  2. simonsuffolk joined the community
  3. Hello Another (hope not big) problem. Superb 2021 2.0 tdi 147kw 4x4 Dsg7 I have wierd noise from my car somewhere front i guess. When i drive from 70 to 90 kmh and release throttle there come some nois from somewhere (uuuuuuu) not so laud. There is no differenc if car stay in gear or go in coasting (neutral) the sound is there! But imediatly when i pres just a little throttle the sound is gone. What could this be?
  4. Seba800 started following Strange sound
  5. zazazac changed their profile photo
  6. Today
  7. zazazac joined the community
  8. Bought a demo Kodiak PHEV at a very good price but to be quite honest we may not have thought though all the implications of our hasty decision. I have been buying a lot of things for the car in preparation of our first holiday away in it to the relatively sparsely populated Western region of the state. The car, (like many EV and PHEV) does not have a spare tyre, just goo and an electric pump. This is simply not good enough, so I have bought a spare tyre and jack online for peace mind when remote travelling on dirt roads. The car only came with a Type 2 cable, so I have made my first Amazon purchase (yeah, I know, my first!) of a 15 amp home charger for about 75 pounds as an interim measure until I sort out something from our three-phase electrical supply. To truly 'Australianise' the car, I fitted mudguards from Skoda today and masked the front grills with flyscreen in case we encounter locust swarms which have been reported in the interior due to the unusually wet weather they had last winter. So far, our very limited experience of driving the car has been a very pleasant experience although my wife is somewhat intimidated by her perception of it being much larger than our mk3 Octavia. In actual fact it is less than a hand length longer and a hand width wider, but I understand why she feels the way she does. We loaded a couple apps on our phone and went up the coast to the nearest scenic (8km away) 22kw AC public charger to test them. Spent $1.50 on 6kw of our best local electricity and $16 on two lattes and three doughnuts, which were not the best. Next experience will be to test a quick charger since the car accepts 50 kwh on DC. Obviously, the electricity will cost more, but we shouldn't have time to buy coffee and cakes so cheaper overall .
  9. According to obd11 my battery resistance reached 6.0 milliohm today. It seems to hover between 5.2-5.8 lately. I found a screenshot from December 24 and resistance was 4.2 milliohm. According to my battery-aging performance/charging reading it’s down to 64%/65%
  10. https://www.briskoda.net/forums/topic/419731-auto-folding-wing-mirrors/
  11. Press the remote lock button twice I think to get them to fold in. Is your mirror adjustment button set to have them fold in as well?
  12. I know I've seen it somewhere, but no matter what search term I put into the forum, the answer eludes me. I can fold (as usual) the mirrors using the switch inside the drivers door of my Yeti, but the remote doesn't do it. Can someone please point me to the post that dealt with this issue? Thanks
  13. If you can access the heater matrix hose connections in the firewall and disconnect the hoses you can: Like Alasdair said flush with a garden hose Blow compressed air in the "input"-connection and catch the outcoming fluid from the "output"-connection, careful dont blow too hard, it will make a mess Tape a long clear hose that you can feed in to the heater matrix to a wet vacuum cleaners nozzle and vacuum the coolant off from inside the matrix
  14. Not Change Hardware, Only wire Setup
  15. Update on my Approved Used Octavia vRS – VAQ service, outstanding maintenance and Start/Stop Just wanted to give everyone an update and thank those who have offered advice so far. I've continued corresponding with the sales manager at Škoda North Wales regarding the servicing that appears to have been outstanding when I purchased the car under the Approved Used programme. Following several emails, they've now offered to reimburse the £199 cost of the VAQ front differential oil service as a gesture of goodwill, which I've accepted. However, they're still declining to cover the spark plugs (£140) and engine air filter (£55). I've gone through the independent Pro Tyre service invoices individually. Interestingly, there's a section for air-filter replacement on the paperwork, but it hasn't been ticked on any of the invoices. I also can't find any mention of the spark plugs having been replaced. The dealership maintains that its technicians considered the previous service documentation, Škoda's internal systems and the condition of the components when deciding what work was required. I've asked them to explain exactly what evidence they relied upon, particularly given that item 115 on the Approved Used inspection checklist was marked R (Requires Further Attention). This is the item stating that all serviceable items due within six months have been completed and the service history brought up to date. I'm still waiting for a response to those questions. Regarding the Start/Stop issue: The sales manager explained that the N/A recorded against the Start/Stop check on the inspection report was a technician's error and that it should have been marked as checked. Apparently, no relevant faults were recorded. However, the system still isn't operating as expected. I've now booked the car into Škoda Worthing for Tuesday 24 November for a Start/Stop investigation and battery health check. I'm also planning to have the VAQ service completed at the same appointment, subject to confirming the reimbursement arrangements with North Wales. For now, I've decided to hold off on the spark plugs and air filter while the discussion continues. I may ultimately get my trusted independent mechanic to do those jobs if the dealership won't contribute. I'm also considering raising the matter formally with Škoda UK, mainly because I'd like clarification of what the Approved Used preparation standards actually require, rather than simply arguing over the remaining £195. I'll update the thread once I've heard back from the dealership and have the results of the Start/Stop investigation. Thanks again to everyone who's contributed. The advice has been really helpful.
  16. Bought a new Kamiq from Rain worth Skoda this year, brilliant dealership and recommend them.
  17. Hi everyone, I could not find any topic covering this specific diagnosis so here is my first real post here! Looking for some real-world feedback before I order a replacement part for my 2019 Octavia vRS 245 (2.0 TSI 245hp, 129,000 km / ~80k miles, DKTB engine code). The issue: Once the car is fully up to operating temperature, there is a constant, fairly high-pitched whistling noise coming clearly from the rear (under the back seat / fuel tank area). Aside from the noise, the car runs great: no warning lights, no misfires, and it starts right up both cold and warm. What I've checked so far: A mechanic listened to the noise and agrees it's likely the low-pressure fuel pump (LPFP) inside the tank. I ran a few checks with OBDeleven showing the pump is working hard constantly (~70% duty cycle at idle, 85-90% under load), while everything else on the engine side (fuel rail pressure, fuel trims, EVAP purge valve) looks completely healthy. The underside of the fuel tank feels completely cool to the touch. Before I go ahead and swap in a new Bosch fuel pump unit, has anyone else experienced this exact symptom on their vRS (or a Golf GTI / Leon Cupra from the same generation)? Did replacing the pump permanently fix the whistling, or is there anything else around the tank worth checking (tank breather/ventilation, fuel pump control module, etc.)? Thanks in advance for any insights! Cheers, AD
  18. MMX23 posted a topic in Hellos and Goodbyes
    Hi to all ! I'm the new owner of a 2019 Skoda Octavia vRS, 2.0TSI DKTB engine with 130'000km. I might post or participate in topics in relation to this car for any mechanical insight and help or regarding modifications and upgrades. I hope that I'll be able to share my experience and be helpful in any way. See you around !
  19. MMX23 joined the community
  20. I do notice the on/off when cornering lights come on at low speed is all or nothing and its noticeable, but I can't say that it bothers me per se. I prefer the white light on/off over the yellow light dimming. Down to personal preference.
  21. piotr1_1 joined the community
  22. ScrapMyCarUk joined the community
  23. maxpage joined the community
  24. O ring purchased 👍
  25. Ah didn’t think so, I quite like the dimming
  26. Hi guys, My radio was stressing me so I bit the bullet. These were my steps... (0742 maybe not needed but I did it anyway) 0463 → 0469 → 0741 → 0742 → 1790 → 1798 → 1800 Radio seems to be working ok, my wifes car so I haven't spent mych time in it. Looks good and works with my phone now. Massive thanks the everyone on here who helped but especially to the tech-savvy heroes who risked their own radios, that first upgrade is the hardest!
  27. Can anybody do me a favour and take a picture from underneath the yellow clip, I’m wondering if there is some type of washer on the underside.
  28. A few things I'd look at on that one specifically, as a diesel auto vRS is quite a different car to a manual petrol SE L. 1. Warranty. Skoda's standard warranty is 3 years, but the third year has a 60,000 mile cap and it all ends three years from first registration. On a 2023 car there may only be months left, or it may already have ended, so check the registration date and ask exactly what cover comes with it. 2. Gearbox. The 200PS diesel's 7-speed DSG is the wet clutch type (DQ381), which has a fluid change in the schedule. VW Group's UK trade guidance puts it at 80,000 miles for that gearbox, so at low miles it won't be due yet, but ask the dealer to confirm the gearbox from the VIN and to show the service history on Skoda's own records rather than just stamps in a book. 3. Your driving. Think honestly about how many short trips you do. The Mk4 handbook says that if the particulate filter light comes on, you clean it by driving with the engine warm at 60 km/h or more with the revs at 2,000 or above, and if the light hasn't gone out within 40 minutes it hasn't worked and needs a garage. If most of your driving is short local runs, a diesel may not suit you however good the car is. 4. It uses AdBlue, which you top up yourself between services, so factor that in. 5. If you buy from a dealer, you've got 30 days to reject it if something is wrong, and for the first 6 months a fault is assumed to have been there when you bought it unless they can show otherwise. So use those first weeks to test everything, including the DSG from cold and in stop start traffic.
  29. Is it possible to get to pipes that feed matrix from engine bay. Remove them from engine/coolant system and flush through with garden hose leaving matrix in situ? Alasdair
  30. I replaced calipers and flexi hoses on my 69 plate Challenge two years ago. Assuming you need the same, the hose part number is 5Q0611775M
  31. AKK joined the community
  32. What does your temperature gauge read in day to day driving it should be around 90c , is your thermostat working, can the fan be run bypassing the normal connection.
  33. Thanks, I understand. I’ll try using other available pins, if I can find any. I’m not planning a front-end facelift for now, everything is set up only for the rear-end conversion.
  34. The two signals are just for the animation. You would, of course, need to wire your headlights to match the facelift version. As far as I know, the BCM supports this. I haven’t wired it up myself, as I personally feel the animation is pointless—though perhaps I’ll get around to it when I retrofit the LED headlights.
