Update to Version 1969
  • Replies 534
  • Views 145.5k
  • The update files for the update can be found here, credit to @Giannis20 for providing these. megaload link:  https://mega.nz/file/994DUTwL key to access file on Mega  u22UzB0cTcz6sutX
  • I haven’t tried exFAT unfortunately and not sure why I decided to format to ntfs after fat32 didn’t work:) Well it sounds like both ntfs and exfat are supported and importantly the update didn’t brick
  • New Download Links:   I have uploaded the file to a couple of my cloud services, and no password is required. Give them a try and let me know if they are working okay for you.  The firs
buonasera a tutti e grazie per i consigli che date che sono sempre molto preziosi, posso chiedervi una conferma se posso aggiornare alla versione 1985 attraverso il file "MOI3_EU_SK_R9850L_MU1985.7z"? allego foto delle mie informazioni attuali.
Grazie mille
Edited by FranzMT
Yes you can make the move from 1941 to 1985. 🙂
Today  I have been given an OTA option to upgrade to 1985, I'm currently on 1969 has as anyone else been offered an OTA upgrade?
I can answer my own question now I've found the other thread :)
Welcome.
I have just updated my Skoda from version 1803 straight away to 1941 with no problems. It took about 30 minutes. Everything as described at the beginning of the topic.
Greetings.
@TWB Are you able to confirm your hardware version. If you've got a 2021 car with H56 hardware you may be one of the first to receive a large OTA update such as this. I'm on 1941 and haven't received any OTA update to 1969 or 1985 so far.
My hardware version is H56, s/w was 1941 and I received the OTA update last week.
Edited by Jip
Yes, its H56. I was 1969 which was updated to manually.
Edited by TWB
I updated it from 1804 to 1941 in OEM store. For 30€ price. This time I updated it by myself from 1941 to 1985 for 15 minutes, using manual taken from this post and all this time the car was working with open/tilt hood. Oktavia IV 2021. Model 2022.
Did anyone successfully update SW 1810 to newer versions 1969 or 1985?
PN: 5E3035816F
Hardware: H56
Software: 1810
HMI HW: H44
HMI SW: 2088
I plan to update to SW 1941 and then to 1985. Thanks in advance!
Hi guys,
I have an 2022 Octavia Elite 1.5 e-tec
Recently I bought a HONOR 200 phone and I can not connect system with cable. Also having problem for Bluetooth connections for calls and media (system is not supporting wireless connection for AA).
Pls find my system info below and let me know your ideas?
Which versions should I go first?
SW Train, MEN3 EU SK38X P1245L
Is 1985 newest software update? Any one knows then it will be newer?
Strange after updated to 1985 update my Octavia 2020 getting SOS fault on dashboard and SOS is red. After engine off and waiting couple minutes SOS goes again good and after driving couple minutes again SOS goes to fault
I was thinking to move fwd from mk3 to mk4 but after reading this i am not sure.
Was looking for 2021-2022 RS TSI under warranty. Question is; with latest software update is infotainment all up&running or there are still problems?thank you
On mine 2022 when display was replaced under warranty there is no any issue. An was on 1969. Now update 1985 via OTA.  All okay.
Updated from 1803 to 1941 all in one go without an issue on Columbus System (Hardware H55 and Control Panel H44), took about 15 minutes. It resolved my issue with wireless android auto disconnecting, random infotainment restarts and Parking Assist error when you first start the car.
What sort of fixes does version 1985 have? Does it resolve 10" dash screen flicker  ?
Edited by RMIK2000
@RMIK2000  If you're referring to the fuel and temperature gauges flickering in the virtual cockpit, there is a separate update for that covered by TPI  2068282/3.
It's discussed in this forum thread here: Link to forum thread
I had this recently applied by a dealer and it corrected the issue. It took around 1 hour for the update to apply.
That's the one thank you!
On 20/01/2025 at 09:55, Pogaj said:
Welcome.
Greetings.
Hi, can you provide a link to 1941 software?
It's on here somewhere if you do a search for it you should find it
On 26/01/2025 at 03:26, Simon812 said:
PN: 5E3035816F
Hardware: H56
Software: 1810
HMI HW: H44
HMI SW: 2088
Hi there, I just upgrade last week from 1803 to 1941 as I could not find the link for 1896 anywhere . It worked smooth.
hardware H56
HMI HW H44
HMI SW 2088
Edited by MadalinT
Hello on my octavia 2024 here are my info
Informations sur le système
Référence de l'appareil: xxxxxx
Matériel: 065
Logiciel/software: 0166
Matériel de l'unité de commande et d'affichage: H41
Logiciel de l'unité de commande et d'affichage: 2108
Banque de données de navigation: 23.6
seems to be not the same software am I wrong? best regards
Matériel: 065
Is your Octavia already facelift? If yes, that this software is for Octavia before facelift.
Thanks a lot for this info.
where can i find info for after facelift please?
on m’y screen no menu no home.
Hi all,
Just sent in my pre-FL mk4 for year1 servicing and requested agent to update my firmware. They updated to the below details. Will try it out to see if any difference versus old firmware.
Old firmware never had any stability issues, only a brief period of lag when trying to adjust aircon or select drive mode immediately after starting the car.
New firmware:
Hardware: H56
Software: 1985
Display unit/control panel hardware: H47
Display unit/control panel software: 2103
Navigation database:
20.8
Media Codec: 3.1.4
Old firmware:
Hardware: H56
Software: 1889
20.8
Media Codec: 3.1.4
