  2. Haha, wonder what the voice command is for that!
  3. Not as yet. I've been following the other thread. There's talk of another update, I think it was in Shop, that some found helped get rid of the message, and I've been meaning to look into that. I was also planning to contact Skoda and ask them about it but not got around to it. So I'm still hitting Later every day, sometimes several times. Worst case it's in for a service in March, they can look at it then. If I make any progress I'll update this thread though.
  4. From my own experience the wireless charging trays in cars are great in theory but poor in practice because they allow the phone to get too hot, which isn't great for the battery in the long run. My Kodiaq will just about charge an iPhone 14 Pro while CarPlay is being used on a long journey, but every so often I get a message that charging will resume when iPhone temperature returns to normal, and by that point it really is glowing. My solution is to use a cable on longer journeys. You can get USB-C cables with right-angle connectors now, and one 20cm or so in length is enough to pick up the phone without having to unplug each time. Happily it coils underneath the phone and stops it charging wireless too. I think until car manufacturers realise that wireless charging trays need their own air conditioning we're better off with a wired charger.
  5. Did you ever get anywhere with this? My Kodiaq has the same issue and it's getting annoying.
  6. Today
  7. @gold I can offer you a full backup from a Kodiaq facelift model equipped with Matrix LED headlights. I won’t handle anything else remotely; the subject matter is too complex—if errors occur, something could potentially get damaged, etc. There is a complete guide for this on a Russian forum, though it’s specifically for a retrofit. Kodiaq1_FL_Matrix_LED_Full_Backup.html
  8. markthecuttysark joined the community
  9. I wish I had got the same In grey but was 8k more Im happy with the 1.5 👌 Gets me around as I need!
  10. thanks for the kind words - much appreciated. tis going to b 10 yrs of ownership soon and Gandalf still makes me happy & excited. i still keep looking for excuses to drive Gandalf. @RogueWagon - on a few rare occasions, i wish i had got the 280 AWD version, but end of the day, i do wat i can with the 220 FWD i have, and wats best for this setup. i don't have any regrets getting the 220 as its a cracker of an engine in terms of response and also lighter than the 280 overall. hopefully u'll b able to find a happy place, mods wise, for ur 1.5TSi.
  11. I'm half tempted, but I keep finding other things to do. Mine is covered in micro scratches - it has had a good polish with Ceriglass which has reduced the 'flaring' of the light going through the scratches, but it's still not great. Something for the future, maybe.
  12. I haven't used it, but I read that running heating and ventilation at the same time is great for drying wet clothes. I assume that's in case you got caught in the rain, rather than if you had an 'accident'. 😄
  13. Yesterday
  14. Not something you could have sorted? Was it all over? How was it bad?
  15. Looked at one this evening which was low miles (25K), but paintwork was shocking. Would have taken it straight away if it was as good as the rest of the car. Found nut shells in a hidden well with my inspection camera while checking out the waterpump housing for leaks. Worth a look though. Didn't bother driving it due to the paintwork.
  16. NikoX14 started following P1103 and P0130
  17. Hello everyone! For the past month I've went into a rabbit hole to try and figure out why my car has been running like **** and when I say **** I mean rough idle gas consumption ~1.5-2+l/h on idle when driving and the car is cold it stutters and losses boost and boosts again rapidly. I've fixed a hose that was split open after the n249 (or whatever it's called) and right before the Y split, and the PCV hose after the Y split that connects to the engine. I was hoping that these fixes solved my problem but unfortunately they didn't. These codes still persist. Also almost the same time that these problems started I wired an amplifier and the positive wire I fished it though the gormet below the steering wheel (could I have damaged any wires there?). And before all these, about 2 months ago, when my car was cold when I was driving and I pressed the clutch the rpms would drop like crazy and sometimes it would turn off, and this happened until the car warmed up. But I blamed the clutch switch in front of the pedal that was faulty, could that be the start of the O2 failure; I'm sorry for the long paragraph, but I can't seem to figure out the problem and it's driving me crazy and neither a mechanic wants to spend time to search the cause. Some info about the 02 sensor: When it's on idle the voltage that it reads is 0.020 volts and sometimes it jumps to normal volts, when the car is turned off it reads ~1.5 volts. The heater S1 was turning off and on rapidly on idle. And when I tried to test the sensor it said test off and after a while it that it failed, without giving me the option to test it myself manually My Gallery — Postimages 20261111_164320.mp4 20261111_164154.mp4
  18. Benji_ joined the community
  19. Kenty1001 joined the community
  20. You will find these “Advanced KESSY” settings in Car>Settings>Exterior and then swipe twice to the right.
  21. When car key removed from ignition the radio goes into its power down mode. Pressing power button with key removed results in radio staying powered off as it always has. I believe radio is correctly wired- it has been behaving flawlessly for 1 year. Problems recently occurred when new starter motor fitted. If I reverse the red and yellow wires the radio, currently running off switch live, will then be powered on the permanent live. This probably would stop the radio cutting out but would leave the radio powered on all the time resulting in a flat battery?
  22. As you say problems with the older cars but the newer ones are better I have a 21 plate VRS and never had a problem Re the sensor, its because there is condenstion in front of the camera and blocking it, but as you say it clears within a few mins
  23. Hi all, new to an Enyaq Coupe, not new to the forum or Skodas in general..... I've just bought a 2024 vRS coupe. I went to fit my dash cam to it and found a hardwire nextbase kit already fitted - result! Unfortunately, the fuse used was a permanent 12v live (!). I've since moved it to a switched 12v. I've been having app 'no connection' and 'battery protection' statuses. Historically, my Superb L&K from 2014 had a dash cam running from the 12v socket, which, ultimately meant the start/stop 12v battery required replacement. I'm wondering if the fact that the dash cam in my new car was connected to a permanent 12v has caused the battery to fail prematurely. I think it's worth changing the 12v battery to a new one to see if it sorts the app status issues. Has anyone changed the 12v battery? Anything to look out for? Cheers S
  24. parkypine joined the community
  25. I only thought about upgrading the bulbs in indicators and rear lights ….. until I joined this forum…… the you start seeing what others have done and their “bad influence” tends to effect you …. YOU KNOW WHO YOU ARE 😂😂😜
  26. Just finished work picked up the eBay package…. Took a before and after picture… can’t see the actual unit but you can certainly tell the difference 🤪
  27. Hey there Chaps, I am getting the same issue . Skoda Superb Elegance 2012 plate. "Software Download- Source Activated, Searching for SWL Image" Would it be possible to send over the software link so I can burn it onto a CD. Many thanks
  28. in video, this chemisist removed all, first soot and then ash with 25% HCL. listen him again.
  29. Hi all, after my lovely Superb L&K hybrid was written off by a myopic cretin that couldn't hit the ar5e end of a cow (but managed to find the front of my car) I decided to go full electric. My Mrs had an Enyaq before, so it was a natural choice for me. I now have an Enyaq Coupe vRS (2024). This was a pic at the dealer, the wheel covers have since come off.....
  30. SKODA_SUPERB joined the community
  31. Worth a go for soot, but bear in mind a flush or DIY clean won't shift much of the ash at 230,000 km. If you do clean it, reset the DPF ash/soot learned values with a diagnostic tool afterwards, or the ECU will keep calculating it as blocked.
  32. Anyone else using the auto function for heating and ventilating? Just today I noticed a setting to increase the intensity of both in the seat and back of both front seats and also the auto function. I didn't even know you could have heat and ventilate at the same time!
  33. no need to open dpf, many people cleaned them by therirselves. look for this video, you ill get all answers.
  34. imart143 started following DPF Problem SS II
  35. Welcome to Briskoda 👋
