Amundsen MIB2 Firmware Update
Hi Just wondering if there is an update for my system?
Many thanks
  • Replies 4.7k
  • Views 882k
Hi pab567 - really appreciate your help on this topic.
I haven't updated my 2018 Octavia since I bought it in 2020 and sometimes I get apple carplay issues when it randomly disconnects. How can I update my system to address that? Screenshots below:
Thanks a lot in advance!
Last Firmware is FW0480
Thank you. Is it possible to upgrade to that firmware with a usb stick? Online Update button on the car didn't work, and couldn't find the file on the Skoda Update Portal. I suspect we have to pay for it at the service?
You have PM
I have a 2016 Octavia with the Amundsen MIB2 system, and was wondering if there are any updates for this? 🙂4460acac-4ccf-4961-acbc-7a375bbee9ae.jpg
17 hours ago, Cairus said:
You have PM
Is it possible to get the info too as im on 477? Many thanks.
Hey,
@pab567 could you please share new firmware for infotainment system. Many thanks!
Device part number: 5Q0035840B
Hardware: H30
Software version: 0361
Media Codec: 3141.0.0.1
Edited by elej
hello,
i would like to ask if there is an update for this version?
Thans
Is it worth it to go from P0369T to P0480T on a 5Q0035874B unit? Will I get the colored grid menu?
I just need to use the toolbox to patch swdownload, right? Are there any risks? Thanks.
You need Meta.
Yes you can brick the device
@Balazs yes, you will get color grid menu.
All check your PMs for dwonload links.
Just a reminder:
1. format SD (best max 32GB) under FAT32
2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder)
3. insert SD card into the slot
4. enter Service Menu (long press MENU button)
Hi everyone
Could someone send me an update for my system?
Thank you
You have the latest Firmware for this Firmware Train
Ah, ok, thanks for the reply.
Hi pab567. Please can you provide the latest software update available for my device?  Part no. is 5E0035874A. The Installed SW Train Version is MSTD_EU_SK_P3420. The Installed SW MU Version is 0435. Many thanks, Stuart
PM sent
Thanks so much 👍
Hi Pab567,
I have a 2017 registered/manufactured 2015 Skoda Octavia Mk3 with the following hardware and software versions.
Please can you send any relevant updates (and instructions on how to install them) and let me know if it is possible/how I can get smartlink activated and link with Android Auto.
Sorry I can't PM as I am new to the site.
1 minute ago, VRSEY17 said:
Hi Pab567 @pab567 ,
Hi guys.
I have a question for you.
I bought a connecting cable to power the radio from an external source. The reason was to connect diagnostics on the table.
For this, a gateway control unit is needed.
I have everything. However, after connecting the vcds diagnostics, the diagnostics only see the gateway. It does not see the 5f infotainment unit. It does not communicate. As you can see in the photos. I was a little surprised that when turning on Bluetooth on the radio it says, "turn on the ignition",
Does anyone have any ideas how to connect the diagnostics so that everything communicates.
Thank you very much for the answer
David
Hi guys, I am new Skoda Octavia owner. Can someone provide me update for my Bolero system? I am not sure but I suppose it is good to update it. Thanks
@IvanMaihaus
The latest Firmware is 0480
Password send me a Message
https://mega.nz/#P!AgGWtzUFoIOM4t9fc-ytrUjaQcCFEvmu8jKphKDSB14nvb6R3neEHfChr0i8fyXQe6SkrUDjtl3vpPDZXRGV44NecBDE2by_C0hK_zDuHWDuB9bbfSd4gJMWyqcRA7qmbxxCSZ4ldow
Edited by Cairus
9 hours ago, Cairus said:
@IvanMaihaus
Hi Cairus. I am new on the forum and it seems I cannot send messages. I even subscribed but still cannot and it is required to do something to achieve in order to send personal messages. Would it be possible that you send me a message.
@IvanMaihaus
