe trouser fashion has chnaged over the last 8 years-or too many pies! Just praying it's not some module sowmwhere playing up.
  3. More for future searchers than current answers. Non Kessy. One key fib stopped working one morning. Transponder part still ok, started car no problems. New battery, no joy. Tried other fob, worked fine. Swapped batteries still worked fine. Diagnosis = dead remote part fo the key fob. 10 years old- fair enough. Found a local locksmith who was cheaper than desler but ended up not changing the fob as he was ill/ unreliable. 2 weeks later.(tonight) leave work. Unlock OK, get to the shop for emergency rations and no locking. Aaggghh. At home still no action at all so popped the door handle lock cover to manually lock car. And after a couple of cycles the fob is then working OK again. Went to get "broken" fob, used it to manually lock unlock arm and disarm alarm and it too now works properly from it's buttons So, I have a short term fix, but why is the car forgetting that the fob should unlock it.?
  4. Id echo everything said so far. Some common issues, water pump, DSG selector and creaking bushes, but for the price,/ space/ size its great. It can waft or be silly. And with the 4x4 that gap on the roundabout can be yours in all weathers. It is big and even indy servicing adds up (but same on all cars with the bits) it's not a sports car, and likes a drink around town. 8 mile commute in Birmingham is between 24 and 28 mpg. Depends on how many times I have to stop. On an A road drive high 30's , French motorways loaded up low 30's. But at 16 miles a day I'm not bothered.
  5. But a phase inverted signal looks the same as the original signal after a delay of half a cycle. Ie its the timing of the signal that matters otherwise you could end up with twice the noise. (If the signals are in phase) Lotus played with active noise cancelling back in the late 80's for the road cars. Never made it to production.
  6. Worked a dream on 2016 model using OBDeleven. 15 changed to 14, reset and have traffic alerts.
  7. Got a petrol blue 2016 model here too. a real change from the sea of greys.
  8. a real range here. and reassuring to see some high miles. around 80k for me on a 2016 280. bought at 2 yrs old with 40k, so I've reduced the yearly down to average ish.
  9. 2016 280, water pump/ thermostat here too, gear stick dont leave in P in park or similar due to faulty microswitch.m, also a relativley common failure. but its a great Q car, you WILL get up to speed before joining the motorway and damp weather will not stop you getting that gap on a busy roundabout or uphill away from the lights ( should you feel the need) oh , squeaky anti roll bar bushes are standard.
  10. I did both. 2016 standard 280 with dcc, no errors. It feels better but could be placebo effect.
  11. Can I ask who / where you did it and cost of new module? Do you feel any difference between new normal the old normal with the new parameters? Ie is this worth more than a slider? Regards.
  12. I'm so glad you had a very clean car to post, a bit like having clean underpants incase you get hit by a bus. Also a reminder to wash mine after our snow and ice (and salt and grit) (also a Petrol blue estate) This thread should be tagged 'suspense'. Hope it's not damaged.
  13. Also another tall one here, is the rear of the seat at its lowest, ie on max sloping backwards. I do find the mirror us in my sightlins at junctions, but nothing new.
  14. "No external leaks" as ApertureS says are you sure. Or just no signs on the ground? mine (also 280) was leaking from waterpump/ thermostat housing area, but always evaporated before getting round the engine cover to the driveway. I could see "wet" peering down the front of the engine sometimes though.
  15. I'd possibly add the 'Don't leave gear selector in park' or similar, faulty microswitch, 700 to fix, some goodwill from skids if recently out of warranty. Plus sqeaky/groans from suspension bushes (no damage but sounds awful). Had all but the DCC misting but still love it. Re 4x4, see it as skodas 'quatro' useful in snow but a game changer for spirited acceleration in the wet. Never worry about axle tramp again.
  16. Hi I, can see you are also in Brum, I used midland VW in Norton Caine's recently if you are in the north of the region. fWIW, my air quality sensor also throws an error, but the air con is pushing out cold air even in the heatwave. There's a few air con specialists in Brum as well who may be better at fault finding/ tracing
  17. Mine looks exactly the same. Only noticed after some opportunist took advantage of an unlocked car door overnight. every cubby door open. I assumed he grabbed the visor looking for cash or stuff. Will check the guide mentioned.
  18. Driver seat memory stopped working at some point, OBDEleven scan threw up basic setting missing from all driver seat motors. Ran basic settings routine via OBDEleven and all working again.
  19. @Cocain less for rattles etc but many will have stories of unusual noises. For me and as spacelord mentions it was the overall roadnoise inside the cabin that surprised me. ( And that was after a 57 reg Mondeo)
  20. To add to the horror shows, here's my filter after 5 and half years, 68000 miles and one oil change (dealers at 2 years 47000miles, wouldn't do filter). Picture from indie's computer screen hence a bit weird looking. Midland VW near cannock. Very happy with service. £95 for haldex service and clean filter. (Skoda fixed price is £85 just oil change) For reference, first 2 years it seemed to do 100 miles a day (presumably mway), then I got it and generally drive in town, not fast, but lots of spirited roundabout entries etc that must tax the 4x4 as I avoid the wheel spin in damp of prev cars. (Key reason for getting the 280)
  21. Another car wash. Summer wheels back on, manual polish but got tired so pulled the dual action out to apply wax. Even tyre gelled after the grief I got last time 😉
  22. As above plus DSG oil changes . Check the air vent controls actually move the vanes inside, especially in the rear middle housing. Easily kicked and made of chocolate. Fixable - if you have all the bits, but easier for someone else to sort it.
  23. In the UK the 272 came with the newer 7 speed DSG. The change to the engine from 280 and gearbox were both to meet the newer emissions/ fuel consumption tests. Some other markets Oz? Middle East have different engine / gearbox combinations.
  24. Rear seat heating? Control panel, not sure on the pointy thing though.
  25. Nots Sure about IN the cabin, but for around the fuel filler smell check the rubber surrounding the pipe where is emerges. It can ride up and obstruct the filler cap sealing, but still seems to 'lock' on. First time I had this issue the dealer removed rear seat base to look at the fuel gauge sender seal.
