Bulb Failure Warning
Yes, that's what it means...
Tristan2026 started following DSG Gearbox Errors. Advice Needed
eagle3024 joined the community
Tristan2026 joined the community
Power steering (Rapid)
@gswainyboy if you'd like to reply to the message I sent to you asking for the VIN, I can look up what system you have.
Thanks for that inspectorman. Back up on the ramps tomorrow and check all pipes and connections now I know what I am dealing with .
- Hunting down my old skoda
Clunky Gear Changes
Hi, yes it is DSG.
Clunky Gear Changes
Is this a DSG Gearbox ?
Warrior193 started following Clunky Gear Changes
- Bixenon Headlights auto-adjustment problem
Yassou joined the community
Binx1310 started following L&K Front Fog light Bulb access? and Bixenon Headlights auto-adjustment problem
You can get a hair dryer or heat gun and gnetly warm the area. it will hopefully soften the clips etc to prevent snapping in the cold eather. they can be a bit awkward and stiff but you pull straight forwards in line with the car, not at the angle the trim is at. That seems to be the main issue. I am assuming it is pre-facelift. I am not sure how the facelift ones come out.
Clunky Gear Changes
Hi all, has anybody got any experience/advice on how to reset/fix jerky gear changes at slow speeds, affecting both up and down shifts? I.e crawling in traffic speed or slight downhill low speed prompting a gear change is very noticeable, whereas normal acceleration is ok. Any tips greatly received as all changes used to be very smooth. 20month old 2l Diesel with 40k on the clock. TIA. :-)
Ccc1 started following Clunky Gear Changes
- Looking for Update Software
So the crash repair is the most likely issue. Might be a long coding issue which tends to tell the car which items are installed. If the car doesn’t think it has self-levelling headlights it might not be listening to any level sensor if that makes sense. What’s the make model and year? And do you have DCC?
I’m not sure either , i found out that you can fill out a form through the council and find out from them and they will tell you certain details about the car like who the last owner was and what not but you have too prove too the council why you need such information and you need a reasonable yet valid excuse and I’m not sure me saying i just wanna buy the car back is reasonable and valid enough
MK3Skoda2018 started following Looking for Update Software
- Bulb Failure Warning
I've not come across the word gettered. Is that where the inside of the bulb's glass is covered in evaporated filament? The bulb failure monitoring electronics in the BCM should be quite sensitive, yes. Bugger all to do with the CAN bus though, the bulb clusters have no connection to it.- Audi S3 Avus - 5 x 100 17”
https://ebay.io/m/62Kr39 Once again will do a discount for any Briskoda membersRogueWagon started following Audi S3 Avus - 5 x 100 17”- Octavia 2l tdi cupa egr cooler bypass what is needed and how to do it ?
Need to get underneath it. Think the pipes are around 20mm internal diameter. About to try something this weekend. Will update you if it worksT07 started following Octavia 2l tdi cupa egr cooler bypass what is needed and how to do it ?- Hunting down my old skoda
