Past hour
Add ons
Very much horses for courses. And skill dependent. I have done lots of bits and pieces to correct some of the age related issues with mine. In terms of retrofits I’ve added front parking sensors, reversing camera and upgraded to 9.2” infotainment screen. And a lot of other little upgrades too. I’ve also fully dechromed the exterior and added some other bits to match sportline exterior look. Full details of what I’ve done here: https://www.briskoda.net/forums/topic/537947-superb-mk3-estate-190ps-tdi-dsg-my2015-se-l-executive-moon-white/ Plans for future include: front bumper splitter and maybe pedalbox to improve throttle response. Longer term I’d like to lower it, add wheel spacers and/or maybe different wheels but that depends on the next few years MOT outcomes!
keywacat started following Reverse doesn't always engage on the first try
Nazdar lads; I've got a 1997 Felda with a 1.3 where reverse sometimes needs another try to engage. I had the tranny fluid replaced 2 weeks ago and of course that didn't solve my problem. I'm thinking the linkage might be the problem, is that what you more experienced lads would look into? Cheers; keywacat
- Skoda Octavia 2018 – MEN2_EU_SKGPX_P7381L Firmware Update & CarPlay Activation
Today
ABS fault codes in VCDS but no warning light.
Yep, bit strange. I did the clutch reset thingy in between scans, and as part of that on the test drive did a couple of heavy braking / hard acceleration - it's looking like maybe I dislodged some rust or junk. I'll post findings if/when it returns. Thanks.
Wheel spin on moderate throttle
Get your wheel alignment checked, have a look for uneven tyre wear and make sure your pressures are what they're supposed to be, preferably with a proper tyre pressure gauge because TPMS isn't universally perfect.
Austin Allegro V6 Street sleeper project by Jonny Smith Car Pervert.
Part 13 is now online. http://youtube.com/watch?v=DadcHQc4hz4 With some amazing cars.
SamSW_ joined the community
Regular False Tyre Pressure Faults
& a dragging brake or bearing on the way out can heat the hub, wheel so tyre and increase the pressure so the circumference and cause a warning. So it is one thing checking the pressures once cooled down. But when you get a warning stop as soon as you can and see if hub hot and check the pressure then.
Evolution13 started following Regular False Tyre Pressure Faults
Reading off DTC's certainly will help. One thing it could also be is a sticky brake caliper. From experience on another VW group car in the past, I had a rear caliper that was dragging and it popped up the tyre pressure loss indicator until it was stripped and cleaned. These ABS based tpms systems use rotational speed to determine tyre circumference, so a change wheel speed due to a brake dragging can be interpreted as loss of tyre pressure.
paulski started following Regular False Tyre Pressure Faults
Problem with humidity in the cabin and fogging windows
Evolution13 started following Problem with humidity in the cabin and fogging windows
Kodiaq steering wheel vibration
Do you have any new information?
In my case, i have almost no vibration at all. But it’s cold now, it gets worse when is hotter.
RAPID 2014 1.2 tsi
Thanks again Pete for the info. I am beginning to think I may need to take it in somewhere and get confirmation of where the leak is and a price to sort it.
Dry mats don't mean a dry floor. Lift the front carpets and feel the insulation underneath, especially in the footwells. On the Mk2, blocked scuttle drains can let rainwater soak in there, and it evaporates into the cabin as you drive.
SteadyDiesel started following Problem with humidity in the cabin and fogging windows
do you have a Climatronic system?
JP17 joined the community
Octavia Mk3 (5E) KUFATEC 43340 Heated Seats Retrofit – VCDS Coding Without KUFATEC 41899
BCM dont Support? BCM Change need odis online, because BCM have CP
Hello to all from Austria!
Hallo from Graz
Add ons
I have a 2.0 TDI SE L Executive 4wd Euro6 (s/s) 5dr. And have been wondering what I can add too it. I’ve thought about a reverse camera. But I’m wondering what I can add to the car. Help 😄
Jamiek joined the community
- ACC control
Cigarette plug has always power. How to change that?
I have a Mk3 Fabia, picture of my fuseboard attached. The cigarette Lighter output is on fuse 44 - it's that Blue 15 amp one on the lower row (between the yellow and red ones). The problem is that whilst there is UNswitched voltage on the top pins of all the top fuses, and bottom pins of all the bottom fuses, the only SWITCHED volts are on the bottom pins of those smaller fuses in the middle on the right.... which are a max of only 10 amps. (interestingly: all unused fuse positions ONLY had the 'incoming power' 'fuse pin' fitted, leaving the upper blade of any potential fuse dangling into nothingness - I guess it saves £££!) In the end, having considered maybe using a relay, I took the decision that 10 amps (or actually 7.5 amps, as that was the fuse I had) was enough for the camera and phone charger. So, thanks for giving us the original idea!
ACC control
AI response "Hi John, Unfortunately, Škoda doesn't let you set the predictive ACC to only drop speed while ignoring higher limits—it’s an all-or-nothing feature. However, if you want ACC to act like a strict ceiling (for example, holding 60 mph when towing a trailer, slowing down for traffic ahead, and never creeping above 60 mph even when you pass a 70 mph sign), you just need to turn off the automatic sign reading in the infotainment menu: Go to Menu / Car icon > Assist Systems > Adaptive Cruise Control (ACC) Untick Reaction to permissible speed (might be worded slightly differently depending on your software version, such as "Speed limit response"). Once that's unticked, the car will ignore all speed limit signs—both higher and lower—and simply treat whatever speed you set on the stalk as your maximum ceiling, while still using the radar to slow down and speed back up with traffic ahead. (You can also untick Reaction to road layout in the same menu if you don't want it slowing down for roundabouts and bends). If you do want to keep the automatic slowing-down feature switched on for lower limits, the only workaround is to give the ACC stalk a quick tap down (SET / -) the second it sees a higher sign and starts accelerating—that will immediately cancel the speed increase and hold your current speed." I have just been offered the option of activating ACC in my skoda, everything for it to work is fitted but the software has to be bought, for a black friday £180 ish i think it was a third off. But i prefer to drive my car myself i use std cruise control and flick the speed up and down as needed.
phemala joined the community
ffowahueusr joined the community
- Austin Mini GT-Four 'Project Binky' Build, Youtube Video Series.
RAPID 2014 1.2 tsi
Have you looked at the throttle body area, in case it's running down from up there? Do you mean the one way valve that connects via a hose to the airbox area? If it's not broken/detached I'd say there's no point in changing that. The oil separator is not a nice job. I think I already pointed you to my thread where I describe it, but in a nutshell it needs to be done from below, and the offside driveshaft needs to be removed first for access. Best done on a lift, indoors, after ruling out all other sources of the leakage. Not sure what a garage would quote, ask one.
If the wheels are spinning at moderate acceleration it could be as said tyres or greasy road conditions especially at roundabouts/slip lanes. If no traction control warning shows it could be that in certain driving modes its disabled but worth getting it scanned to see if anything has failed and caused it to be disabled. On all my skodas the traction warning light comes on even if its a minor wheel spin. There all manual so not sure re DSG. Alasdair
- ACC control
