Past hour
MIB3 Preh – VCRN Showing 1234 on All FECs – What Could Be the Cause?
I’ve received two different explanations regarding this, and now I’m a bit confused about which one is correct. If seeing VCRN 1234 and an incorrect VIN is a sign of corruption, how can this be fixed? On the other hand, if this is completely normal on MIB3 units, I’m wondering why some MIB3 users can see their actual VIN and VCRN in this section, while others like me cannot. Could someone clarify which explanation is correct?
disherwood started following Skoda Fabia Mk2 (2007-2014)
Skoda Fabia 2010 sport 1.9 TDI BSW 5J
Hi First post to say hi Just finding my way around the above car and a 2016 Octavia combo
disherwood started following Skoda Fabia 2010 sport 1.9 TDI BSW 5J
If you haven’t installed any updates or patches on your MIB3 unit either, and yours also displays the same information, then I guess this is normal. What I’m curious about is how some MIB3 users are able to see their correct VIN and VCRN in this section, while others like us only see incorrect information such as VIN and VCRN 1234. Do you know why this happens or what makes the difference?
AutoSecurity joined the community
Today
Hola. Saludos
Just entered the Škoda world with a 2023 SE L Karoq. Previously drove a 16 year old VW Golf estate forever. Very different - like going from a Cessna to a 747! Lot to learn. Bob
Bo7b started following Hola. Saludos
Tyres and punctures
I'd strongly advise against leaving the screw in place, in some cases this can result in sudden failure if foreign objects in the tyre heat up excessively while driving. Remove it and check if there is leakage by using soapy water in the area. If there is leakage, there are 'self-vulcanising' repair plugs that can be inserted into the hole - much safer than leaving the screw in place.
Warrior193 started following Tyres and punctures
Bo7b joined the community
Yes, everything is still the same, and the VIN provided is incorrect. IMG20261118144240.heic
igrozan started following MIB3 Preh – VCRN Showing 1234 on All FECs – What Could Be the Cause?
Hello
Hi Hortygui, the local service also updated the software on mine (up to the 1989 version) but unfortunately issue is still there (as I wrote into the dedicated topic). I'm planning to detach the power and volume bar as described there, because it's always starting by itself and during the night it causes the discharging of the 12V battery.
Gearbox Emergency Mode
I believe that advice from 'Skoda Warranty' contravenes UK law.
Warrior193 started following Gearbox Emergency Mode
Tyres and punctures
I had to take my car to the garage recently and the technician pointed out that I had a screw embedded in my tyre. I was surprised because I hadn't had any puncture warning. Next stop therefore was my local tyre supplier who said that yes there was a screw there but the Pirelli tyres fitted on my Skoda from new are 'Seal Inside' technology so that the tyre creates a seal around any foreign object. So the good news is that I don't need to do anything about the screw other than monitor it. The bad news is that you cannot repair these tyres, only replace them if damaged. Had not come across this technology before but it seems to work.
Remote no longer folds the mirrors
Just to put this to bed I did the window up and down thing this morning and now the mirrors are playing ball with the remote. Thanks again.
- Any luck with intermittent limp mode fault?
How to update software on Bolero
Hi @fralik , @FnLn , @Everyone I have a 2019 Scala with almost identical infotainment specs (HW 033, SW 0463), although my part number is 654035871B. Did you eventually manage to update your Bolero firmware? If so, which version did you install, and has it been working reliably? I'm trying to resolve persistent Android Auto connectivity issues with my Samsung Galaxy S23+. Thanks in advance!
brretvert joined the community
Looking for help regarding rear door handle fitting process on Fabia MK1
I thought I'd add a follow-up question, based on something I've found. Obviously, you can buy new end caps for the handles but that alone wouldn't secure the bracket in (I would be very surprised if thats all that held it together). I did find this though: This is listed as a "de-lock barrel & cap". So, I am wondering if this is what I need/am currently missing? Or is this an aftermarket modification for a front door?
Strange sound
Anyway of getting a recording? Could be anything really. Not long ago one of my panels underneath the car came lose which caused a funky sound at slower speeds Might be worth hacking it up to make sure all the exhaust heat shields are secure
Software Update available for Bolero?
Hi @k00ks , @Everyone thanks for sharing your successful upgrade! My 2019 Scala has a Panasonic Bolero MIB3 (P/N 654035871B, HW 033, SW 0463). Two USB-C ports below my Scala's infotainment screen. I've already tried several cables, including the original Samsung cable, without success. I've had persistent Android Auto issues with my Samsung Galaxy S23+. Could you confirm your hardware version and whether your upgrade path to 1800 would work on my unit? Any advice would be greatly appreciated! Screenshots attached. Thanks!
Blank cluster / dash display and immobiliser killing engine - wiring help needed.
I’m very interested in this thread as I’m driving a Skoda fabia 2011 with the same issues. It is not starting after the panel has gone dead while driving, but starts every time after towing. This happened two times! Was it indeed fixing/changing the panel that was the solution? The mechanic is suggesting I change the panel cluster.
annaodh joined the community
Clarkson's Favourite - Tales of Vectra Ownership
Touch wood this has been pretty decent! Currently out of work so obviously not driving much, but when I do, it's spot on.
Common issues and what to look for
At 45,000 km a year (roughly 28,000 miles) a few things matter more than they would for an average buyer. Warranty. Skoda's standard warranty is 3 years, but the third year has a 60,000 mile cap, and it ends three years from first registration whatever the mileage. A 2022 car is at or past three years now and a 2023 one won't have long left, so I'd price it as an out of warranty car unless the dealer is adding cover, and ask exactly what that cover includes. Recalls and MOT history. Put the reg into GOV.UK's vehicle recall checker. It shows any safety recalls that haven't been done and gives you the MOT history. A 2022 car will have had its first MOT at three years, so you can see the mileage it was at and any advisories. Service history. Ask the dealer to print it from Skoda's own records rather than going by stamps in a book, and check the dates and mileages line up with how far it's been. DPF. Your mileage suits a diesel. The Mk4 handbook says the particle filter cleans itself when the engine is warm and you're doing at least 60 km/h at 2,000 rpm or more, and if the warning light hasn't gone out within 40 minutes the clean hasn't happened. Long runs will look after that. If the car you're looking at has a history of DPF warnings, it usually tells you the last owner did short trips.
SparePartAlam started following Common issues and what to look for
Servicing my serpentine/auxiliary belt, what brands should I get? (CGPA)
The pulley screwhead appears to be a 12-point, XZN type, not Torx (6-point). Try picking out all the loose bits of debris and using the correct tool. Not 100% sure on this, but a bit of cleaning out and a better photo may confirm. You may then be able to use that to release the belt tension (and so not need a new tensioner at all). I've never known of the existence of the Torx socket in the aluminium, always released via that pulley screw. It won't come undone with the amount of torque applied to relieve tension on belt, it may even be a left hand thread, I forget.
CarPlay crackling issue, software update fix?
@pab567 I've been having the same issue. Factory reset helps for the initial drive after the reset, but any connections after that and the crackling comes back. Weirdly the connection works fine for audio over bluetooth or USB connection, it's only through CarPlay that the crackling starts.
Kallum9 joined the community
How the MK4 VRs should have really looked?
Sure messaged you just wondering where you are?
- Bixenon Headlights auto-adjustment problem
Many thanks both, mine is a 2020 so I guess they have changed. @Binx1310 that's great, I'll give that link a look and see what turns up this time. Cheers
