  2. Hi. Tbe o rings are special rubber so they don't rot. If there is still pressure in the system it will need recovering first. Illegal to deliberately release to the atmosphere. To oil the O ring use the appropriate LAG oil for the system. Going to need a garage with AC equipment. Good luck
  3. Mattridd joined the community
  4. My fronts were measured at 4mm and rears at 5 mm, which is more than I expect, but they are Goodyear all-weather, so I suspect a bit of a softer compound. But Mrs says the big difference is the car never aquaplanes when it rains very heavily, which both of our Golfs (Mk7.5 and Mk8) on Bridgestones did. So I'll probably replace them like for like next summer when we get to 20,000 miles or 2.5mm whichever comes first; annoying but I do absolutely love the car and it is heavy, so like the higher road tax, it's an accepted cost of ownership. Your tyre wear, however, does sound concerning, assuming you check pressure regularly and drive it like a Tourer rather than with gusto? Had Pirellis on some of my former warm/hot hatches (XR3, Mini Cooper S) and, as I recall, they did wear more than expected, perhaps more sticky and hence softer, as a performance brand?
  5. Got the ISO file, burned it to cd and everything works perfect now.
  6. Ok. Looks like they've just done an oil change and not cleaned the strainer / filter which needs the pump removing. The latter is not part of thier normal service routine but needs doing and some dealers do it some don't. I'd ask if them whatbtheybdidnre the internal pump strainer / filter when they changed the oil and if they didn't do it either ask them to or take it elsewhere. Also double check with them that they know where the Haldex drain plugs etc are just in case they've drained the diff instead as they are easy to confuse if your not familiar with the car.
  7. What's the increase in BHP with the new dipstick? 😉
  8. I had a new Scala 1.5 dsg Monte Carlo from 2021 before trading it in for a SEL Karoq in 2025. Had seven Skodas since 2004 and the Scala was my favorite by a country mile, comfortable,economical,spacious and a great looking car. Icant think of anything I didnt like about it, probably get another when I change next time.
  9. Have been on a 15000 Km ( 9400 Miles ) summer trip with the car. Have discovered a very annoying and clear exhaust drone in a narrow rev range ( 2950~3350 Rpm. ) The car has a 100% stock Skoda OEM exhaust system. 🤔 Anyone else here at Briskoda who has or had similar exhaust drone on their Octavia-II FL 1.8 TSI / 2.0 TSI equipped car ? 🤔 .
  10. I have a leak at the pressure sensor I believe it must be the O ring seal. My question is, are the O ring seals special as they are VERY expensive for an O ring, can I fit an ordinary EPDM O ring. Am I right in thinking the pressure sensor can be removed without losing any remaining gas? Also what sort of lube do I use on the O ring when installing it?
  11. I filled the tank and managed to get 58 litres in on the first click. So if the 4x4 tank holds 65 litres, that means the trip computer and fuel gauge is definitely still over reading by some margin. I had the RHS pump out the other day but when I saw the extra pipework disappearing off to the 2nd off take I admitted defeat and put it all back without any further tinkering. I have a service coming up so I might just get the readers replaced at the same time….
  12. Refuelling time. I couldn’t remember if I reset the trip when I last filled up, but the car was showing 160 miles left in the tank, and the refuelling quantity was showing 35 litres.
  13. Today
  14. Thats cool but not good when your order specified contis in January on the car spec .
  15. DJC123 joined the community
  16. Many thanks! I just replied to you. Good luck / "bonne chance" 🙏
  17. They look good. I had the boot and rear quarter windows tinted earlier this week, on top of the existing factory tint. I would have have considered those but not heard of them before.
  18. The two black wires are the speaker connections... Probably old 2 pin DIN connectors from memory and the beige one will be permanent live, ignition switched live and earth. If you have access to a multimeter simply probe the three contacts on the white connector to work out which is which and wire up accordingly. Your new radio may have an ISO connector where all power wires are in a single black socket and speakers in a brown one, or all in one large black one, but you should be able to get a plug with wire tails already fitted. Like this https://www.ebay.co.uk/itm/266294103226?campid=5339147365&mkcid=1&mkevt=1&mkrid=710-53481-19255-0&toolid=20006&customid=EAIaIQobChMI77-sp43_lQMV8pRQBh2QrgSjEAQYAyABEgIekPD_BwE&loc_interest_ms=&loc_physical_ms=9046365&adtype=pla&gad_source=1&gad_campaignid=23835726846&gclid=EAIaIQobChMI77-sp43_lQMV8pRQBh2QrgSjEAQYAyABEgIekPD_BwE The internet will tell you which connection on the plug is for what (speakers, live, earth etc.) so simply splice your existing wiring into the tails on the new plug.
  19. ^^^ Manufactured by Hankook, or Factory owned by Hankook.
  20. For me, the ADAS wasn’t an issue, the team at the windscreen depot did everything in just over two hours. And yes, my original screen was also scratched to hell!
  21. Just noticed i have Laufenn tyres all round on the stock wheels , obviously changed the contis down to these at skoda , 1st time I noticed ,
  22. Thanks. BTW, how are your tyres wearing? My front Pirellis are under 2mm at 13,500 miles.
  23. This is what we were sent for the haldex change as part of the sale.
  24. Hi all. Had a quick search of the forum and can't see anything related. We are getting an odd sort of booming noise when pulling away with lock on from the rear of our 2020 karoq 2.0tsi 4x4. It's done it since we bought it last year on just over 40,000 miles. The selling dealership, group 1 Skoda Maidstone said they would service the haldex system as part of the sale and I have an email with the work stating it's been carried out. I assume this noise would be coming from the haldex as I've never heard it in any other car, this is the first car we have owned with such a system. I've read it could be binding. Does anyone else get this noise, or has anyone had this noise and had it investigated? I wouldn't say it's got any worse over the time we've owned the car. Thanks. Adrian.
  25. They’re very effective. Drove down to in-laws with the kiddies and with the rear screen from @Tankdave and these, it was like being in a blacked-out limo in the back. 5 days from Order to Door from Australia is decent too.
  26. Feeling frustrated. Following on from previous post. 2014 Superb Elegance TDi CR170 Back story. Ran over something in the road, punched a hole in the fuel tank. Mechanic replaced the tank with one I sourced from a breaker that included pump, gauge sender etc. Car was then hard to start. Mech thought maybe low fuel, so put half a tank in. Following day, it started but cranked for ages before it started. Drove fine for a while then gave me limp mode, flashing glow plug light etc. Code comes back as P008700 - fuel rail/system pressure too low. Checked getting fuel out of tank pump, and at filter housing (and was full to top), HPFP and rail but I have no idea if any of those are ‘in spec’. Fuel filter had 15,000km (9000 miles) on it so well within factory intervals but changed it anyways just in case but noted this time the housing was nearly empty. No sign of HPFP metal pieces. Still very hard to start if sitting for more than a minute but runs ok til you give it some stick - brings on limp mode about 4.5k rpm. Im usually pretty sedate driver, but tow a trailer fairly regularly so gave it some death to make sure it’s ok which its clearly not. Question is - could the tank pump be causing my issues? I have the old tank with pump, so can change it but I don’t know if it’s my problem. Otherwise it goes back to the mechanic on Monday. TIA
  27. vanko joined the community
  28. Ains changed their profile photo
  29. Update: I saw a low battery key warning on the screen last week... which kicked in my "change all the batteries now paranoia"! All 4 (3 keys and immobiliser fob) were swapped for new Duracell CR2032s, which I did annually on both previous VW Golfs, and it was also just before service, so another minor cost avoided. I tend to buy a pack of 10 from Amazon so I have them on hand, and ... they have a longer lifespan than their annual use.
  30. If you are on a Service Contract, you can do an annual fixed 12-month, 10,000-mile servicing, my Superb IV estate 1.5 TSI/25Kwh has just gone in at 9 months and 10,700 miles, as we recently got back from touring France and will average down until next summer. This has always my preference, although the petrol engine has probably only run for no more than 70% of the time; I prefer the full annual inspection, which came with a video of all of the underside verifying no damage to any of the components/covers or leaks of the shock absorbers, a full tyre condition report and new oil/filter all documented across a circa 60 point proforma. They didn't check the tyre sealant because the boot was full, partly with a loose space saver, so I am double covered in any case. Given it's a big, complex car, I would not want to leave any of this for 2 years? Trans City also got to the bottom of a rogue Electric/Hybrid switching problem (user error with the App) and changed my number plate for £24, as I had applied for a DVLA change in the morning and had the eV948 form.
  31. Hi @pab567, Could you please help me with the firmware MST2_EU_SK_ZR_P0480T (or P0478T) for my Skoda Bolero MIB2? My unit: Train: MST2_EU_SK_ZR_P0477T MU: 0477 Hardware: H41 Part No: 565035840 Thank you very much!
