  2. MikeTheThinker started following Wheel Caps
  3. Hmmm.....I'm sure I get a dash light showing a car skidding.......? I'll check tomorrow......
  4. paul1973 joined the community
  5. rabbituk replied to BlueDun's topic in Skoda Yeti
    Unless I'm missing something, aren't they supports for the exhaust rather than pipes?
  6. rabbituk started following What are they?
  7. I have the following wheel caps on my MY20 Mk3 Octavia. The chrome finish is prone to corroding and I am already on a second set. At £18 each, £72 for the set is a bit steep however, I will be getting my Geminis refurbished imminently and begrudge putting the old caps back on in their current state. Wings SKODASKODA Decorative centrepiece of the wheel SKODAEven your SKODA deserves to be elegant at all times. In case you ever loose it, SKODA Genuine Accessories offers you a decorative wheel centrepiece with new company badge, which is perfectly identicalThe following are the “latest style” wheel caps, available at a far more reasonable £20 a set. The MY20 Mk3 Octavia isn’t listed as a compatible vehicle however. Has anybody fitted these to a Mk3 Octavia or able to advise on how the finish holds up? I’ll probably give Wings a call to clarify the compatibility and report back. Wings SKODASKODA Decorative Wheel Caps - Latest StyleBy using the wide range of Škoda Genuine Accessories you can draw individual style of your car to perfection. Fit the already attractive light alloy wheels of your car with wheel center caps. Plastic
  8. CookieMonster87 started following Wheel Caps
  9. All sounds perfectly fine. The radio will go into standby when you take the key out. Yes, you can still turn it back on as it's on a permanent live, but while it's off, it's drawing next to nothing. I did the same retrofit to my mum's (now mine) Fabia II Combi in 2014, 12 years later, both the car and the RNS-315 have been fine with no flat battery issues. However, that said I finally removed it about two weeks ago and replaced it with an RCD 360. As map support for the RNS-315 ended years ago, I wanted more functional sat-nav in the car, so the CarPlay support of the 360 - and its factory look - has worked well. I just need someone with VCDS to hemp me code out the reversing camera setting on it.
  10. Hi all, Looking at purchasing a 2010 Superb 2.0l SE at 160,000miles. Engine history looks confidence inspiring but it has a few electrical issues that are either a common fix, or a big deal, and I'm trying to work out if its worth taking the project on. Drivers (right hand) door only opens using key manually in lock. All other central locking works ok. Rear o/s door does not open from in or out (deadlocked) Both front windows and mirrors temperamental. Looks like the cables through the drivers door have a had small solder/fix at some point. Is this likely a simple DIY job with a new wiring harness, or a quick fix for an auto electrician, or might something larger be at play here? ordering a full loom? I have read the many similar threads on here, but its a bit of mission trying to decipher them all, so any advice much appreciated.
  11. Today
  12. Hi all, Looking at purchasing a 2010 Superb 2.0l SE at 160,000miles. Engine history looks confidence inspiring but it has a few electrical issues that are either a common fix, or a big deal, and I'm trying to work out if its worth taking the project on. Drivers (right hand) door only opens using key manually in lock. All other central locking works ok. Rear o/s door does not open from in or out (deadlocked) Both front windows and mirrors temperamental. Looks like the cables through the drivers door have a had small solder/fix at some point. Is this likely a simple DIY job with a new wiring harness, or a quick fix for an auto electrician, or might something larger be at play here? ordering a full loom? I have read the many similar threads on here, but its a bit of mission trying to decipher them all, so any advice much appreciated.
  13. Hello, i recently purchased a RNS 315 with DAB and Bluetooth for a decent price to upgrade from the standard SWING radio that came with my 2011 fabia elegance. I have read about the CANBUS issues and how incompatibility would lead to a power draw issue that could lead to a flat battery, I scanned the CANBUS using VCDS and my version is 6N0 909 901 which i think is the older part and has issues with the RNS 315. When i install the RNS 315 it does seem to turn off when i take the key out of ignition, or atleast the screen turns off as i can still turn it on after using the power button, the MAXI-DOT screen does seem to recognise is as i can access navigation and phonebook tabs, the Bluetooth connection to my phone also turns off when the ignition key is taken out. I am not sure however if i can keep it installed as i fear a flat battery happening from a power draw problem as the radio does not recognise the car being off. I have purchased a "1.6- 2.0 CANBUS quadlock emulator" to hopefully test it out and prevent it from causing a flat battery hopefully. Has anyone had experience in this subject and can offer any information or help it would be appreciated.
  14. dashupgrade joined the community
  15. OldMahogany joined the community
  16. Amundsen maps need to be on an SD card that had the correct ID so it is (or looks like) a genuine Skoda card (or it appears you can hack the Amundsen to accept maps any card) - I use a 32GB genuine card I got off eBay. Amundsen music can be on any SD card - I use a 256GB SD card.
  17. I got sane answer from skoda so I thought that TSR to get work I need to do hardware changes East_ Yorkshire_Retrofits is TSR possible with my configuration.thx Gateway:hw/sw 5WA907530C/7078 A5 camera: MQB MFK 3.0 hw 5WA980653 sw 5WA980653A/3129 Dashboard: hw/sw 5E3920770/1400
  18. BlueDun replied to BlueDun's topic in Skoda Yeti
    I have spent a lot of time on this and made some progress. Firstly, for those who don't know (including my garage) the aircon drain tube exits into the transmission tunnel inside the drivers footwell, underneath the footrest ( same as Octavia (Screenshot_2019-05-22-21-35-34.jpg.9c10c83445932916cf97ab10ce1b31a2.jpg (1440×2560) Even though I had checked that water was draining from the scuttle under the windscreen, I took it all apart and found quite a bit! There was a build-up of debris (dense, like wet soil!) in front of the drain on the O/S, acting like a small dam. Just above there is a hole through the bulkhead, which should be sealed with a grommet - mine was missing. When I poured water onto the windscreen, which ran into the scuttle, it pooled in front of the 'dam' and whilst a lot went down the drain, quite a bit went through the hole into the drivers footwell just behind the accelerator pedal. I plugged the hole with a large amount of Bluetack, cover the whole area with Gaffer tapeand formed a really good seal - result no more leaking into car. I then removedthe mudflaps and prised the inner wheelarch covers away, to find a mass of 'compost' and dry leaves, mostly on O/S. Why this isn't part of the service schedule, say every 50k miles, I don't know. It would take a mechanic 10-15 minutes to do this and prevent a lot of problems. Having done all this andchecked the drain tube (shown in photo) was clear, I ran the car with aircon engaged and the drain tube end put in a bowl - water dripped in, so all seemed to be working, so reseated the tube end into the chassis hole and it then dripped out underneath the car. For the moment, I'm hoping it's all sorted. Placing towels etc. underneath the felt-type soundproofing under the carpets, to try to dry everything out. I'm now going for a beer and a lie down!!
  19. Please explain. I'm O-L-D. 😁😁 What is 'Patch Unit'? If using anything other than a Skoda original/coded SD card, is it possible to use a card larger than 32Gb? (I have several ......)
  20. On the M4, heading for Wales 🏴󠁧󠁢󠁷󠁬󠁳󠁿: Gaz
  21. Hi everyone, I recently picked up a 2014 Skoda Octavia MK3 Estate with the 1.6 CR TDI 110hp engine. Currently, my car only has rear parking sensors (PDC) installed. I’m trying to figure out if front parking sensors were available as a factory option on this specific year and trim level, or if front sensors were completely missing on certain specs. If front sensors were available from the factory, how can I go about sourcing the correct parts to retrofit them? If anyone has successfully added OEM or OEM-style front PDC to a pre-facelift MK3, could you please share links to the exact kits, wiring harnesses, or guides you used? Thanks in advance for any advice or links!
  22. BlueDun replied to BlueDun's topic in Skoda Yeti
    2014 Elegance 4wd, DCG, 2.0 diesel 170BHP - does this photo help?
  23. nikolakolev joined the community
  24. Patch Unit and you can use every SD Card
  25. If you have Amundsen MIB2, you will need to use an official SD card. It may pay to get a 32gb replacement card if your original one is only 16gb.
  26. @ndm Did the earth cable repair fix your problem?
  27. It was a very good car, particularly with the 2-series Volvo engine!
  28. I drove one of these in Canada a few years ago, but didn't play through all the available MFD options.
  29. Ha, that's going back a bit, I always wanted one of those, alot better looking than my 340 DL
  30. Hi, I have the same isue and same software with the same pixel 10 pro problem and same skoda scala from 2019, how did you solve android auto issue? The compatibilty list site https://compatibilitylist.skoda-auto.com/# isn't working, but i managed to find this site https://compatibilitylist.skoda-auto.com/?app&appLanguage=en-US and it says that iphone 12 is compatible, but latest pixel that is compatible is pixel 5 from 2020, but i wasn't able to find list of compatible devices for which software version does work with pixel 10 pro
  31. Bognor_Reg joined the community
  32. I guess this has been asked and answered dozens of times but I've trawled and found nothing recent. A few problems. I'm really struggling to update the Nav system. I only have access to a Mac, on OS 26 Tahoe. Can I use a new card that IS NOT a Skoda original, or must I stick with what I have? The Mac seems to insist on writing extra files to the SD card and messing up the install. Can I simply 'unhide' and delete these files, or is something else needed? Naturally this has all caught me out with 2 days to go before a big trip - when a Satnag would be very useful ........... The Skoda Update Portal seems to say any SDS card will do - but it won't ......... unless I've missed something fundamental. HELP!!
