  2. samitolo joined the community
  3. I always take a trial-and-error approach šŸ˜…
  4. Yeah my guess was the same. Saw eu and china had diffrent hardwer versions. From my understanding atleast the indexes after the serial numbers where later "revisions". Yes i have the most cable and i have my nav maps showing in the cluster. How risky is the update to the newer softwere and where can i find a link for it. Thanks!
  5. Mine does the 12v protection from time to time. I have a ctek charger, a CS Free, and in winter, chuck it on the battery about once a week. As the ctek has its own battery built in and will bring the 12v up enough to allow the car to start in a few moments, I carry it in the car just in case at all times. However, I think that warning also comes up if you access the car remotely too often in a given period. Like about 6 times in 12 hours or something.Because I use Octopus to schedule, I sometimes get a schedule with an hour here, a gap, half an hour, a gap, another hour... Those kind of non-contiguous schedules sometimes seem to kick in the warning and then charging stops or fails. But you just get in, move the car an inch, get out, it resets the warning and Octopus will charge it again. Not much good at 3am but still. Every time I used the ctek the 12v is either fine or within an hour or so of being fine. Car is also a coupe, 25 months old. I don't think Skoda offer the Optimised Battery Use setting in the app, that's a VW thing I think. I think the Enyaq charges the 12v when driving ok, but I can't find a definitive thing saying it will charge the 12v when you plug the car in and just recharging. I can find things like "it's supposed to" or "probably in some circumstances" but not an official yes that's how it works. Maybe someone else has definite info on that. I just assume mine doesn't, hence using the ctek just in case
  6. First Screen With positiv pwm = Seat 2nd Screen with negativ pwm = SKODA
  7. The difference is that with DCC, the sensors are processed by the DCC control unit, whereas otherwise, they are handled by the BCM (Body Control Module). The system stores information regarding which axle is installed and the number of sensors—specifically two in the case of all-wheel-drive vehicles. The regulation mechanism functions on the same principle, regardless of whether DCC is present or not. The basic setting (calibration) for DCC is distinct from that of the headlights. The vehicle should be positioned normally on a level surface and left unloaded before performing the basic setting.
  8. Today
  9. A thought though. I wonder if it might be irrelevant anyway. May give you some info of relevant position but with regards to the precise number, @JR RS has me thinking. does the adaptation without dcc have to be done in the same way. E.g jacked up with wheels hanging at full extent to find a max extension and then all compression of suspension is relative to that figure. Edit: just had a look at the manual and it only mentions basic settings for dcc. Will let you know what my numbers are when I get a chance to look.
  10. Guys, thanks for the reponse. Binx1310, awaiting your data!
  11. Also do you have G13 coolant and does it read in your expansion bottle "Mit silikat"?
  12. Hi. Are you sure the cause is the heater matrix and not the climatronics passenger side flapmotor that controls the hot and cold airflow. In LHD vehicles its V159 i think. These flapmotors are known to fail when they age, the potentiometer inside fails or the plastic stop breaks so that the motor loses its position signal. Have you read DTCs?
  13. emiilsd joined the community
  14. JPenedo joined the community
  15. From China, the VC šŸ˜‰... unfortunately, you bought an older software version; the Sportline visuals, etc., only arrived with "Index A" what i know... It is possible to perform an update via an SD card through the MIB2 unit—provided you have retrofitted the MOST connection—but I cannot offer any guarantees regarding this.
  16. Cairus started following S3's Virtual Cockpit
  17. I definitely did not intend to offend anyone. If my words came across the wrong way—which can certainly happen, given that English is not my native language—I apologize. My only point was that the discussion should remain focused on the Superb; if someone were to read this thread days, weeks, or years later and encounter talk about a VW T6.1—or any other vehicle with a completely different system architecture—it would simply be confusing. I am certainly not questioning anyone’s competence; everyone—absolutely everyone—in this forum contributes something of value. I simply felt a personal need to clarify this, and as far as I am concerned, this matter is now settled.
  18. Ross2001 joined the community
  19. No, the dataset is essentially an extension of the firmware. It is loaded onto a control unit and—to put it simply—contains vehicle-specific data and the functions that the control unit is supposed to execute. Tools like ODIS-E or VCP can be used to flash these datasets. There are also some handy tools that allow you to load the OEM dataset, which then provides you with a user-friendly interface for making adjustments; you can then save your configuration and flash it onto the unit.
  20. Yesterday
  21. AlexLiv joined the community
  22. A diesel vehicles fan can continue to run if the vehicle was mid-regen when stopped
  23. I’m sure everyone can take a mo to calm down. It’s easy to read things in the wrong tone. Plenty of knowledge to be shared which makes the forum greater. Cairus has a wealth of knowledge particular to these models. You clearly have lots of knowledge too but seems more general. Both have their place but I’m sure nothing was intended to be a p***ing contest šŸ‘šŸ¼
  24. Thank You for the reply and the link, and Your original post, very helpful! The mirror in the link is the same mirror I have sourced, I was left with the ceramic circle after removing the factory mirror so I have mounted just below as I managed to get a working sensor to mount in the middle of the retaining bracket. All working fine, Thanks again
  25. I changed my NS front spring today and yes the 21 yo top mount was goosed , good job I bought one then I had a few issues getting the shock off but a lot more hassle trying to fit it back in the hub. I dont suppose if anyone knows if the tab that slots into the hub that the pinch bolt goes through is supposed to be elongated and have a 90 deg hook on the bottom? I noticed this as i was changing the spring and tried to bend it backin line with the tab but it seemed pre-formed so I ended up leaving it. I,m not sure if the shock is sitting slightly higher in the hub then it should and its got me paranoid now after finishing the job in the dark tonight šŸ…°ļø I'll compare it with the other side in the morning if it aint pishing it down then back to the MOT station on Monday ,good article this one thanks guys !
  26. Id be more inclined to go on mileage, and if its one you want to keep for a while, do more often than 15000. I do the oil in mine every 7,500 because oil is actually pretty cheap. 1.4 TSI engine I get whatever VW502 is on special and change it more often. If the 504 is on special I get that but my understanding is the 504 only gives extended service intervals so not worth it in my case
  27. Yeah, I think the main work is the refill procedure and pipe connections. I think the actual matrix is fairly easy to access
  28. Nice. Im keen I wonder how detailed it is. Keen to hear the feedback. I got a Haynes and a Gregory's in the past. Gregory's was way superior. Just better graphics and explanations. More detail.
  29. Just after sunset this evening...........
  30. I agree with 26DIPP. For the sake of a few pounds I will have the oil and oil filter changed at 9,000 miles to preserve the life of the engine and turbo, as I have done with all my cars that I tend to keep for 9 years or so. However I also have a look and smell the oil on the dipstick as well at about 6,000 miles to see how dark and smelly it is! As for filters, the air filter gets looked at every year and replaced before it gets really dirty, likewise the cabin filters. Basically I don’t trust manufacturers schedules any more. Also I don’t trust cheap chain car servicers who use inferior generic oil filters not fit for purpose. My local reliable independent has got used to me supplying him the desired oil, correct filters, sump washer for him to fit during the past 30 years He is happy as he says he wastes a lot of time arguing with Eurobits factors and FSG plc that they have sent him the incorrect poor quality part and service item on the van. Unlike others I believe the 0-20w Castrol Edge LL IV spec meeting Volkswagen requirements is better for these Turbocharged cars in UK. I will revise that opinion as Global warming takes hold and my turbocharger catches fire!
  31. The bosch md1 [ tdi ] ecu's in vag cars from around 2020 are locked from the factory and it has taken until now for someone to crack them. ECU needs to be removed and sent away for unlocking, then a remap can be done in the normal way. There's only 2 places doing the unlocking at the moment but that's likely to change in the future. DC Remapping UKNew ECUs We Can Unlock | DC Remapping UKThe locked, encrypted ECUs (Bosch MG1 / MD1) we now bench-unlock in-house - across BMW, Porsche, VAG, Land Rover, Ford and more, with the models each covers.
  32. Yes! Best post ever! Just ordered mine!
  33. henrypolack84 joined the community
  34. To be honest the biggest faff with heater matrix is draining the coolant and then if you flushed it, disconnecting pipes, might as well bite the bullet and replace, not sure flushing would be that effective (I replaced mine). Lots of blocked matrix threads going on!
  35. I had this on mine, but I believe the tell tail signs it's the matrix being blocked, is that the passenger side is warm and driver side hot. It's pretty reliable how it faults, not on and off. Outside air temp has an effect though, the blocked matrix really shows itself on cold days.
