Blind spot assist retrofit
6 hours ago, EduardDo said:
The vcds I have is a clone one
Don't expect any help from Ross-Tech or on here when using your illegal rip-off clone of VCDS.
  • Replies 244
  • Views 31.9k
  • I  am almost done with the materials.  Here the most important.      Left radar 2Q0907685H  Right radar 2Q0907686H (master) Bracket on the left 5E6907456A
  • I've had VCDS for well over 10 years and it's paid for itself many tmes over with £100 in garage fees saved everytime I (or friends) have needed a fault diagnosis.
  • Could you please open your topics in the karoq area and create a thread for each topic?
For a hobbyst like me is not worth to pay 800 Euros or God know how much for a full vcds
I'm also a hobbyist, and I don't know where you get 800 Euros from, the real price for a 3 VIN licensed cable suitable for a hobbyist is GBP222 which is €255.
Still a lot... For that money I could go to a garage and do a full ambient light retrofit with a app while getting the full car cleaned... Or do 2 full service changes to the car
But still I am aware of the limitations of a clone, and I acknowledge that I won't get support from Ross Tech
7 hours ago, EduardDo said:
So sad to learn you can't diy your car anymore, my car has SFD 1 and even with obdeleven I don't know if I can unlock itt and the swap to vcds to do the adaptations
The vcds I have is a clone one bought it with 40 Euros , but another 150 Euros for obdeleven just to unlock sfd once ?? It's a lot
You dont need vcds, when you have OBD 11 Pro
Hi everyone, I have retrofited my Skoda Kamiq to install the BSM. I have installed the same radar ( 2Q0 907 686 H / 685 H ) and impossible to remove component protection with Odis online.
I see on another forum the H versions are very difficult to install by retrofit due to SFD2
Anyone have a ideas ?
Day of Production from the Car?
VIN?
VIN?
Production 31/01/2023 and my VIN is : TMBGK6NW5P3092109
Which Error Code have Odis ?
Edited by Cairus
I don't take screenshots from ODIS but on OBD11: Screenshot_2025-09-20-19-46-04-881_com.voltasit.obdeleven.jpg
When we try with my colleague on Odis, the option to remove component protection doesn't appear
Wrong radar... H is for UNECE vehicles
Fit B instead
Edited by East_Yorkshire_Retrofits
For Index B I have the note until production date 21.06.2021. If it is Index E in my opinion
Installation periods for the Kamiq
A B are for MQBx
D E G H K are for MQBevo & MEB
A & B do not have component protection
Until Index B, the Power ist KL15
I have the same information, B is for Kamiq mk1 and HJ for Kamiq mk2.
Not others.
For the power, since 2019, these modules are powered by KL15a and not by KL30 (as recent car for Exit warning into the door IThink).
For my Kamiq, I followed the official Skoda documentation (see attachment)
Is it possible to "downgrade" the H version into B compatible with MQB ?
If not, I'll order 2 versions B and I have to sell the H versions 😁
Lane Change Assist 7Y1.pdf
Until Index B it is Kl15
For H versions installed on Kamiq 2024, the schema show also KL15, are you sure ?
Edited by Vincent_83
I Connect every Control unit With Index B on KL15
And you're right, it's the good line.
I just have see the schema for 2025 Octavia and it's on KL30a.
But Kamiq is KL15a (I don't know if the new Kamiq is MQB or MQBEvo)
I just found on Ovoko 2 radars version B compatible with my Kamiq.
Maybe just the correct Dataset to be installed for Kamiq and I think it will be ok.
I'll inform you soon
Fit B instead
Is it H good for my 2022 FL Karoq?
I have 2 version H if you want 😅😅😅
Normaly Index B
