  2. Just wanted to thank everyone who supplied answers here. I've got a '22 Enyaq iV 60 and I was having huge problems with Octopus intelligent Go and an Ohme epod 7kW charger - immediate charging fine, but smart charging failed every time. The car never seemed to wake up for the smart charging times in the middle of the night, although the first smart session which charged for a few minutes on plug-in would work OK. Software version on my car was 3.8, but it was updated before I bought it. I went through the process described here, pulling out fuse 3 for a few minutes - I think I went for 10 minutes - and then replacing. I'm sure I heard an extra 'clunk' at about 6 minutes. Anyway, end result was that it now charges perfectly on smart charging, waking up in the night to charge with no problem. So thank you! that's why forums are great.
  3. dr5urf joined the community
  4. It would NOT drive up the ramps, conjunction of dragging brakes and the slope made some GREAT clutch smells. The absolute limit of the jack's reach was enough to wedge a ramp under the front right wheel which gave me just enough room to go investigating. I won't bore you with a whole blog about it, but deblocker xs, a set of punches, and an air hammer were all ultimately successful, but I still feel beaten up. The problem ultimately was a bound up joint in the gear linkage which has been the case since this lump was delivered to me, around page two of this thread my neighbour punished the gear linkage into shifting which is what i think first cracked this bound up weak link, but it's finally gone full bluetooth: I think https://www.ebay.co.uk/itm/187384471604 will get us back on the road, but I'll try and get the existing parts apart before I order, in case I need to raid a breaker for a less rotten example. There's also this option which might be a better choice? https://www.autodoc.co.uk/vika/13157945#selector-shift-rod At least I know what the problem has always been, the root of today's oopsie, and ultimately will have a refreshed gear shifter which should feel like brand new. It does feel like everything is between me and this truck working, but this is actually the hobby I wanted, I may actually be SAD when this thing is 'fixed'
  5. Today
  6. mistac replied to mistac's topic in Škoda Elroq
    Latest update is that there is still no build week (I am not concerned about that due to the many report software/infotainment issues) so I am now expecting a Feb or Mar delivery? My dealer guy said that on their internal skoda website there was something about new builds from now on that shouldnt be getting these issues but could not recall exact reason why, but it sounded like something different happening at build stage? Was a bit vague but hoping it is not just sales talk but something beneficial!
  7. turbotoddl3r joined the community
  8. Nothing special with Castrol and it was 0W 20 FS IV that VW went to for 1.0 TSI,s with gpf,s for the WLTP. As it is dealers get Quantum from Fusch. If concerned about high heat stability go non Long Life so 5w 40 FS VW 502 00. As far as VW 504 00 /. 507 or VW 508 00 / 508 00 it matters not if from Comma, Asda, Tesco , Mobile, Miller etc etc just to the spec and approved.
  9. the Haynes manual for Fabia mk2 covered the 1.6 TDi 90 bhp CAYB engine in our 2012 Fabia Combi if that's any help.
  10. No they weren't missing. I removed them to help with the dry out, I just wanted to check where the vent/breather holes were. Apparently, they should have some but no one knows where they are 🤔
  11. @jonathan.tong Did you find the cause of the problem ?
  12. You will probably find the part number on lllparts as well. Alasdair
  13. Chances are the cluster specialist is in a nice heated room. When you said cold start they probably thought engine was cold. Not sure how easy it would be as a DIY as you said. Probably best let an expert do it. Alasdair
  14. My understanding is that Castrol were involved in the development of the relevant oils for the later turbocharged 1.0 litre engines. Apparently they developed a product that has a very low sulphated ash content to protect the exhaust particulate filter and the catalytic converter. Also the turbocharger needs to have an oil with very high temperature stability and shear resistance. This is to reduce carbonisation and varnish deposits and sludge build up. Other oil producers may or may not meet the Castrol Edge/ Volkswagen specs of VW 504/00, 507/00 and VW508/00, 509/00. As I am planning to keep the car for many years, I will buy the Castrol Edge Volkswagen spec oil from my local Tesco at £54 for 4 litres plus Tesco Club Card points. I cannot advise what Volkswagen main dealers practice is, but when I owned a one year old turbocharged Nissan eight years ago, I discovered that amongst other poor practices, my local Nissan main dealer was knowingly putting in the wrong spec oil from their bulk purchased contract drums with an oil supplier. This is why I always buy and supply my own parts, Castrol oils and filters ( Mann) to a locally trusted independent garage, or sometimes for the fun of it if the weather is nice, I do it myself. If I have my Škoda for 9 years at 12,000 miles per year, I expect I will change the oil twelve times. If I pay £30 over the odds each year for this period compared to buying a cheap oil, then I will have paid £360 over the odds overall compared to a cheap oil. However I will have done my best to keep the turbocharger and cat in good health. I would still do the same if I planned to part exchange the car after 3 years since it would only have cost me £120 over the odds in the shorter period for the peace of mind of using the correct oil and being able to prove it by receipts at trade in time.
  15. No. Use the two holes that are covered by the rubber access seals that you have already removed in the photo above. Unless they are missing? Thanks. AG Falco
  16. Hi. I recommend that you make an account to skoda-parts.com site and enter your cars VIN-number in there. Then you can search for the right parts that fit you car.
  17. @Lord_Moppy thanks for the info - that issue does sound very similar. Not sure why the instrument cluster specialist didn't pick this up (although problem had gone away - did think their diagnostic techniques would factor this in though as I told them its cold start problem). Thanks for the part numbers too, will find someone to replace them (assuming its not a DIY job). Trying to avoid going down the route of replacing the cluster and having to find someone to recode it. I'll report back when I get round to doing it. Thanks again - much appreciated.
  18. From memory, anything below 8 mOhms is ok.
  19. Resistance not a little high? For comparison i tested the same battery in a friends car but a year older. His read over 600 amps and a resistance of 3.7 millohms.
  20. I have used a smart charger a few times. Didn’t make any difference, offen says the battery is full after only 30-40 mins.
  21. 38% health while SOC at >95% is pretty low and tends to suggest your battery is suffering from hard sulphation - which will probably not be fully reversible. Internal res looks OK. A recovery charge programme may help, but approaching winter could well finish it off.
  22. Hi! Ive been working on the same type of project. Are you looking for contributors for the iOS side of things? Ive done some research and i have a working demo for iOS client.
  23. respi02 joined the community
  24. It would come up as one of the selection you get by pressing the rocker switch on end of wiper stalk, mpg, outside temp etc. I think.
  25. Don’t think I can but not 100 percent sure how would I even go about doing that
  26. Tried to move it, i think the front brakes are well bound up now. yay. in BEST news the gear shift was a bit stiff and then it went POP and now the gear lever wobbles around freely, it will select gears but something's popped off in an annoying way. You fix 7 things and another 10 go wrong. Maybe 28 year old cars aren't the best when all you have a drive way and not much free time. I might try and DRAG it up some ramps and have a crawl under it again.
  27. I can't seem to find it in the parts catalogue for your VIN, but I think you need to look anyway, may be able to see wiring going to it down the back of the sump, from engine bay if it's present. Can you display oil temperature on the cluster display?
  28. Expose those black/yellow wires from destination (MAF etc.) to the 14 way connector until something is visible. If you let me know the VIN, I can look up whether your car has the oil level/temp sensor. I'll message you to ask for it.
  29. Yigit42 joined the community
  30. I’ll have to check if I have a sensor in the sump because I’m not 100 percent sure but it’s bloody rattling it down so it’s making this 10x harder but thanks how would I go about checking for that short
