Skoda Octavia 1.6 green line Thursday,08,October,2026,11:09:52:63202
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 26.9.0.3 (x64) HEX-V2 CB: 0.4713.5
Data version: 20260828 DS378.0
www.Ross-Tech.com
VIN: TMBKG7NE5G0187442 License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBKG7NE5G0187442 Mileage: 170790km-106123miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-DBKA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 CA HW: 04L 907 309 R
Component: R4 1,6L EDC H22 1662
Revision: B5H22--- CVN: 187943B7
Coding: 01190032032501094000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM16TDI01104L906026CA 002004
ROD: EV_ECM16TDI01104L906026CA_002_AU37.rod
VCID: 6B84248D430A9E72222-803E
VINID: 91D49B5C779515700120710408C448C5A2
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 60196000000796
Coding: 1C078A9124280973007B060441C5243851249000608224F20043F072C002
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033
ROD: EV_Brake1UDSContiMK100ESP_034_VW37.rod
VCID: 4BC4840D234A7E72422-801E
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5E0 907 044 Q HW: 5E0 907 044 Q
Component: Climatronic H04 1002
Revision: 00001K07
Coding: 02110104002100011005000000141000
ASAM Dataset: EV_ACClimaBHBVW37X 004131
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 3334FCED5BBA06B22A2-8066
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 086 AH HW: 5Q0 937 086 AH
Component: BCM PQ37BOSCH 028 0162
Revision: -------- Serial number: 865823011601CV Dataset Number: 5E0063t____ 0075
Coding: 0F000842434702FF07A04082B10406280000000000000000000000000000
Shop #: WSC 73430 790 12345
ASAM Dataset: EV_BodyContrModul1UDSBosc 015002
ROD: EV_BCMBOSCH_015.rod
VCID: 005E63215A8C6D2AE70-8054
Wiper motor control module:
Subsystem 1 - Part No SW: 5E2 955 119 HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 151207 041 0570
Serial number: 160110074103
Coding: 064DFD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S5Y16M12D22H06M57S19
Coding: 07805D
Anti-theft alarm system sensor:
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY153150UYV
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000034358257
Humidity sensor: interior:
1 Fault Found:
929796 - Light Switch
U110B 00 [00001001] - No Communcations
[Lichtschalterkeine Kommunikation]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 170790 km
Date: 2026.10.08
Time: 10:58:38
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: Not operated
Position lamps: Not operated
Automatic high beam assist: Not operated
Low beams: operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 13.9 V
Outside temperature: 12.0 C
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39491533702715 Dataset Number: 5E0039t____ 0016
Coding: 0131061041
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_003_VW37.rod
VCID: 47CCB83D3F229A1266A-8012
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 AS HW: 3Q0 959 655 AS
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SQP0VHUG4 Dataset Number: 5E0003t____ 0057
Coding: 98CCC000000000005C5400CC008800000065
Shop #: WSC 73430 790 00000
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 0F7C501D17D202526EA-805A
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 454 002 107 15
Component: SideSensor_Df 008 0887
Serial number: 3576U000000C2455D51C
Coding: 2D2D2D
Crash sensor for side airbag: passenger side:
Subsystem 2 - Part No SW: ----------- HW: 454 001 312 15
Component: SideSensor_Pf 008 0887
Serial number: 3586U000000196554815
Coding: 2D2D2D
Crash sensor for side airbag: driver side rear:
Subsystem 3 - Part No SW: ----------- HW: 454 802 012 15
Component: SideSensor_Dr 301 0148
Serial number: 3516R877177090000002
Coding: 2D2D2D
Crash sensor for side airbag: passenger side rear:
Subsystem 4 - Part No SW: ----------- HW: 454 802 312 15
Component: SideSensor_Pr 301 0148
Serial number: 3526R23007709000000S
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 454 801 612 15
Component: FrontSensor_D 304 0149
Serial number: 3556V10695109000000
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 M HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160131400703
Coding: 1400
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 3C26D7D176E4C9CAFB8-8068
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5E0 920 951 B HW: 5E0 920 951 B
Component: KOMBI 325 6422
Coding: 27A50A002190A60001087A001000000000000000
Shop #: WSC 73430 031 12345
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 261215B99868631ABDC-8072
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AH HW: 5Q0 907 530 E
Component: GW MQB Mid 127 1244
Revision: -------- Serial number: 0004443985 Dataset Number: 3V0067t____ 0015
Coding: 030100045F087300EB000248080F00010001050000000000000000000000
GVL: 01543C0000000000400C00000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewLear 013020
ROD: EV_GatewLear_013_VW37.rod
VCID: 77AC08FD0F422A92D6A-8022
Generator:
Multi-function steering wheel control module:
Subsystem 2 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000D2568210116
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185704001601191428
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-DCD-V1.clb
Part No SW: 5Q4 959 393 E HW: 5Q4 959 393 B
Component: TSG FS 010 0031
Serial number: 0000182640288 Dataset Number: 5E0222t____ 0018
Coding: 005C0020C001040000001100
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
VCID: 45D0B235052E8802946-8010
Left rear door control module:
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000008643855
Coding: 1D0200
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1063
Dataset Number: 5E0074t____ 0018
Coding: 8303
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_012_VW37.rod
VCID: 44D6AF310E14B10A838-8010
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 392 E HW: 5Q4 959 392 B
Component: TSG BFS 010 0031
Serial number: 0000184262476 Dataset Number: 5E0157t____ 0018
Coding: 005400208401040000001100
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
Right rear door control module:
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000008675541
Coding: 050200
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 874 A HW: 5Q0 035 874 A
Component: MU-S-ND-ER H24 0253
Serial number: SKZAZ2S8210918 Dataset Number: V03935238MV 0001
Coding: 23730201FF00000011111201008800006F02048601200100C6
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 323AF9E9A4A00FBA214-8066
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5E0 919 605 J HW: 5E0 919 605 J
Component: ABT_Std-2_Nav H41 1031
Serial number: SKZ8Z9SBT01LGT
Data carrier:
Subsystem 2 - Part No SW: V03 959 823 CB HW: -----------
Component: ECE DL2 2026 --- 2510
Serial number: --------------------
End----------(Elapsed Time: 01:47, VBatt start/end: 14.4V/14.4V)-----------
-------------------------------1 Fault Found-------------------------------
