What bulbs are fitted to the S3 & upgraded bulb recommendations
Installed d3s led bulbs.  The brutal 3s change compared to xenon and better than the standard original led.
  • Replies 802
  • Views 235k
  • Reversing Lights   1156/BA15S/382   STD:   80W CREE LED’s:  http://www.ebay.co.uk/itm/2x80w-1156-BA15S-382-BRIGHTEST-OSRAM-CREE-LED-WHITE-CANBUS-REVERSE-BRAKE-DRL-/152013310456?hash=item2364b
  • Boot lights   (no std photo)   Fitted with W5W LED’s from eBay (the flat 4x LED ones in the middle)         Now whilst these were a big improvement over std they were not as good as they
  • Rear indicators   PY21W    Philips X-treme Vision http://www.powerbulbs.com/product/xtreme-vision-py21   OE on the left LED on the right:
How about heating?  It has radiator and fans. Is it usable during hot summer time? How hot do the back of the cover gets?
2 hours ago, Paikesejanku said:
¿Qué hay de la calefacción? Tiene radiador y ventiladores. ¿Es utilizable durante el caluroso verano? ¿Qué tan caliente se pone la parte posterior de la cubierta?
No problems of any kind.  It has a heat sink and the headlight itself does not get hotter than with a xenon.  Used on long night trips with no problems.  Used in the rain and very good.
This summer I will use them, but they heat up less than a xenon.
 A recommended change.
What kind LEDs are those and from where did you order them?
Does anyone know of a decent reliable set of cargo boot lights which would fit in a skoda combi MY2018?
I recently fitted a pair of Leds from Aliexpress , although they provided good brightness compared to the original lights they caused no end of problems with "boot open" errors and even battery drain.
Switched back to the lacklustre original bulbs while trying to find alternatives.
Are these any good?
https://amzn.eu/d/hLJf9Oi
Are these any good?
I don’t believe anyone has managed to fit boot lights without some sort of problems unless they’ve bought these
http://www.kopacek.com/Skoda/SUPERB-III/Superb-III-Combi-MEGA-POWER-LED-cargo-trunk-light-KI-R
Rather expensive but if they fit and guaranteed to work then it’ll be the best option
On 08/03/2023 at 21:12, MartiniB said:
i found one
-> https://www.aliexpress.com/item/32838811778.html
not ordered yet, seems ~30% overpriced, even with their "31%" discount
On 08/03/2023 at 21:22, Bap33 said:
Thanks for remembering.
I´ve bought a 4 bulb set with 6+6 red & white LEDs since this post. But not installed yet. I ´ll let you know how the result is. ;)
I finally installed the 6+6 LEDs (6 red + 6 white) such as these on my rear doors:
This looks like this:
The red lights look a bit clearer than they actually are.
I think I'm gonna install the 2 remaining sets on the front doors, since I'm a bit "fed up" with the Skoda logo:
It has something 'too much' for me.
@MartiniB Thanks for your advices
I finally installed the 6+6 red and whites LEDs. No more Skoda logo on the floor for front doors. Back to simplicity :
12 hours ago, Bap33 said:
Finalmente instalé los 6+6 LED rojos y blancos. No más logotipo de Skoda en el suelo de las puertas delanteras. Volviendo a la sencillez :
I wasn't able to install the rear door lights...
The rear door lights were standard specced on my french 2017 L&K.
Edited by Bap33
A couple of years ago I upgraded the factory halogen reversing lights with Auxito LED lights.
While the improvement was great, I still found it a "bit" lacking.
So I put a set of iilumo LED lights - phwoahhhh, a nice improvement again.
Then....
Now....
The comparison...
Edited by JR RS
Then....
Now....
The comparison...
AHH feck, I was delighted when I saw this post, turns out you're in Australia @ 60 odd bucks they aren't cheap either.
indeed they're not cheap, but they're good :)
Hi as this topic is old can someone recommend anything to buy to swap standard  fog for led option please
This topic is not old. It’s just dynamic a full of information. 😁
Take time to read, you´ll find the answer for sure… 😉
+1, it's old, but not obsolete.
....also famously said by a Terminator 😉
The stuff recommended already still applies.
Cannot find stuff on Ali express
Hey there! I have a Superb 2016 L&ask estate. The interior ceiling lights in the back of the car above the backseats is very weak and a bit too bluish for my taste. What is it called? And has anybody changed it?
Hello, this week i have replaced my xenon light with led lights. I was  afraid in doing the switch because there is no known brand that produces these kind of lights. In the past i changed the fog lights to led and they have been working good since i replaced them 4 years ago. The brand i choose then was bevinsee  so i went to theire site and found that they made led light that replaced xenon lights and one good thing about this brand is that have a warranty of 3 years , so i decided to purchase them . I fitted them (my lamps are non sla ,  i did not remove the wheel arches but it was dificult to clip the led lights in ) . For now , i'm happy with the light they are 6000k 7000lm, they produce more light then the oem (xenarc osram d3s) below  is the link to the lights oficial webpage but i bought them from aliexpress for 55€.
 https://www.bevinsee.com/products/d3s-d3r-led-headlight-bulbs-7000lm-for-hid-xenon-lamp
On 08/03/2023 at 22:12, MartiniB said:
i found one
ordered this 12+6 LED version, but received 6+6 😞
last incandescent bulbs have finally been replaced
Ali's 3AD 947 411 vs OEM JBE 150 1102
Ali's 3AD 947 411
Door_Warning_Light_3AD_947_411_Ali_50p.thumb.jpg.4eb97f1633998d67ea3e5d06247c09f2.jpg
OEM JBE 150 1102, clear print as 5th VHS copy :)
due mismatching product description i asked, and got, 50% refund from Ali
When follow your link, it will warn that they don't fit : WILL NOT FIT EU 2017 Skoda Superb III
Mine is non sla and i fitted them without removin the wheel arches ,  they are cliped and working fine.
What do you mean when you say your lights are non sla? But you’re certainly brave; I hope they don’t melt your headlamp housings.
