  2. 1.5 tsi act, 144k on clock 130k ish as a taxi. Gearbox leak at 100k , vibration when act kicks in from about 100k. Oil on spark plug also from 100k
  3. Checklightcaser joined the community
  4. Today
  5. Thanks, I'm sure that is the case but I have been unlucky to buy a car in june that does have the dsg problem, intermittently I do acknowledge that some of the problem is due to short journeys and sitting in traffic. However I live in a village close to Cambridge, a densely populated city. I do go into Cambridge when necessary and also drive to the other end of the village, to other places 3-5 miles away. It does get longer journeys regularly where I drive at 50, 60, 70 mph! Correct me if I'm wrong but I thought new cars are built for any length or type of journey......
  6. A colleague is currently working extensively with the MIB2. In this case, it’s a Seat system, but it can be upgraded to any firmware version. Tire temperature monitoring has been added for the active tire pressure control system. The MIB2 has been patched, as has the firmware for controller 65.
  7. Yesterday
  8. Your car does not have TPM sensors in the wheels, the system is part of the ABS system as far as sensors at each wheels hubs. If you are resetting the TPMS correctly then, maybe the issue is a wheel bearing overheating and heating the wheel and increasing the tyres heat and increasing the tyres pressure. Only causing a warning on longer runs. So not a tyre pressure loss, less circumference of a tyre but increased circumference. Next time there is a warning try to stop someplace soon as and see if the wheel seems too hot. Or just try resetting the TPMS again.
  9. Welcome. Fluid as in something that is not just water? Any smell to it, or dare I ask any taste?
  10. It anyone wants or needs a small capacity petrol automatic and it is going to be less than 8 years old then a 1.0 tsi with a dq200 DSG is no more likely to have issues than any other manufacturers small petrol autos including cvts with engines with a gpf. Thankfully since 2018 the DQ200 DSG issues are much reduced, especially when matted to a 1.0 TSI rather than to a 1.5 tsi act.
  11. Hello, Hoping that someone out there has either come across this issue themselves or can kindly offer some considered advice. We own a 2023 Skoda Scala 1.0 litre which has covered 13,000 miles. The car was fitted from new with 'Nexen' branded tyres which still had at least 3.5 - 4mm of good tread. Three out of the four original tyres developed cracking on the outside shoulder of the tread which was brought to our attention during the car's first MOT (October 2026) Although not a MOT fail or even advisory we were asked just to keep an eye on the situation in case the cracking went deep enough to expose the steel fibres. In the interests of safety we decided to change the three 'cracked' tyres but kept the fourth tyre as it was clear of any similar cracking. On the first long journey after changing these tyres, the TPMS light came up on the dash even though all four tyre pressures had been checked no more than two days previously. Likewise the tyre has no obvious nail or similar object causing a slow puncture. I have again checked all four tyres and re-set the dashboard computer but any reasonably long journey keeps lighting up the TPMS on the same rear offside tyre. Bizarrely short trips around town don't cause any such issues. Hard to imagine it's a faulty pressure sensor given the proximity in time of when the three other tyres were changed. Many thanks.
  12. Peet joined the community
  13. No, I tend to swerve away from Grand Tour stuff.
  14. Good series that was. Have you seen Francis Bourgeois on the new Grand Tour series. He can drive fast alright.
  15. Budget one from AliExpress. Used it for about 8 months and it’s been perfect. Once it’s set up it connects by the time the car starts. Only thing I’ve noticed is a tiny delay in audio (e.g when changing tracks or if you’re watching a video when parked up) but this is the same as the wireless CarPlay built in on my wife’s kodiaq so it’s not down to this adaptor. I just found this on AliExpress: https://a.aliexpress.com/_EydTvyw
  16. I concluded that PhonoStar don't support mib3 icons in Australia when it last came up before and I looked. The question is what icons do the units have on them in Australia. The DIY firmware update that people do will wipe the icon storage... pretty sure, so buying a secondhand car could be pproblematic. Probably something to check.
  17. Hi, 2012 Superb 2 Estate - 140cr DSG - 70,000 miles As title really - both rear wheels showed faults during a routine scan. Also ABS Control Module fault. No warning light on display. I had both rear tyres checked for air loss a little while ago and new valves were fitted - so they had the wheels off. Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb Part No: 1K0 909 144 P Component: EPS_ZFLS Kl. 000 3305 Revision: 00H22000 Shop #: WSC 18598 000 1048576 VCID: 372B28B10349808216A-8062 1 Fault Found: 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 219 Mileage: 111296 km Time Indication: 0 Date: 2021.04.18. Time: 10:56:40 Freeze Frame: Voltage: 14.00 V DU Temperature: 31.0 C RPM: 1242 /min Speed: 4.0 km/h Speed: 4.0 km/h Count: 0 Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V2.clb Part No SW: 1K0 907 379 BH HW: 1K0 907 379 BH Component: ESP MK60EC1 H31 0121 Revision: 00H31001 Coding: 863D601609260001610F06E490210082300000 Shop #: WSC 33361 790 00078 VCID: 79AFEE8979DD56F2A0E-802C 2 Faults Found: 00287 - ABS Wheel Speed Sensor; Rear Right (G44) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 219 Mileage: 111296 km Time Indication: 0 Date: 2021.04.18. Time: 10:56:40 Freeze Frame: Count: 0 Count: 0 Count: 4608 Count: 83 Count: 50689 Count: 0 Count: 0 Count: 0 00290 - ABS Wheel Speed Sensor; Rear Left (G46) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 219 Mileage: 111296 km Time Indication: 0 Date: 2021.04.18. Time: 10:56:40 Freeze Frame: Count: 0 Count: 0 Count: 4608 Count: 67 Count: 50689 Count: 0 Count: 0 Count: 0 Coincidence? What should I look for as a 1st step? Thanks, Fats
  18. Thanks all. It is just the picture. It seems to be doing that When assembled it was solid. Kwik fit last to touch it during a wheel alignment. Could the ECP outer track rod not actually be the correct fit? I suspect the threads are indeed damaged internally. I'm going to change them both. But the driver's side which was also changed at the same time, identical brands, is fine. I watched the tech tighten up the lock nut. I even wire brushed the threads and gt85 before presenting for wheel alignment. Tech wasn't struggling at all if I remember (1.5 years ago). Passed 2 MOT (1 was 2 weeks after alignment and other 1 year later). If it had play they would have noticed this. The outer, inner rods don't want to pull apart (yet) but not safe I agree. Just odd it has taken so long to manifest. Is it the lock nut tightened up on dirt (it was all clean at time). Could bad roads cause this? I've changed gearbox mount and top engine mount in this time. Gearbox mount was causing an odd noise on full lock in reverse. Could this damage the joint between the steering rods? I'm going to replace the coil spring, strut shock and drop links and inner outer track rod. Ball joints were done 1.5years ago.
  19. As title states. Trying to source a good quality adapter for only iPhone use. I have tried the AA wireless two+ to allow wireless CarPlay using an iPhone and it was a poor experience for music playback. Nothing would fix the random stutter so it’s been sent back. Looking for the best recommendation or even to start a list, from those that have one that works flawlessly. No need for android compatibility or multiple phones. Recommendations so far are for ottocast and carlinkit, but would like to hear personal experience from anyone who uses one daily without hassle please.
  20. Thanks Bazz that's very useful and very kind!
  21. I have a 2015 Scout with the same problem. I think if I took out the diff, prop and shafts, but leave the CV joints in to clamp the bearings, then it should be ok to run 2WD. My haldex controller is dead as well as the noisy bearings, so I can’t see how it would throw a load of errors that it isn’t already entitled to throw. If traction control tries to run the rear differential then it won’t get a response. If I get the traction control excited - eg if it goes a bit lighter over a hump back bridge, it cuts the power for a second then calms down and carries on.
  22. I've converted the file to a pdf Skoda Fabia Mk4 1.pdf
  23. johnny78 joined the community
  24. Yes, sorry the attachment isn't there. Link is : https://www.carchecker.pro/reports/skoda_fabia_mk4_1.0_tsi.html I'll see if I can post the body of the article again. It's a long running nightmare with with our Fabia 4 mc. You just know that the dealers think older customers must be mentally challenged when they continually raise issues that they can't identify with their equipment. At least the article provides some expert evidence. Maybe, even persuade the dealer into helping you out of your pedicament but I wouldn't hold your breath on that one. Hopefully your model comes into this particular category. VAG group and Skoda are in big financial difficulties now. Chinese cars are building their share of the market very quickly.
  25. You are averaging ~ 82 miles/day and 27 stop/starts, seems a extraordinary number of stop/starts, you must spend a lot of hours in the car. Ordinarily, that sort of mileage should have no problem keeping the battery at 85% SOC but couldn't see the SOC increasing by 10% in a short drive, my alternator only seems to charge at 1 or 2 amps after a initial burst of 15/20A for 20 seconds or so after starting, I put a 5A smart charger on my 2026 Polo a few months ago and even though the SOC was down around 70%, the measured charging rate fell to 0.15A so would need a mighty long night to get any sort of charge into the battery, it might charge initially at ~ 1A or so but as soon as the voltage rises to 14.4V or so it immediately sees the battery as being "full" and reduces the voltage to ~ 12.8V + 0.1shA, a CTEK might do better??.
  26. Hello, yes it's free.
  27. jc_whiskey joined the community
  28. Are these updates free.
  29. Rebuilding. Don’t know the cost but he’s not greedy.
  30. I use the obd11. My battery charge status on average hovers between 68-73%. It never or rarely hits 80%. I’m not sure them readings are entirely accurate because i have seen it jump from 66% to 76% after only a very short drive. Also the percentage rapidly drops if you walk by the car a few times when the key is in your pocket. If your battery drops to 60% the start stop deactivates. Battery resistance has significantly increased. When new it was 3-4 millohms. These days it averages between 5-6 milliohms. Battery usable charge averages between 36-45ah depending on the battery’s mood and temperature. At the moment battery aging charging and battery aging performance is at 68% . That number varies too. Yesterday it dropped to 61%.
  31. Thanks that's great, the source is Carchecker pro?
  32. sonay joined the community
  33. No joy as yet 🤷🏻‍♂️ A couple of ideas to try but they are longshots. Is your guy in Wales rebuilding yours or replacing it? Without meaning to sound rude, how much is he charging?
