Cairus
Everything posted by Cairus
  1. No warrenty 2x 5E0035411G Canton rear door speakers 2x 5E0035411D Canton front door speakers 2x 5E0035411H Canton mirror tweeters 1x 5E0035411E Canton front center speaker 1x 5E0035412 Canton subwoofer 1x 8V0035223 Canton sound system amplifier
  2. Karoq? Maybe it will Help history.txt
  3. This is normaly by a new batterie. If The SoC&SoH ist by 80% the BMS say Stop To the Generator. If The Car is Sailing, you have the "Fake" recuperation
  4. This Parameter is for the City detection Main_Beam_Assist_Urban_Area_Detection
  5. Sure, manuell you can Always Turn on the high beam light
  6. I know how it works. But Not everybody here
  7. Misunderstood, poor translation on my part. I meant that I think replacing the camera is unnecessary.
  8. Why Change Camera? Firmware Update?
  9. I Hope you have disconnect all again
  10. There are two possibilities. 1) If only the high beam assistant is installed, then it works via the interior/rearview mirror, which technically doesn't have a camera. 2) The high beam assistant works via the assistant camera in the windshield. Regarding parameters: If you have control unit 20, then this is the method: Control unit 20 adjustment Activation speed for High beam assistant The activation speed for the high beam assistant is set to 58 km/h at the factory. If you don't have control unit 20, it's normal in the A5 control unit.
  11. I have it mounted in the trunk of my car (non Skoda) and it works without any problems.
  12. Driver's door and hood open? Electric parking brake engaged?
  13. What can I say? My equipment costs around €5,000.
  14. Take multimeter and Check Heating resistor
  15. CP will write in the Display, If is Activ
  16. Wrong Copy the contents of this folder to the SD card. Ans this is a Micro SD, Not good
  17. Show a Picture from USB Stick on Windows
  18. my personal opinion Never Touch a running VC Software
  19. Diagnose Tool Like obd 11 or something Else. The heating is Managed by the BCM
  20. Sorry , i forget i have LHD
