PetrolDave
  1. Windows, and I suspect the MIB system, expect the album art to be embedded into each and every MP3 file. I use an MP3 Tag Editor to add album artwork to every file.
  2. Because you edited out the header, which is always done by people with a VCDS clone - so it looks suspicious.
  3. Rather than guessing get a proper diagnostic scan done, very often ESC and TPMS errors are caused by a faulty ABS wheel speed sensor.
  4. Modern aerodynamics mean there is little or no direct airflow over the rear window creating a back eddy where road dirt can easily accumulate and restrict rear vision. Personally a rear wiper is a "must have" because of this.
  5. How do you plan to remove Component Protection?
  6. I had the VBF on my previous Octavia estate, always left the VBF in the up position as I found the space underneath useful for lots of small items and it made the load floor flatter. I had a Skoda boot liner and just cut off the side flaps.
  7. I don't think that screen is compatible with a MIB1 unit - @pab567 can you confirm? Please post the full part number of your MIB1 unit - DAB and Nav are NOT just coding!
  8. Currently self levelling is only required if the light output exceeds a limit, which I think is 2000 lumens, but a change to the regulations from 2027 will require self levelling to be fitted to all new designs and from 2030 for all new sales.
  9. I suggest you buy a sensor from a reputable source not eBay. BTW the sensors need to be painted to match the bumper.
  10. I wasn't aware that a Scout version of the Octavia 4 is available? Have you posted in the wrong forum?
  11. There are two threads in this forum about later versions, please ask in one of those - I think with 1804 you may have to update in two stages to get to the latest. OTA requires a later version than you have so the update won't be automatic.
  12. The important number is the 1804, which is pretty ancient. 2092 is just the software version of the display, not the actual "brain".
  13. Do you mean the instruments/virtual cockpit by the steering wheel?
  14. pre-FL means before the facelift O4, which will include your 2021 model. 1941 is the firmware version of the infotainment system, now superceded by newer versions which can be downloaded.
  15. What we need is a thorough public investigation into the profit levels on EVs, since it seems the RRP is "flexible" which suggests possibly excessive profit margins leading to prices that are high enough to discourage the switch from ICE to EV for many less well off drivers.
  16. Not sure how the ABS and TPMS firmware would react to different size front and rear tyres on the O3, it's been designed to have identical size front and rear tyres so you could end up with ABS & TPMS faults. Yes the RS3 has different sizes but it also has different ABS firmware.
  17. Resetting the one touch does NOT involve the fob, only the window switches on the door - and the door does not have to be open just the ignition on. You're making it far too complicated!
  18. But the E-Tec adds weight for the batteries etc. - be worth comparing the unladen weights of the two cars, and I'm pretty sure your Mk4 will be heavier than the Mk3 was so will need higher tyre pressures.
  19. Does one touch window open/close work on ALL windows? - that's a pre-requisite for the long press to work. If it doesn't then you need to reset one touch by the usual hold the switch down when the window(s) fully open and fully closed.
  20. Because there is no other source for MIB2 maps than VAG, so we have to "play by their rules". Skoda SD cards are available easily off eBay (that's where I purchased both of mine) for less than an equivalent size normal SD card at full price, so it need not cost any more.
  21. If music over Bluetooth is fine then the Bluetooth and the MIB are probably OK, so this sounds like a phone or mobile network issue?
  22. Cornering fog lights only works when moving.
