After market alarm wiring colours and connection points
You can probably pick up a replacement alarm horn very cheaply on the secondhand market. Much easier to just change that than start from scratch. Car alarms are almost useless anyway, immobiliser does the work these days.
It did have; unfortunately it was unreliable and I suspect a previous owner/garage may have messed with it - siren looks battered. I just want to fit a new system for reliability.
Doesn't it already have a factory fitted alarm?
Aggiornamento (Update)
- 1.0 etec lack of power under acceleration and rattle
You don't have ECO mode selected by any chance do you?- Superb MK3 FL 206 KW Vibration under low rpm load
Ohhhh - so essentially vibration was disappearing when haldex disengaged - once you’re up and moving the car is basically front wheel drive. Makes a lot of sense. You’re right though it should be every 2 years and clean the gauze on the end of the pump as well as change the oil. It isn’t in the dealer workshop manual but all decent independents know to do it (although always worth asking just to check). Anyway, glad all is sorted!- 1.0 etec lack of power under acceleration and rattle
No warning lights or codes on garage’s diagnostic- After market alarm wiring colours and connection points
Hi All, I was wondering if any knowledgeable folks out there have any wiring information and connection locations to install an aftermarket car alarm? I have a 2012 Fabia 1.2 TSi. Many thanks, MMiniM started following After market alarm wiring colours and connection points- 1.0 etec lack of power under acceleration and rattle
No warning light/s?scotthugh3s started following 1.0 etec lack of power under acceleration and rattle- Wheel commonality?
Evolution13 started following Wheel commonality?- Wheel commonality?
I am considering a Mk4 Octavia (2025 onwards probably) and would prefer to have a spare wheel with it. I've had a 2016 Mk3 Octavia since new and used the spare wheel two of three times. I believe that the wheels are universal, i.e. that I could use the spare wheel in my current Mk3 on a Mk4. It's sold as a space saver but its a 16" 205 so plenty big enough. I believe I can just save buying one in the replacement car but would be good to confirm. Any thoughts? Thanks JonOctaviaJon started following Wheel commonality?- 1.0 etec lack of power under acceleration and rattle
2023 66000 miles serviced 3000 miles ago spark plugs done service before last rattle is coming from opposite side to gearbox .noise and loss of power under acceleration- 1.0 etec lack of power under acceleration and rattle
@Westie99 Best give some idea of things, Age and miles cars done, & when it was last serviced? What has it had done at the service, spark plugs changed? Did the clutch get replaced yet?Evolution13 started following 1.0 etec lack of power under acceleration and rattle- Which Octavia Scout would you choose?
Well, today has been an interesting day. Collected my, new to me, Scout and when I got home, about 14 miles, someone knocked on my front door to tell me there was a wet patch under the front of the car. Aaahhh. What the heck. OIL!! I cleaned and checked the dipstick and it was DRY!! Called the garage and it is getting taken back first thing tomorrow. Plus the Bolero panel has gone blank. Nothing at all. I'll do some digging.- 1.0 etec lack of power under acceleration and rattle
Hi there I have a Skoda Octavia Etec 1.0 and when you apply throttle to accelerate I get no response or when I do a horrid rattle it seems to be coming from the drivers side of the engine anyone had this or any idears thanks PaulWestie99 started following 1.0 etec lack of power under acceleration and rattle- My Skoda Superb 4x4 is in limp mode and my garage is unable to find a solution
Garage, which is skoda independent, has been exploring number of possible solutions. They have looked after car since I bought it. Car is still in one piece. I will get codes to share.- My Skoda Superb 4x4 is in limp mode and my garage is unable to find a solution
What have they actually done since getting the car? and is it dismantled? Time that you had the car moved to someone that knows a bit more than those sitting with your car. A good idea to get the fault codes that are logged.MrJeza joined the community- My Skoda Superb 4x4 is in limp mode and my garage is unable to find a solution
Hello - Thank you all for your support on this matter. I drive a 2015 Skoda Superb 4x4. 93k miles and it passed its MOT back in July after some required changes. The problem came in the following week when it suddenly lost all power, went into limp mode and has been in garage since July 22nd. The light came onto the dashboard saying something referring to engine management warning. Garage is having real problems diagnosing what it could be. I can try and get ODIS codes if that would be helpful. Thanks Mark- Rapid 1.2 tsi 81kw, Monte Carlo-power upgrade
mlroberts1971 joined the community- Rapid 1.2 tsi 81kw, Monte Carlo-power upgrade
- 2014 Skoda Octavia Mk3 2.0 TDI – Coolant Loss / Possible EGR Cooler and/or Head Gasket
- Button panel adding functions
What is the exact make, model and year of the car?- Custom CUPA downpipe
@jaychen What is the law or regulations in Australia (or is it Austria) on a Decat / DPF removal?- Buying a 2019 1.5 TSI SE L 5dr DSG
There is no REGULAR Servicing scheduled, advised or recommended for a DQ200 DSG which has 2 oils and a tiny filter in the MCU. This is not to say that you can not change both oils, but a main Dealership might not be prepared to, but a Service Desk person might advise it is done and will book it in, and then have no idea of the cost of Servicing a DQ200 DSG. Get done at an Automatic Gearbox specialist if getting done.- Custom CUPA downpipe
Are you UK based? How does your car pass the MOT? No way to pass diesel particulate test unless DPF is in place...
