  2. The Sensors can be a PITA. I had a new sensor fitted front passenger side yesterday before a MOT. It was already showing before i broke the valve as being on the drivers side from the last fitting of All Season tyres as the fitter put wheels to the wrong side. Anyway the MOT tester who fitted the New Sensor pre-mot coded all 4 sensors. Supposedly. After the MOT and a pass he took the car for a road test. When i left the place the Drivers Side was showing 2.4 Bar & 36*oC and the other 3 wheels / tyres 2.2 Bar and 24*oC. I carried on a few miles & thought the new sensor on the Passenger Front would re-set. But no. I stopped off and let them know, but it was closing time for them. So once i have time it will be going back to get coded properly................. Re Setting low pressures. On my BMW you go on the cars screen to the Tyre Size on the Car and Summer or Winter tyres and it recommends the Tyre Pressure range. Then it asks if you want to set to a pressure different from the recommended range. If you do you accept then Set the TPMS as you have inflated the tyres.
  3. I think a lot of people don’t realise the crescent moon goes piston side It’s there mostly for anti squeal but I bet it can contribute to a little vibration tbh Your previous pads may not have been bedded in correctly too, so be gentle for about 150miles
  4. Not for a Scala, but I got a set of Nordrive bars and 2 bike holders for my Octavia, from micksgarage, but I’m sure available elsewhere. Fully adjustable, and come with custom feet to match the curve of your car roof - specify the car model during the order and they supply the correct foot pack. Haven’t had any issue with any of it, and the bike rails even fit my thick framed mtb. Lot cheaper than a set of Thule bars, and not massively less aesthetically acceptable. Bit windy at motorway speeds, but overall fine
  5. Thats one very strict MOT place. Glad I didnt put my old octavia in there. Alasdair
  6. Lee01 replied to Lee01's topic in Motoring News
    https://www.skoda-storyboard.com/en/emobility/peaq-enters-production-sharing-the-line-with-the-octavia/
  7. ...But the system warnings should be inhibited if you reset the system at the lower pressures (within reason) you want to use.
  8. Today
  9. Lower pressures could well be appropriate for snowy conditions, and, in any case will soon gain some pressure once you are running - I'd leave them as is and recheck at your first rest stop.
  10. Consider using Steel-Wire Armoured Cable for the run.
  11. 6.1.3.(b)(i), apparently: MOT inspection manual: cars and passenger vehicles - 6. Body, structure and attachments - Guidance - GOV.UK
  12. I confess to being very surprised that this seal was picked up on an MOT - was it flagging a fuel purge fault (MIL) on the instrument cluster?
  13. Replied, but for the benefit of others who may be reading:- the seal ring part number is 1K0 201 557A, currently £11.55 + VAT from Skoda. Lots of offerings for less than half that price online from the aftermarket, and lets face it, Skoda didn't supply a particularly durable one when this car was built, so there may not be a strong case for staying genuine.
  14. IMHO it's rather HW issue, not SW
  15. I don't own the radio; I have it connected to a bench power supply here, so I can't test those specific functions. It has been running on the power supply for several days now. Unfortunately, the owner doesn't know the details either—since the radio wasn't really working, he didn't use it and just wants to get it fixed up. Do you think it could be a software issue?
  16. Prins joined the community
  17. Hi, I have the following system details on my mkIII Octavia Elegance -- Device part #: 5E 003 587 4A Hardware: 040 Software: 0421 It has the smaller screen, MIB1, but not sure if it's Bolero, Amundsen or Columbus? I assume this has never been updated, but I don't get the download screen, as I don't have the maps SD card -- it just complains about not having a card. I'm getting a card off the Yorkshire bay -- by gum! How do I get the latest soft/firm ware? Maybe the software on the SD card will also need updating, regularly ...
  18. Yesterday
  19. Frank19 replied to Frank19's topic in Skoda Karoq
    Okay started with both windows failing to open, it's been into Skoda three times with no positive lasting outcome. After the windows wouldn't open a Skoda employee forced them to shut and for a while they opened and closed but the glass could not be correctly placed on either side. Entering our garage I close the mirrors, sometimes when in a morning they will work and when selecting reverse the windows dip as had be programmed.Todsy everything stopped mirrors folded in but would not open left for 3/4 hours ignition on and mirrors opened but nothing worked, moved car onto garage locked mirrors wouldn't turn in locked and messy disarmed. Any solutions welcomed
  20. Hi, Here are the codes on my LHD MY22 Kodiaq : Driver seat (Left side) : Address 36: Seat Mem. Drvr (J810) Labels:* None Part No SW: 3Q0 959 760 E HW: 3Q0 959 760 E Component: Sitzmemory H07 0026 Coding: 001000020000150081C280808180000000008181000000D440 Shop #: WSC 00033 790 00122 Passanger side (Right side) : Address 06: Seat Mem. Pass (J521) Labels:* None Part No SW: 3Q0 959 760 E HW: 3Q0 959 760 E Component: Sitzmemory H07 0026 Coding: 001000020000150081C080808180000000008181000000D400 Note: They are both fitted with massage function and have only 2 memory button.
  21. Hi Frank, Your going to have to give a lot more information in a post if you want anyone to be able to help if your having an issue?
  22. Frank19 posted a topic in Skoda Karoq
    Skoda karoq ,edition 32 reg
  23. Frank19 started following Electric window
  24. Thanks for that information, most helpful. I'm going to have to wait a while if I want to try and tap into the mains as the ground is like concrete and impossible to dig with shovels or spades, so once we have a decent amount of rain that softens the ground I might be able to get our gardening team to dig a trench across the lawn about 12" deep so I can install a cable conduit (usually a heavy duty water pipe) and bury it in the trench up to a base of a redundant lamp post base, reuse that for a charger on a post.
  25. Creation Motorsport are not far from me, but not sure if I like their catchcan kit- looks lie one of the cheap ones on ebay with some hose thrown into the deal (£67)
  26. thanks bullet-guy! Yes this forum has supplied all the info I need to at least do the SAI, N249,N112 deltes and, if I get that far, then fit a catch can. Hopefully the piggyback sump plug will arrive tomorrow- until I've sorted that out, I'm not ordering £250 of parts. Everyone keeps telling me I'm crazy to attempt this, but I've had such a series of hassles from garages, it's down to me. Still don't know if i can start on the deletes and arrive at a point that allows me to drive the car- probably inadvisable. Cos it's likely to take a few days and I expect problems along the way I'll try not to ask too many questions - I expect a lot of the folks who have contributed to the 'Octavia Mk 1' sub-forum have moved onto other cars by now. The posts are over ten years old thanks for the help so far !
  27. Missed this evenings sunset although a pleasant sky just afterwards
  28. There’s all sorts of stuff (mostly useless 😬). I did find a battery temperature app though which I’ve added to the Home Screen.
  29. If you find that you need to do a lot of charging not at home then it may be worth knowing about Tesla's charging network. Many of their "supercharger" locations are open to all. Tesla cars pay a reduced rate per kWhr. Most locations are open to all and if you dont drive a Tesla you can buy a "subscription" to get the cheaper rate that Tesla cars pay..... From Duckduckgo ....
