Car starting issue
Since it has a slush box I suspect an issue with the ignition inhibitor.
Clicking into this forum gives offer of translation from French to English
It's not doing that to me with Windoze 10 and (Blunt) Edge.
Virtual cockpit display
KiloWatts, the same as usual.
Airbag warning light
Because the main ECU thinks there is an issue with the airbag. You need to use a code reader to find out what the issue needs, and then software like VCDS or OBD II to reset the latched error.
rear washer
Have you tried adjusting the jet with a dressmaker's pin instead of loading the parts cannon?
2010 Octavia L&K Estate 166k mileage. Low Beam Light now pink not white
@sarbouy - This is pretty much what I was thinking too, particularly on an L&K.
Advice on fixing or not to fix my Skoda Fabia 2013
@Fabiafan6 - What @MikeTheThinker said, with the note that your car will be unroadworthy until the RH rear lighting cluster is replaced.
Guess the Hire Car.... Mac's 2019 game
There doesn't seem to be a "tearing your hair out by the roots" emoticon?
headlight bulb replacement Skoda Superb MK2
Correctamundo!
- Water under car...any thoughts?
Which engine/trim level would you have?
I'd go for an SEL PHEV on the basis of fewer computery bits to go wrong and no DPF to go wrong.
the truth about electric cars
We have PHEVs (mostly Toyota P(r)ious) in Glasgow. That said they are mostly UBERs, and most of the ones I have seen parked outside a likely keeper's property are on a public highway, not on the keeper's non-existent drive.
Help, Octavia 1.6 bfq, atmospheric - MAF issue
How much clearer do you want this!?
MAF - Buy pattern, buy twice (or more).
Skoda Felicia # Won't Start
Equally to the point, they should all be within 10% of each other and 2 and 4 are both outside this.
The standard air filter box (with a reasonably new filter) will flow air for at least 220bhp, say 3x what a 1.6non-turbo makes. Not all of this air passes through the MAF!! Your better running with the MAF disconnected (and hence the default air map) indicates that you need a new genuine MAF.
Warning message only please in position P
Try A is for Audi; the last time I had work done their labour rate was about half of Henrys', and they were using OEM parts.
They knackered my car... 😢
If only my local Dacia dealership wasn't a branch of Arnold Shark...
- airbag light
I need a boot for my vrs please help !
That's not going to help much, because red can fade differently on different panels of the same car, never mind between 2 different cars.
Overheating and coolant level high
Perfectly normal, because opening the expansion chamber cap on a hot engine relieves the pressure on the cooling system and drops the boiling point from ~115C to 100C. So don't do it!
Superb 4x4 - hot or not?
You need to know if the Haldex has been properly serviced, and we can't tell you that from this data.
- Worryingly low fuel economy in city on my Skoda Octavia mk3 TDI
Paint scratch
There's your answer; Holly would like you to park further from her hedge!
Lower back pain
Never owned an SUV, but IME manual lumbar support needs setting right to start with and occasionally adjusting after maybe 4 hours (1x4 or 2x2 plus comfort and/or coffee break) driving.
