  2. Hi First post to say hi Just finding my way around the above car and a 2016 Octavia combo
  3. AutoSecurity joined the community
  4. Just entered the Škoda world with a 2023 SE L Karoq. Previously drove a 16 year old VW Golf estate forever. Very different - like going from a Cessna to a 747! Lot to learn. Bob
  5. Bo7b started following Hola. Saludos
  6. I'd strongly advise against leaving the screw in place, in some cases this can result in sudden failure if foreign objects in the tyre heat up excessively while driving. Remove it and check if there is leakage by using soapy water in the area. If there is leakage, there are 'self-vulcanising' repair plugs that can be inserted into the hole - much safer than leaving the screw in place.
  7. Bo7b joined the community
  8. Yes, everything is still the same, and the VIN provided is incorrect. IMG20261118144240.heic
  9. meee replied to meee's topic in Hellos and Goodbyes
    Hi Hortygui, the local service also updated the software on mine (up to the 1989 version) but unfortunately issue is still there (as I wrote into the dedicated topic). I'm planning to detach the power and volume bar as described there, because it's always starting by itself and during the night it causes the discharging of the 12V battery.
  10. Today
  11. I believe that advice from 'Skoda Warranty' contravenes UK law.
  12. I had to take my car to the garage recently and the technician pointed out that I had a screw embedded in my tyre. I was surprised because I hadn't had any puncture warning. Next stop therefore was my local tyre supplier who said that yes there was a screw there but the Pirelli tyres fitted on my Skoda from new are 'Seal Inside' technology so that the tyre creates a seal around any foreign object. So the good news is that I don't need to do anything about the screw other than monitor it. The bad news is that you cannot repair these tyres, only replace them if damaged. Had not come across this technology before but it seems to work.
  13. Just to put this to bed I did the window up and down thing this morning and now the mirrors are playing ball with the remote. Thanks again.
  14. Thanks, I'll look into it. DRW
  15. Hi @fralik , @FnLn , @Everyone I have a 2019 Scala with almost identical infotainment specs (HW 033, SW 0463), although my part number is 654035871B. Did you eventually manage to update your Bolero firmware? If so, which version did you install, and has it been working reliably? I'm trying to resolve persistent Android Auto connectivity issues with my Samsung Galaxy S23+. Thanks in advance!
  16. brretvert joined the community
  17. I thought I'd add a follow-up question, based on something I've found. Obviously, you can buy new end caps for the handles but that alone wouldn't secure the bracket in (I would be very surprised if thats all that held it together). I did find this though: This is listed as a "de-lock barrel & cap". So, I am wondering if this is what I need/am currently missing? Or is this an aftermarket modification for a front door?
  18. Anyway of getting a recording? Could be anything really. Not long ago one of my panels underneath the car came lose which caused a funky sound at slower speeds Might be worth hacking it up to make sure all the exhaust heat shields are secure
  19. Hi @k00ks , @Everyone thanks for sharing your successful upgrade! My 2019 Scala has a Panasonic Bolero MIB3 (P/N 654035871B, HW 033, SW 0463). Two USB-C ports below my Scala's infotainment screen. I've already tried several cables, including the original Samsung cable, without success. I've had persistent Android Auto issues with my Samsung Galaxy S23+. Could you confirm your hardware version and whether your upgrade path to 1800 would work on my unit? Any advice would be greatly appreciated! Screenshots attached. Thanks!
  20. I’m very interested in this thread as I’m driving a Skoda fabia 2011 with the same issues. It is not starting after the panel has gone dead while driving, but starts every time after towing. This happened two times! Was it indeed fixing/changing the panel that was the solution? The mechanic is suggesting I change the panel cluster.
  21. annaodh joined the community
  22. Touch wood this has been pretty decent! Currently out of work so obviously not driving much, but when I do, it's spot on.
  23. At 45,000 km a year (roughly 28,000 miles) a few things matter more than they would for an average buyer. Warranty. Skoda's standard warranty is 3 years, but the third year has a 60,000 mile cap, and it ends three years from first registration whatever the mileage. A 2022 car is at or past three years now and a 2023 one won't have long left, so I'd price it as an out of warranty car unless the dealer is adding cover, and ask exactly what that cover includes. Recalls and MOT history. Put the reg into GOV.UK's vehicle recall checker. It shows any safety recalls that haven't been done and gives you the MOT history. A 2022 car will have had its first MOT at three years, so you can see the mileage it was at and any advisories. Service history. Ask the dealer to print it from Skoda's own records rather than going by stamps in a book, and check the dates and mileages line up with how far it's been. DPF. Your mileage suits a diesel. The Mk4 handbook says the particle filter cleans itself when the engine is warm and you're doing at least 60 km/h at 2,000 rpm or more, and if the warning light hasn't gone out within 40 minutes the clean hasn't happened. Long runs will look after that. If the car you're looking at has a history of DPF warnings, it usually tells you the last owner did short trips.
  24. The pulley screwhead appears to be a 12-point, XZN type, not Torx (6-point). Try picking out all the loose bits of debris and using the correct tool. Not 100% sure on this, but a bit of cleaning out and a better photo may confirm. You may then be able to use that to release the belt tension (and so not need a new tensioner at all). I've never known of the existence of the Torx socket in the aluminium, always released via that pulley screw. It won't come undone with the amount of torque applied to relieve tension on belt, it may even be a left hand thread, I forget.
  25. This link is to the forum topic that discussed DRW's 2020 Kamiq's DSG-gearbox problem. https://www.briskoda.net/forums/topic/539758-gearbox-emergency-mode/
  26. @pab567 I've been having the same issue. Factory reset helps for the initial drive after the reset, but any connections after that and the crackling comes back. Weirdly the connection works fine for audio over bluetooth or USB connection, it's only through CarPlay that the crackling starts.
  27. Kallum9 joined the community
  28. Sure messaged you just wondering where you are?
  29. I’ll come back to this topic in the next week, after i will bring my OBDeleven from Poland....
  30. Many thanks both, mine is a 2020 so I guess they have changed. @Binx1310 that's great, I'll give that link a look and see what turns up this time. Cheers
  31. Create a backup of the headlight range control adaptation in control unit 09.
  32. I’m afraid I have to correct you. It is normal for "1234..." to appear on the MIB3—even on completely legal, official units. Furthermore, the VIN is not contained within that number; rather, the VIN is included—along with a unique identifier (VCRN)—within the FeC/SWaP code. VW intentionally designed the display in the service menu this way. All my MIB3 devices at home show the same display with the same date... The VCRN is registered into the unit at the factory—essentially the radio's unique ID. Every control unit that operates using FeC/SWaP has one.
  33. Hello everyone! I've noticed that my serpentine belt has got a mark on the flat side of it, (crap blurry picture attached) which i suspect is the cause of my squeaking I hear when its wet or humid outside but I have also noticed that the tensioners sockets are stripped (and the cover is missing, somehow), so I'm going to have a new tensioner as well What brands should I get/avoid? Currently planning on buying through skoda-parks.com I was going to buy an INA tensioner because it being OEM, but I've heard the sockets being made from mild aluminium makes them easy to strip, so I was wondering if i should get the SKF one instead? Ive heard good things about it but of course I don't yet know how it differs when it comes to installing it and getting the belt on properly (this will be the first time I've serviced a belt but i have seen a mechanic walking through with the OEM tensioner) Similar situation with the belt, I was initially going to go with the Gates one as I seen a lot of people swear by them but I've seen a few comments in recent years saying that they have gone down the plug hole with their quality I can also buy the Contitech one, which from what I understand is made by Continental, or I could get the Skoda one but its also double or quadruple the price of the other two If you have any experience with these brands or products I'd love to hear your opinions/experience and recommendations Thanks for your time!
