Dashcam Switched Power
22 minutes ago, Graham Butcher said:
When you say it threw a wobbly, I assume that it switched from displaying the speed to a live feed display of the road? This what happens with with my Nextbase 622GW and apparently it is caused by the dip in supply voltage when the Starter kicks in. The good thing however is the camera continues to record and is not affected by the change in display. This will happen regardless of the fuse you are connected to.
Thanks Graham, but it rebooted, or at least tried to and it got stuck in a cycle of constantly looping the start up sound with the Nextbase logo stuck on the screen. Had to pull it off the click&go mount.
  • Replies 166
  • Views 88.2k
  • WARNING!!! Hi Guys. For those fitting a dashcam to their vehicle. You need to be aware that for at least the last eight years that I know of, Skoda have fitted their "Curtain Airbags" (the ones b
  • mattjames1980
    mattjames1980
    Hi all, popped the panel closest to the door and it came away easy enough. You can get to the fusebox through the side here and there's two points into the frame you could use to ground. Just thought
  • mattjames1980
    mattjames1980
    Pull towards you not push away https://www.dropbox.com/s/9e5w02f7nwbnhh0/VID_20190302_174557_01.mp4?dl=0
In that case then, it is an indication that the small internal Lithium Ion battery is failing, I had that happen before on my 512 dash cam, sourcing a new battery and fitting it will cure that issue.
If you don't feel that is something that you could do, then Nextbase do offer that service for you.
Edited by Graham Butcher
  • 6 months later...
Hi ,
I came here to post something I encountered recently with my Skoda Karoq, it happened during snowfall when car was parked and I tried to clean the rear wind screen by activating the rear wipers, it failed to move and I also realised the Dashcam isn't getting any power. It seems like the rear wiper fuse had gone bad, because it is the same fuse where I connect the Dashcam wire as well.
Also, the rear wiper when it was in working state had issues like, intermittently stopping (not reaching full wipe) and starting when rear wiper is activated.
Anyways, I will check the fuse and update.
6 minutes ago, Heisnam said:
Hi ,
You were lucky if you only blew a fuse. Mercedes Sprinter vans snap the wiper arms.
Hi everyone,
Can anybody suggest an alternative to fuse 47 (rear wiper) for tapping the Nextbase Dashcam, I earlier used it but had issues with rear wiper not functioning properly stopping before a full wipe. Thanks.
  • 3 months later...
Hi everyone, I am also attaching 2 pictures of my installation for LHD Karoq. Initially I've started undoing the glovebox only to realise that the fusebox is fitted there only for RHD Karoqs. Spent a good minute trying to locate the fusebox behind the glovebox, only to realise it can't be there for my car 😬
Wiring is not as seamless as I would want and is stressing the gasket a bit just when it starts going under it, but I think it would be fine. Not yet confident pulling the side panel especially when an airbag warning is written on it 😅
In March 2026 I bought an August 2024 Koraq SEL to which a Nextbase 322GW front & rear dashcam had been fitted when it was supplied new. The dealer hadn't connecting to a 12V switched supply but it is powered via it's USB socket. It's not connected into the USB socket by the rearview mirror nor into the 2 x USB sockets in front of the gear selector. So I assume it's been connected direct into a USB connection some where.
Why do this & does it have any problems other than slower battery charging? It seems to work OK.
The only other potential USB ports that I know of are on the back of the center console for the back passengers. If not connected there, they must have wired it directly from somewhere.
My Karoq doesn't have the USB on the back of the central console. I think they are an optional extra cost item.
All dashcams that I have had and seen are powered via a USB lead that plugs into the dashcam itself. Is the USB that you're seeing? I have had mine hardwired into the car's electrical system so that it automatically switches on when the ignition is powered up, but the cable running to the dashcam is always a USB and, depending on the make and age of the dashcam, will be micro, mini or USB-C. The other end of the power cable terminates into a power adaptor that converts the 12V to 5V for the dashcam, and the wires are normally connected into the car's fuse box.
My Nextbase has a seperate socket on the windscreen mount that accepts a special Nextbase plug/lead directly connected to the car's 12V supply. The dealer didn't use when installng. The camera would then pick up the power through it's connection to the mount.
Oh, now I understand, but that wouldn't make any difference to how it works. I have a Nextbase 622GW which also has a socket on the mount to which the power lead plugs into and the dashcam then has a multipad magnetic connection to the mount and picks power up via this connection, enabling the dashcam to be taken of the mount. But the camera can also be fed directly via its USB connection, it just makes in slightly harder to remove the camera and plug into your PC.
Removing the A pillar trim is a real pita, and there is an airbag tucked away in there as well.
When its off, remove the lh end dash panel containing the passenger air bag switch and you can feed the power cable down to the fuse box.
My system also has a rear camera, connected to the front.
Remove the cover on the rear view mirror which enables the front edge of the headlining to be pulled down.
Remove centre fir retainer on rear edge of headlining so rear edge can be pulled down.
Then, using a long flat piece of plastic, fed the rear camera cable from front to back above the headlining.
It can then be fed through one of the rubber flexible cable ducts servicing the tail gate and by removing the tail gate upper trim, exiting on the inside of the rear window glass.
  • 5 months later...
It does see to make a difference to how the dashcam operates. Everytime the stop/start operates the dashcam switches off & on. If I was stopped and a car ran into the back of me the collision would not be recorded.
I turned
I turned off my stop/start by raising the threshold of the voltage at which point it comes into play. The car now behaves as if is not fitted with the system. The minute amount of fuel it uses is way cheaper than the cost of replacing the battery, starter motor and alternator, which work harder with the system activated, and the camera switches off and on all the time. This is a better solution I think, especially if you drive in a town or city a lot as it exposes you to a higher risk of not video evidence at times of increased risk.
29 minutes ago, Graham Butcher said:
I turned
I usually switch off Stop/Start as part of my start up routine but occasionally forget. It just annoys me that a dealer carried out such a poor dashcam installation.
Nothing the dealer can do about it. That is how the dash cameras automatically switch on and off is by detecting the actual voltage being fed to it. If it drops below a certain point, the camera switches off. When the car starter kicks in, there is a large drop in voltage everywhere in the car at the same time, so it is just as likely to do the same even if it is plugged into the power socket. At least with the camera wired up so it wakes up when the ignition is switched on, it removes the chance of you forgetting to plug it in, leaving you without any video protection in the event of an accident. If the voltage gets to a critical point when it is plugged into the 12V socket, the camera switches itself off to prevent it from draining your battery even lower.
So wiring it in will prevent it being forgotten to be plugged in when driving and also prevent it from being forgotten to be unplugged when you aren't driving the car.
For the small cost of an OBDII scanner tool, you can ensure that you can never forget to switch off the stop/start by tweaking the point in which it cuts in, all the way to disabling it completely, and also alter the way other things operate, and also enable some options that aren't operational unless you have a range topper car model.
