Mpg????
Was looking at a newer fabia for my son and read real world mpg figures are 45-55 on long smooth runs but 35-40 if journeys are short and lots of stop start city/heavy traffic Alasdair
the truth about electric cars
I just meet a lovely couple with a brand new Suzuki Vitara EV. Supplied by a dealer 30 miles away and they live a further 12 miles from here. The have 60% charge in car, no home charger fitted yet and they came to charge. Parks salesperson explained nothing. Motability car and no Motability card for charging yet because nobody told them to get one ordered at time of car ordered. They know nothing about AC and slow chargers or AC and home charging. They know nothing about kWh,s or kW and charging speeds. They are now off to try the charger at the Farm Shop and using a credit card. I showed the lady Apps and tried explaining the various providers. I checked where they are and there is 1 AC charger a couple of miles from them and it is out of order. Real world EV,s and Dealership providing disabled people and EV.
veglia joined the community
Mpg????
Hi all, owned my 2016 Fabia 1.2tsi for a few months now and it's killing me on fuel, only averageing 35 to the gallon... is this right??? Thanks
Mpg????
Hi all, had my 2016 Fabia 1.2tsi a couple of months now and it's killing me on fuel, I'm getting 35 mpg average but to be honest most of it is shortish journeys, is this about right???? thanks
william_uk joined the community
Front park assist retrofit help required!
Thanks! All coded and tested using a cardboard box front and back as per @Bap33 suggestion!
Error: selector lever...
Hi again! So, I managed to reach the solenoid component and bend the little pins to increase the contact. I did a scan on the module and erase the error, and finally got rid of it. Indeed, the component that hold the solenoid is the last component you can reach after you disassemble the entire central console. I took some photos, but not with exact steps to follow. The tools that I needed were prying tools for the trims, T20 and T30, a 10mm socket(preferable a longer one as the screws are a bit longer) and a flat screwdriver to help me with the removal of the different connectors. I’ll try to explain the steps as best I remember: Remove the trim with the gearbox selector and the wireless charger with the prying tool and unclip all the connectors. After that is removed, you have 4 T20 screws, two on each side that you have to remove. In the front row also, the central console has two “skirts” that needs to be removed. These have one screw each, almost at the extremity near the accelerator pedal(for me, as i have LHD) and on the other side as well. After the screw is removed, pull the skirt to the side and down, they’ll come off quite easy. Remove the rear usb chargers trim/rear vents with a prying tool. Start from the bottom, there are two clips, one on each side, then go up, and you’ll find two more, one on each side. After that, gently pull from the bottom towards upright and use the prying tool to unclip it from near the armrest hinge. Once that is removed you will have to remove the duct vent and you’ll be able to reach the 2 T30 screws, that you have to remove. Once that is done, you’ll be able to remove the central console, but you have to unplug the connectors for the parking brake/autohold. Remove the T20 screw from the front side metal part that provide the 220V current and the two T30 from the back. There is no need to unplug it. You just take it out of the way. Remove the two T30 screws from the plastic bracket that holds the central console with the 4 screws from step 2. Remove the duct vent. Use the prying tool to unclip the keyless module from the upper side. (This step can be ignored i think, as after I removed it, I saw that it wasn’t blocking anything) Remove the 4 10mm nuts that holds the final plastic part, that cover the module with the solenoid. Remove the solenoid with prying tools on the clips and gently pull it upward to not damage the pins. Once you the solenoid, bend the little pins so it makes a better contact with the counterpart. Everything in reverse order, making sure you don’t force/break anything and you don’t forget about the connectors.
Amundsen MIB2 Firmware Update
have a instrucion?
Patch dont Work with SD Card You have to Remove the unit and have to Open it.
Buying Octavia mk4 vs keeping MK3.5
touchscreen for everything on the MK4 You can't beat buttons and twiddly knobs
ChoonDoode started following Buying Octavia mk4 vs keeping MK3.5
Sportline 85
I can't see any mention of a home charger included in the 2.9% offer on the skoda site, so I presume that it must be a dealer deal.
BBZ 1.4 Fabia Having a Meltdown (Codes P1504 and P1553)
That code is just a referral, saying "check engine ECU, it has a stored fault code", I think.
Rear left brake dust shield escaped, killed abs sensor?
From memory bearing has to come out to replace splash guard anyway and safer to remove sensor when removing bearing . Reckon easiest way is to remove knuckle and scrap it with bearing and replace with new/second hand knuckle plus new bearing,splash guard and sensor. Dont fancy trying to get the old bearing bolts out judging by the corrosion on knuckle anyway. Whats the other side like? Alasdair
Skoda Superb mk2 columbus sytem not starting up.
Hello. Some time ago my skoda Columbus system started acting up and just isnt starting. I have seen several posts here with kinda similar problem. One fix i have seen here is updating with a firmware which some people can give here. I do hope its the system not the hdd that has failed. Could someone give the link to the ISO for my car fix? Also im kinda curious why is the link only given with PM-s? Some legal thing?
usiim started following Skoda Superb mk2 columbus sytem not starting up.
Same crap. Charging AC at Girvan harbour. CPS and Electroverse card no access. Got phone answer quick and no Messing about with Liam. ID checked and remote start done. I waited till I needed 11 kWh as £5 minimum charge. Hopefully just a 90 minute wait as I listen to the radio and a full charge for early tomorrow start. PS now going to leave the car untill I see it has charged enough for a fivers worth. 20 minutes and only got 1.5 kWh of electric. 75 pence. PPS. Back at car. Still 36 minutes till fully charged estimated. There have been 4 cars turning up to the DC charger with no idea if the area but have already been to other Ayrshire chargers not working and unaware of Dowhill Farm Fayre,s charger.
Guess the Hire Car.... Mac's 2019 game
Ooooo I loved Menorca when I went there years ago with my parents. Seemed a lot less busy than Mallorca the years before. Group D, so kinda Normal hatchback size. Decent chance it’ll be an Arona or a Leon.
VOICE in New Karoq 2026
No idea what a "Style" model is, but even the base SE model has voice control. To be sure, download the digital certificate from the My Skoda app. It can be manually initiated by the button on the top left of the steering wheel. Initiation by the wake command "OK Laura" is a setting in the infotainment. I leave voice activation off as even when travelling alone, the radio can trigger it.
Rbz5416 started following VOICE in New Karoq 2026
By the looks of things I would probably be looking at doing the bearing housing (knuckle), bearing, sensor, splash guard and associated bits all at the same time.
Never meet your heroes. Was at the Hawthorns, as oft am, and Frank Skinner was walking around talking to various in the crowd, he was miserable. Managed to shout to him his tv series, which he wrote appeared is SH1TE which is how the public reacted to it too. Like his stand up, but Shane was bad.
PS Alex Salmond and Nicola Sturgeon lead the SNP and filled their own pockets and advanced Independence not one little bit. Like Cuckoos. There are plenty Champagne Socialists that earn well from the public purse and were happy for true supporters money to fund their lifestyles.
jske joined the community
1.0l TSI SE suitable for private hire use ?
I assume you have factored the lower cost of petrol against the higher MPG of a TDI? Four passengers with suitcases would suggest a Combi as opposed to a Hatch - If going down the TSI route, suggest looking for a 1.0TSI 110 or 116PS engined version, which, for a manual, have the 6-speed box.
Warrior193 started following 1.0l TSI SE suitable for private hire use ?
There is another story. My mum went to school with him & worked at St.Cuthberts Bakery & Tam Connery at the Milk at the Coop. They were the same age but somehow all his life after body building and boxing and being an artists model he had a DOB making him younger. He said he lost his virginity to an older women. well considering he tried them all on and an 18 year old was older than his supposed 15 year old. Once at Downfield golf course in Dundee my pal shouted and asked for an Autograph and he told him to get to ****.
Wheels and Tyres
Pic of tyre and excuse the dirty wheel, needs a wash. Similar tread pattern to the premium Michelin CC. Ive also removed the locking bolt, as I do with all my cars, as I dislike them.
He does, genuinely seems to speak up for the poor. Chalk and cheese compared to Sean Connery who seemed exactly as a Scot abroad with so much to stay on Scottish independence. I like Brian Cox the actor and he seems to appear on UK tv ie Question time a few times. I like SNP actions on green issue, they appear more socialist than Labour.
SNP Supporters that do not live in Scotland and pay taxes or even in the UK can say and do as they like, but not even having 1 vote is something, but their 1 voice might impress some but really it counts for nowt. Good that he impresses you @lol-lol
