Everything posted by Danoid
Heated windscreen - Can you see the wires?
Fairly certain that’s a non genuine part, you should see the Skoda logo stamp if it’s genuine
I don’t have heated windscreen but my insurance uses Autoglass and I insisted on genuine screen First two times they rocked up it was non genuine so I refused and third time it was genuine. Was great because all it cost me was £10, as it had a chip which they fixed but then I noticed it had little cracks again a few weeks later, so they replaced the whole screen I don’t have cameras either but I just said “people had issues with non genuine” as some folk on here had it replaced but glare and distortion was all wrong
Would you buy this car?
I wonder why the mileage is “unavailable” If I were you, I’d go back and ask for an hour or two test drive on your own and say if there’s any reason you’re not happy you’ll repay fuel back £20 or so Then if all good buy it then get a DSG oil & filter change at a Skoda dealership then live happy Btw VAG changed timing belt interval to not be based on mileage and time instead which is 10 years, so it’s due one and about £1k from a Skoda dealership (obviously cheaper elsewhere) but for your bargaining power that should knock £1k off the asking price immediately So if it’s £12500, and you like it get it for £11k, dsg oil and filter is £300 ish and timing belt another £1k
Propus Wheels reparability question
What are Propus alloys? Google says Volvo so I’m confused
update infotainment/map
Almost correct You need to unzip the map update zip, you’ll then see the 2 folders and one file, copy the 2 folders and one file directly onto sd card
Rear window spoiler loose on Skoda Superb Estate Mk3
Do you actually want it? Personally I much prefer the OE style with the two mini spoilers at either end, but yours was probably removed by the previous owner If you don intend on using it I’m sure you could drop into a local body shop repair and have a word, I just imagine they’ll charge too much
Servicing - Dealer costs & digital records
Go here https://tools.skoda.co.uk/book-a-service-online/#/sk-data/osb Out in your reg and select dealer, basic service should be £220 ish and Oosh that’s gone up! If you DIY, just keep the receipts if next owner wants proof
Front passenger window operation
Does it behave the same when using the passenger switch/drivers (passenger switch) and key fob (long press unlock, will/should open all windows) If it does then it’s an issue with the regulator and should be covered by warranty no issues and fully expect them to reimburse your diagnostic fee, which you can either confirm with local dealer or ring Skoda customer services up and confirm first
Hesitation starting then Warning Lights
Hmm that does sound like battery issue but you changed it not long ago so shouldn’t be that but I’d get the battery tested somewhere first
New VED prices
£195 like travs said 👍
USB read speed for music
You can pick up usb3 drives for peanuts these days and it’s backwards compatible
Missing Chrome Trim
Looks like top right there’s still a bit in there. Best place will be to call your local Skoda dealer Most likely this part number 3V0807834A2ZZ That is for “right” side and I can never remember if left is looking from the front of car or not
coolant type
New stuff is G12evo, if your car has G13 now you can mix but coolant will turn brown
I suspect you will need to take the cover off from the inside then you’ll be able to disconnect power and washer line Can you see the original 3rd brake light behind? I’m hoping previous person didn’t just remove it when fitting the new one and discarded it. Be good if you have the two original mini spoilers which original has and do away with the spoiler (unless you like it)
That’s rather unhelpful, like I said earlier I’d remove it personally for now until you know for sure the best way to fit correctly. If it is Skoda part then you should be able to remove it easy enough and still use original connectors and give both sides a decent clean
Hmm, I wonder if previous owner installed this https://www.kopacek.com/skoda/superb-iii/superb-iii-combi-genuine-skoda-autoas-roof-spoiler-in-monte-carlo-edition-black-magic-metallic#description Looks the same/similar If it is you can email them and ask for install documents and explain the issue you have
To be honest you can pull that off as it’s not a factory fitted one at all
Vibration noise from drivers door
Might be a right pain but if it was my car I’d take the door card off first then go for a drive and see if it goes. I take if you’ve removed the umbrella and made sure the huge cup holder area in the door is completely empty? It goes back quite far so hopefully just something in there
Used Superb from Dealer - Wet Floor
I’d say your gut is telling you something and always best to listen to it. If they can’t prove it did indeed come from a valet or open window then yeah get your money back
Should I buy
Are those wheels actual Superb ones? Not sure if I like them or not hmm Pretty sure I’ve seen them on kodiaq’s
Black badging?
They do the full black ones, but to me looks cheap Talking of costs the kopacek not at all cheap but don’t think I’ve seen complaints here from people but plenty of complaints of eBay specials
Black badging?
Like this? https://www.kopacek.com/skoda/superb-iii/superb-iii-original-skoda-emblem-int-version-front https://www.kopacek.com/skoda/superb-iii/superb-iii-original-skoda-emblem-int-version-rear
DSG oil change
£280 is very reasonable
Superb 3 2.0tdi Coolant Refill From Empty After Engine Replacement
Just out of interest how do you bleed the system? My old Passat B5.5 you had to pull one of the pipes out a little bit going through the firewall until water come out of the hole on the pipe
Heating Issue
There’s good news and bad news… Bad news is official way is to remove the bumper Good news is when looking at the front of your car, it’s just below the left of your number plate Top right of my picture is the edge of my front number plate My fingers are big, not like King Charles’ though and if I wanted to I reckon I could get that off as the grille bits are quite big As you can see the grey part has some plastic tabs which will need to be pressed in and pull it back I imagine, might be handy to have 4 hands
