Everything posted by bigjohn
Brakes
I thought the early 1.9 and all 1.4 versions came with Spectrum 16" alloys as standard
E10 fuels
The mk I 1.4 8v mpi does have a version of the Felicia pushrod engine whereas the 1.416v has the VAG DOHC engine as does the VW fox. One thing I've noticed though is most VW engines that can't have E10 are the fsi engines. This was also fitted to the Octavia up to about 2008 but is not listed as an E10 incompatible engine.
MK2 Octavia 1.8 TSI L&K
One of the big issues with some 1.8 tsi engines was burning oil. Obviously check oil level but I'd be looking for evidence of oil near the exhaust tail pipe - oil yellowing on bumper nearby or oil that shows when you wipe a tissue around the area at the back. Anyway of taking on a long test drive? I have a friend with a 1.8tsi Yeti (same engine I believe ) that has had no trouble
New car TSI rattle
I'd say that sounds normal then.
Retro fit Recaro type front seats?
You can possibly get Recaro subframes but a major complication will be related to seat airbags etc https://www.sportseats4u.co.uk/product/recaro-seats-skoda-superb-direct-fit-sub-frames/ I'm not sure re compatibility with sportier / bolstered seats from Skoda eg Octavia vrs etc
New car TSI rattle
It is normal for the high pressure tsi injection to "tick away" somewhat. On my Superb 1.4tsi I only hear with the bonnet up, I don't hear inside the car with the bonnet down and the doors shut. Does the Karoq petrol still have the under bonnet sound insulation?
Advice Needed Skoda Superb Mk 1
All I know is my previous Superb (2003 pd100) now has over 100k miles more than yours and the turbo is still going strong - It's had a meticulous service regime though and was taken off long life servicing as I bought it at 18 months old
rear led fog light
I think it's the angle I took the photo / daylight - the rear LED sidelights are on when the rear foglight is on:-
Sounds as though you might have a leak in the turbo pipework somewhere - could also potentially explain the MAF error you have. Thoroughly check where it connects too/from intercooler. Don't panic if you see a bit of oil.
Re No 1) I never had the MAF issue in my ownership but I seem to remember it was very easy to get at - can't fully remember but I think it's top left under the bonnet, Replace with new. Re No 2) - front suspension. The Superb I is known for front suspension parts wearing out and not always coming apart, however replacing with the full kit of parts sounds like a plan. On my Superb I during my 10 year ownership in the last few years I seemed to have a joint or two needing replacement every other MOT. Make sure the outer CV boots are also in tip top condition as it's very cheap and easy to replace whilst in bits! Likewise with steering rack bellows/boots. Re No 3) - A colleague who bought my previous 2003 Superb had this issue - in the end it turned out to be the tandem vacuum pump failing. It's been ok since replacement. The tandem pump (tandem as it's a vacuum and diesel pump) is a known weak spot with the 1.9pd. PS it's at the top back of the engine near the bulkhead. Check the pipe between the servo and tandem pimp - which has a "T" off in the middle to feed the pd vacuum controls.
rear led fog light
Just checked on mine(also an led facelift twin door) and the fog light is on the right cluster - could this be the usual twindoor wiring fail? I suppose you'd expect a bulb fail warning but not sure if the led fog light is covered by that?
1.4tsi coolant leak
You need to take it back to the supplying dealer - the law is on your side :- https://www.theaa.com/car-buying/legal-rights
Is the Rapid now Scala ?
In the UK the Rapid is no more but the Scala replacement is very similar re body design to the previous Rapid Spaceback although the interior has been updated. The Rapid Hatchback lives on in some countries such as Russia - and many things such as the interior look very much like the Scala. Looks pretty good actually!
Handbrake advice
Usually the only way is to pull the handbrake on a bit harder. The new pads still might need a bit more bedding in as well it can take a few thousand miles especially when fitting to old disks. Also new pads may or may not have a taper on the friction material to help this bedding in process - this can mean slightly less friction material in contact for a while. Must have been a really steep hill! What engine does it have out of interest?
Handbrake advice
As part of replacing the rear pads you will have wound back the caliper hydraulic piston with a special tool - this mechanism is the self adjustment. Usually if you have to adjust handbrake cables then something isn't quite right. This has been the case with almost every brake system for decades with various adjustment mechanisms - some better that others! I remember the one on the mkII Cortina, hopeless. The ones on VAG cars usually ok but handbrake lever can seize somewhat if neglected. As mentioned further up the thread the condition of all the brake components is really important. Are the calipers free to slide and what condition are the discs? If caliper sliders are stiff then handbrake may be only acting on one pad - which when it does slide may release somewhat If disks are corroded/scored/worn then it's less than ideal and new pads will take 1000's of miles to bed in As it's a major safety component I'd suggest a qualified mechanic checks it over. With rear disks don't forget as it cools and contracts the action of the handbrake will reduce (with drum brakes it's the opposite)
High Mileage Superbs
Hi, I realised that. I only mentioned re the life of your MKII , however I think your engine should be robust although if a manual keep an eye on the clutch. There have been some issues with the Sachs pressure plate falling apart and damaging the gearbox casing. I loved my previous mkI even though it was only the 100ps 1.9pd. It was a fantastic continental cruiser. I do like my mkII but I always preferred the suspension/ride comfort of the mkI. Saying that my petrol mkII is somewhat quieter and economy not that much worse than it's diesel predecessor. However re the theme of this thread I doubt I'll achieve the starship mileage of some of the mkI's - especially compared to the 1.9. My next-door neighbour has a 2003 1.9pdAudi Avant that looks mechanically identical to my old mkI Superb 1.9 pd that's now nearly 400 k miles and running well.
Gearbox compatibility
Gearbox rebuild was around £600 all in inc labour/fitting - However the Panda has a smaller gearbox and doesn't have a DMF but cost inc new clutch and I insisted on replacement of everything "inside" the bellhousing inc the funny lever release fork Fiat uses
Superb 'Outdoor' Suspension Swap
I was surprised how much higher the rear end of my FL twindoor was after the rear springs were replaced.
Why not get it sorted by a gearbox specialist? I used one for mrs BJ's Panda when it started making awful noises. Now sounds/ feels better than it was new! In our case we used Wallis Auto Engineering Hull. Looking in your area - https://www.neilengineering.co.uk/ ?
Annoying noise
1) For the metallic spinning at idle the I'd still suggest - "With your head under the bonnet at tick over can you tell where the metallic spinning noise is coming from? Front or rear of engine etc." 2) Re bearing noise - If tyres are new (bearing like noise common with certain tyre wear patterns common with the mkII) then bearings need checking. If bearing then noise usually gets worse with extra weight load such as cornering. Does it change as you steer to the right or left?
The slight problem is your mkII Superb is transverse, it's only the mkI that's "length wise". All good though the 2.0 170 CR diesel is a cracker. My previous 2003 mk I is still mechanically going strong under new ownership with well over 250k miles now. Rust starting to be an issue though.
Annoying noise
Which noise is there when idling and stationary? Getting confused - two faults?
Annoying noise
Mis fitted timing belt? or was it already making the noise before this was done. It's always worth checking anything recently done. With your head under the bonnet at tick over can you tell where the metallic spinning noise is coming from? Front or rear of engine etc.
Annoying noise
Which engine/gearbox? 2wd/4wd? Note:-
Pool of "Fluid"
I'd suggest waterpump , any clues re colour of the liquid? As it's drivers side wheel I've ignored the aircon condensate drain Sunroof fitted?
