1.0l TSI SE suitable for private hire use ?
My old 1.9tdi and newer 1.6tdi are 105hp which is less than the 1.0tsi. Torque on my diesels is 250NM which is higher than the 200NM of the 1.0tsi but reckon as long as your not towing you wouldn't notice. Alasdair
Jason_E started following Skoda Superb Mk2 (2008-2015)
vitaliycom joined the community
Very wet carpets
Thanks for the response. The car doesn't have a sunroof, so we can rule that out. Need to try to lift/remove carpets to get the underlay out, which holds water like a sponge apparently. Haven't worked out how to do that yet.
the truth about electric cars
Superb still has a good sized tank ie 66 litres, and has not suffered so much of the trend of smaller fuel tanks on B and C segment cars. Cars was modified with non standard tyres ie more energy efficient ones, had the Greenline smooth underfloor, something EVs have as fairly standard now and who knows what else. Probably cooled fuel to reduce volume ie put in a fridge before the run and the absolutely brimmed like I would do when I use to get my Tescos 5p /8p off tokens. Still and impressive mileage and especially as set on roads and not track like when an RAF team near doubled the miles travelled compared to WLTP ie over 480 miles compared to 250 miles WLTP but that was done at Thruxton and average speed was 20 mph not not really practical and therefore must have taken nearly 2 days, must have been a lot of fun, not. Couple of other points. Diesel is 2.25 Euros per litre so fuel tank would cost about 150 Euros to fill ie about £130 so not cheap compared to ICE home or destination charging costs or even some public charging costs at the right times. That 66 litres of diesel 2.5 GJ of energy and burning it would produced 177 kgs of CO2 being added to the Earth's atmosphere. Energy per mile would be 1.42 MJ per mile, normal driving and normal car would be around 3 MJ per mile. An EV would typically average about 0.9 MJ per mile so way more efficient than even the most extreme effort to be efficient. EVs are at least twice as efficient as even the most extreme ICE effort, on average more like 3 to 4 time more efficient. Running costs similarly so.
MikeTheThinker started following Optimal place for a subwoofer amp remote wire location
Very wet carpets
Hi, welcome to the forum. There are lots of posts over the years about water ingress so worth doing some searches. And if you resolve the problem it is always helpful to post what you found and how you cured it as it may help others. I'm not an expert so what follows is what I've picked up from other members over the years, If you have a sun roof don't rule that out. There are a lot of posts on this forum and elsewhere about the chassis that holds the sun roof cracking and that allows water to drain into the car - we did have extremely heavy rain recently. There are suggestions of d-i-y fixes using Capt Tolley's sealant but with variable success and no indication of whether it gives a permanent fix or just a temporary breathing space. On older cars the consensus was moving to sealing the sunroof so it can't open but at least gives a waterproof glass lid that lets the sun in. If you don't have a sunroof you can breathe a sigh of relief as replacements are wallet straining. From what you describe I'd be thinking along your lines - someone's interfered with the aircon and immediately after that you have a problem. Bit gross I know but did you sniff/taste to see whether the liquid in the well was likely to be water or something containing chemical compounds? It might have helped reduce down the options of what the problem could be. As you've been able to partially dry the carpets unfortunately that's not an option now but if the water keeps coming in worth thinking about. On the cars with sunroofs there are four drain tubes that run down the corners of the car. I'm not sure if they are there on cars without sunroofs but someone may be able to help with that. There have in the past been reports of these getting blocked and water getting into the car. From memory a common suggestion was to carefully thread a long thin cable from the accessible outlet holes at the bottom up the tubes to dislodge any debris. I say carefully as you don't want to puncture a tube part of the way up and make matters worse. (Just a though but these days you can buy endoscopes for a few pounds on eBay; don't bother with the ones that use your smartphone, they are usually rubbish. Possibly they are narrow enough to fit in the tube and feed up and see if there is an obstruction. The tubes are, I think, around 2m long so you'd need a "snake" at least that and maybe a bit more. If it fits not only would it let you see if there is an obstruction but also the head is unlikely to snag the rubber of the hose. There is an irony here - I had one with a 5m snake and found it clumsy to use so recently gave it to a charity shop when I bought one with a more manageable 1m "snake". I hope i don't live to regret it). Sorry I can't be more help but unfortunately most of the really clever guys that knew their Yetis inside out have moved onto new marques and models taking their expertise with them but you might be lucky because occasional one or two look into the forum and post replies. Good luck.
ak9m12 started following Optimal place for a subwoofer amp remote wire location
Hey! Currently doing subwoofer wiring and I was wondering, where would be the best place to put my subwoofer remote wire. I would prefer to keep it in the boot of the car. If you guys have any experience, let me know.
ak9m12 joined the community
When relative engine power is considered, it was pretty common in the past for a private taxi to have a 1.8 or a 2 litre NA engine - a modern 1.0TSI matches that at lower RPM !
Our local taxis drive a lot of octavias. Reckon every second one is one. Last one I was in was a 1.0tsi and taxi driver said it was excellent. I too was really surprised when he said it was only a 1.0 litre. It felt like my 1.6tdi Alasdair
Clunky noise over bumps
Could be a broken rear spring if it sounds metalic/clacky. Had one that the pig tail broke off an was bouncing around in bottom of swing arm on my octavia. It was difficult to see but worth a check. Not sure if the fabia mk4 has rear drop links as well. If worn they will give a similar clack clack sound. On the Octavia rear spring is easy to do. Alasdair
Heater recirculation flap motor replacement.
I have seen the flap actuator and it is fairly low down, behind the lower glovebox, close to the LH side of the car. It seems that mine still works, but it makes a light tapping noise when I first start the car, for about 20 secs and a much louder tapping when recirculation is selected, again for 20 secs. I've got used to it. I would like to fix it and came to the conclusion that the easiest approach would be to use a Dremel to cut out a section at the rear of the lower glovebox, but I never seem to get round to attempting it, partly due to having 3 other old cars, all requiring attention! The Skoda is used intermittently. If I do the job, I'll then replace the cut out section by attaching a flange to the edge of it, so that it can be screwed or maybe clipped back in. With the lid closed, it won't show. I'll post again if I get it done. It's a silly design!
Very wet carpets
Hi, new here. Skoda Yeti 2014 2.0 diesel (170bhp) 4wd. In the last few days I have noticed small amounts of water on top of the rubber floor mats, front and rear O/S. It was noticed first in the rear footwell but yesterday it was very evident in the drivers footwell. Warm fine day, so used the air con and noticed the water amount had increased. When we got home I removed the rubber mats and the carpets were extremely wet. We had to place old towels on the floor, stand on them (water rising visibly under pressure), wring out towels (soaking wet) and repeat many times until too tired to continue - will resume today. Thoughts were, blocked drainage under windscreen (will check) but more likely air con drainage issue, particularly as using the air con made the problem noticeably worse. I drove the car into the garage and turned the air con on for 3 or 4 minutes - no sign of any water dripping onto the floor. Recent events that may be relevant:- had an air con check at Kwik Fit several weeks ago and we noticed the mechanic jump, exclaim, accompanied by loud hiss of escaping gas. they said the pressure was OK and we left but immediately noticed the air con was noisy. Returned and they reluctantly agreed all wasn't right and re-gassed free of charge. Could the drain tube have been damaged? Also, a couple of weeks ago the Garage removed the engine tray to fix a leaking oil filter, could they have kinked/trapped the air con drain tube? Sorry it's a long post, will appreciate any advice.
BlueDun started following Very wet carpets
Even with the advances in engines these days I think you'll find that if you ever travel fully loaded with passengers and luggage the car will struggle. A car may appear nippy when it's just yourself driving (the default situation for many cars) but if you have the opportunity, try a test drive "fully loaded" to see how suitable a workhorse it may be.
Sofo started following 1.0l TSI SE suitable for private hire use ?
Upgrade Carplay on my Superb 3T
carxoil started following Upgrade Carplay on my Superb 3T
BlueDun joined the community
Fabia VRS LE Register Part Trois
- Yesterday
Sportline 85
Would also be interested to hear from any new/recent owners of any Elroq 85 if they have the 84kwh battery (think that is now standard on MY27 versions?) and if they ended up with crappy I mean not so good Giti branded tyres?
I have just ventured into this and through a voyage of discovery, have found you can take the top glove box out without too much trouble. Unfortunately it achieves nothing, no access to the offending item. I have a 2010 mk2 Skoda Fabia and the only way to access the actuator, is by removing the whole dash. The glove box in my car is integral to the dash. The flap motor in my case, is under the passenger air bag, in the top left corner. There is little information about the task, I now know why.
Mark4168 started following Heater recirculation flap motor replacement.
Photography Thread
Skoda fabia IV 2024 31k miles. When driven over any slight bump in the road there is a clunky noise/rattle coming from the nearside rear. This includes potholes, speed bumps and uneven roads. Sometimes the noise sounds squeaky but sometimes it’s like a metal clunk. Has anyone else had this issue and if so what was it as i’m trying to repair things myself and wondering if this could be done without taking it to a dealership
Door Umbrella
Well blow me down! I've been driving the Fabia quite a bit more just lately and continuing to enjoy it, though the ride can be a bit firm when only two up on poor roads, even though we stuck with the smallest wheels available, probably not helped by the energy efficient tyres which I assume have stiffer sidewalls? Also smaller cars tend to be more firmly sprung to be able to cope with the varying load of one to four/five people which is a greater percentage of the weight of a small car than it of a big car. The suspension in my son's Mazda 2 is also quite firm. Anyway, I digress. Couple of days ago my wife looked in the glovebox when I was driving and low and behold a Skoda umbrella! The car is coming upto 3 years old now and in mitigation we rarely use the gloveboxes in any of our cars. Maybe I had looked in the glovebox and saw the umbrella when we first got it and thought it better left in there and I'd forgotten?
Guess the Hire Car.... Mac's 2019 game
Sorry.. No cigar for that guess...
Yes, we accept that it is possible on a good day with the right conditions and the right support just as this diesel powered Skoda Superb managed to drive for 1,759 on one tank of fuel and it set a Guinness World Records record. Record-Breaking Skoda Does 1,759 Miles on a Single Tank Greatest distance driven on a single tank of fuel | Guinness World Records
Guessing a Chrysler Voyager 🤷 A bloke I know here who has one, not sure what spec, but he uses it on the Autobahns a lot transporting antique furniture.
Bingo... A C3 Picasso that seems to have had quite a hard life... Is version number one. Version number two arrives tomorrow
5Q0 and 2Q0 radars have different mounting positions and, consequently, different brackets. With the 2Q0, you would normally have to buy and install different brackets. The 3D-printed part saves you from having to do that, allowing you to use the OEM 5Q0 bracket instead. It’s a great solution from @Cairus.
****röen Picasso. Can guarantee that if you're in a hot country the AC will be on the fritz 🤣
Skoda News
25 years of the Superb https://www.irishexaminer.com/motoring/arid-41906230.html
