Blind spot assist retrofit
I don't have any success when I tried to flash dataset of the versions H with VCTool ☹️
  • Replies 244
  • Views 31.9k
  • I  am almost done with the materials.  Here the most important.      Left radar 2Q0907685H  Right radar 2Q0907686H (master) Bracket on the left 5E6907456A
  • I've had VCDS for well over 10 years and it's paid for itself many tmes over with £100 in garage fees saved everytime I (or friends) have needed a fault diagnosis.
  • Could you please open your topics in the karoq area and create a thread for each topic?
Is correct
Ciao friends,
I'm following this conversation with interest I have a 2022 Skoda Octavia mk4 and I would be interested in this retrofit I'm following this conversation with interest I have a 2022 Skoda Octavia mk4 and I would be interested in this retrofit, I wanted to ask so as not to make mistakes, what would be the right radars to buy for my Octavia and what are the steps after installation?
2Q0907686E until 20.06.2022
2Q0907686G After 20.06.2022
10 minutes ago, Cairus said:
2Q0907686E fino al 20.06.2022
2Q0907686G Dopo il 20.06.2022
Thanks I will look for the spare parts, for me it's fine before 06.2022
SFD2...
Wrong module for the car...
Edited by East_Yorkshire_Retrofits
Can somebody tell me which is the exact production date of my car? What do You need VIN or what else?
I need the vin
4 hours ago, Cairus said:
I need the vin
Sending via dm
10 hours ago, East_Yorkshire_Retrofits said:
SFD2...
Yeah, I know now and with your help, It's not the good versions. But I had tried to see if I can made somthing with this version... and nope.
The strange thing it's the CAN Extended isn't recognize into the module 3C. In VCTool, others ECU show me the way to communicate with them (Powertrain bus, Infotaintment, etc) but the 3C is Unknow. Maybe due to SFD2 you'll say to me ? 😁
2 hours ago, Benja77 said:
Senden per DM
15.03.2022
25 minutes ago, Vincent_83 said:
Ja, ich weiß es jetzt und mit Ihrer Hilfe, es sind nicht die guten Versionen. Aber ich habe versucht, herauszufinden, ob ich mit dieser Version etwas machen kann ... und nein.
Seltsamerweise wird der CAN Extended im Modul 3C nicht erkannt. Im VCTool zeigen mir andere Steuergeräte die Möglichkeit, mit ihnen zu kommunizieren (Powertrain-Bus, Infotainment usw.), aber das 3C ist unbekannt. Vielleicht antwortest du mir ja auf SFD2? 😁
unece also Index H is no longer in the extended can
Then where?
I'm not agree, according to wiring for Kamiq after 2024 (using H versions) connected to Extended Can
But architecture of Kamiq is very special...
Lane Change Assist after 2024.pdf
Edited by Vincent_83
Sorry, i Looks bei unece Cars, where Index H is used, MQB EVO
Edited by Cairus
Karoq’s platform is MQB Evo, so H should work
No, karoq is Not MQB EVO, Index H needs unece Car, you dont have a unece Car
Karoq is MQB A1 lke Ateca and T-roc ph1
cars with MQB evo are:
Audi A3 Mk4
Audi Q3 MK3
Audi Q3 Sportback MK2
Audi Q6
Cupra Formentor
Cupra Terramar
Jetta VS8
SEAT León Mk4
Škoda Superb Mk4
Škoda Octavia Mk4
Škoda Kodiaq Mk2
Volkswagen Caddy Mk4
Volkswagen Golf Mk8
Volkswagen Multivan (T7)
Volkswagen Tiguan Mk3
Volkswagen T-Roc Mk2
2 hours ago, Cairus said:
January 2024 is not unece
Ok but why version H is used on Kamiq since 2024 ?
Even the FL isn’t Evo?
The 2026 T roc is MQBevo
Update from mechanic: Units with H at the end have been fitted and once dataset (I'm still looking for it) has been flashed according to him, they should work, even if many of You tolf me the one with final B are better
BUT I do have a question, among the several retrofit, I also did the Park Assist: initially I used a 5Q0 control unit (PLA vers. 2.0) and it worked fine, then I realized I needed to 5QA (PLA vers. 3.0), specific for my car: I replaced and it works even better now! Can it happen the same with H units?
Edited by Cairus
H has SFD2.. Not straight forward/cheap to configure. H is for MQBevo. Incorrect for your vehicle, will not work. Install B.
