Breezy_Pete
Sponsor
Joined
Last visited
Currently
Viewing Topic: Every day’s a school day!!
OEM (or other numbers) for parts MAF, Lambdas (both of them) Hi. :)
Bosch or NGK/NTK for lambda sensors is probably safe. Not sure about MAF, OEM may well be Bosch, see if there is a Bosch part number on it.
Partslink24, but it costs money. Various pirated free catalogues are online e.g. ,https://skoda.7zap.com/en/cz/ but usually not completely up to date and lacking the facility to input VIN and have results filtered to only show relevant parts.
VIN supplied by PM, engine code = BFQ. Car built 17 Jan 2003. Front lambda probe part number 1K0998262D. Others can help with physical location, probably just before/upstream of catalytic converter on front exhaust section. Rear lambda probe 1K0906262AJ, superseded by 1K0998262Q. Air mass meter 06A906461B 👍
Tell me the engine code or VIN and I can help. Engine code is on build sticker near spare wheel or on a sticker on cambelt top cover. VIN is visible from outside car through base of windscreen.
Dreaded wiring loom - Cannot locate spares for sale
(Relatively) Good price here Skoda Wiring Set For Door 5J0971120HG - LLLParts
The full part number of that is 5J0971120GK. It has been superseded to 5J0971120HG, £98.70 + VAT from a Skoda dealership. Not sure you'll find many if any other sources for a new one.
Petrol Overflowing when Tank Less than 3/4 Full
Skoda dealership parts dept. Surprisingly, not vastly expensive, probably part number 3Q0201801D, £46.42 + VAT, but they'll get it right with your reg number or VIN.
Air Recirculation malfunction
OK, just trying to help.
Maybe a temperature-related 'feature'? Deliberate? See what others with same car say. A failure so early in the car's life seems unlikely.
Dashcam electrical supply / fuses
For 7 euro plus tax you can get an hour of access to erWin Skoda, the online official information resource. Circuit diagrams are amongst many of the pdfs you can download. Fuse tables are at the end of such docs. Not all countries allow access to this, I think Australia is one that doesn't.
Fuse 7, and 39-46 inclusive and fuse 50 of the cabin fuseholder all appear to be ignition switched.
Fabia 1.4 2005 - Engine Won't start BBZ Engine 75kw 100hp
This page shows a couple of older equivalent part numbers,in grey boxes near top of page. https://www.skoda-parts.com/spare-part/030957147aa-speed-sensor-1-4-16v-55kw-european-union-41175.html Not sure why so many part numbers, I have a spare for my manual BBY but that's a different number from any of those, though it has a captive cable.
^ Yep, I was thinking that you said your crank sensor has a captive cable, with connection to the loom remote from sensor. Reckon you'll still find it can be done without gearbox moving, though Mr BKY's video appears at times to have been filmed by a tiny person sitting behind the engine. This is the current part number and appearance of genuine sensor for a manual gearbox BBZ Engine impulse sender 16v 1.4 / 1.6 Golf4 Beetle Bora A2 030957147AA Genuine VW | Deutsche Parts (deutsche-parts.co.uk) If you think that listing is expensive, retail price at Skoda dealers is a startling £111.80 plus VAT! Once again, in another 'bid or Make Offer' listing, ebay may provide potentially excellent value (appears to be missing its captive screw, but that's likely 'workaroundable' by extracting old one)? Would be nice if this is the last 'boom' from the parts cannon for you, apologies for my apparent bum steer on the TB.
Reckon so, top work Lee.
How to test wheel speed sensor?
Easier said than done, I fear, and you've said it might be tricky. What about trying the magnet waving on the rear sensor (extracted) that seems to be working, to test your test technique?
Actually, not so sure now I've looked at some workshop manuals. Would be odd if it can't. Are you saying you've done one on an AUB sep?
If the sensor is kidding the ECU into thinking cranking is too slow, that could be the issue. I'm near certain that you can change the crank sensor without removing gearbox, will see if I can dig up instructions. Or ask your VW guy? Not Crasher is it? He's on here too.
One cylinder no ignition
Inspect cylinder 2's wire between coil and ECU for damage/exposed copper/corrosion maybe? Probably easier to run a new wire in parallel with existing, spicing in close to connector at each end? Or are you saying all's well now?
What gearbox oil for a 2012 1.2 TSI fabia engine CBZB
The specified oil for that code is part number G 052 512 A2, superseded by G 055 512 A2, £14.92 + VAT per litre from dealership. Fill qty is stated as 2.1L but most people report that they are unable to get the full theoretical amount in when refilling, so I would quite confidently predict that 2 litres will be enough.
Read your gearbox code off the build sticker on the boot floor. Same line as engine code, often.
Cruise Control Not Working, Is It Even Installed 2009 Superb 2 1.9 Greenline
I think testing off the car probably needs a small magnet to waft around near it, while having +12V on pin 5, the return/earth of that on pin 1, then measuring volts at pin 2 and expecting it to come and go as the magnet is/isn't adjacent. Sort of as explained at the end of my post on May 19th above.
Air Conditioning
The data sheet posted contains this line just under the headings, which might be a clue: "The REACH etc. (Amendment etc.) (EU Exit) Regulations 2019, SI 2019/758 (as amended)." Wonder if brexit has made that link I posted obsolete somehow? Bet the A\C refill commercial outfits are 'snowed under' this week, and thoroughly booked up for the foreseeable.
Battery tray clamp/bolt?
It will be their failure to 'tell' the car there's a new battery fitted that'll be causing the fault indications, I'm almost certain; nothing really wrong. They need to finish installing the battery by doing this coding, or they haven't done the job properly. Please don't let them off the hook on this. @varooom has written a guide for how to do this, maybe show it to them if they say 'not necessary' or fob you off in any way. The warnings probably would/will go away on their own over time, but if you've paid to have the battery fitted, they should do the whole job.
Air Conditioning
Does look like the right data, thanks, but baffled by the contradiction with the link above. Halfords seem to need showing that link? 🤔
Air Conditioning
https://www.gov.uk/guidance/selling-f-gas-or-equipment
