  1. Today
  2. DGW started following DPF cracked?
  3. Yesterday
  4. Fabrizio956 joined the community
  5. Carlinkit's adapters are very good. I am using it (mini ultra 3). It is almost as good as using it with cable. Most importanlty no delay while listening songs. Sometimes while playing songs it can glitch for 1 milisecond and after that it continues normally. Glitch happends rarely. If I was in your shoes I would first try with some better cable, like Samsung's original, if that doesn't help then I would continue with other methods. Good luck.
  6. I had read that they were problematic but considering I'm only looking for android auto have gone for the latest Motorola one from Amazon. I like that it has a physical power button and fast switching between phones. Good suggestion.
  7. Thanks @pab567 for such a quick response. Have a few follow up questions on procedure via pm thanks again.
  8. My son has a 2013 Octavia 3 purchased from a dealer about 11 months ago. The dealer has proved deeply untrustworthy and has lied about many things. That’s another story. In spite of this the car has mostly performed ok. However, with MoT looming he’s mentioned again that the check engine light is on. Code is PO401, insufficient EGR flow. Car drives fine so I’m suspecting that the EGR filter in the LP circuit is blocked. This in turn likely means that the the DPF is cracked - a theory supported by the sooty tailpipe 🙁 We could clean or replace the filter pipe, which will probably keep the light off briefly (until it clogs again), but this is probably pointless as even if the MoT tester doesn’t spot the sooty tailpipe, the machine will spot excessive particulates? Anyone else travelled this way? I’m thinking aftermarket DPF replacement and a through washout of the filter pipe is the budget option. Looks like genuine parts exceed the value of the car even before fitting! Thanks Nick
  9. VitesseEFI started following DPF cracked?
  10. I definitely type stuff filling in blanks in my head; then go back and re-read it and wonder how on earth I’ve let that go out the door.
  11. Colourful skies this evening and despite appearances it didn't rain!
  12. MargaretandRob joined the community
  13. I sometimes get this when on the A303 heading east coming to the Sparkford turnoff, it ' sees ' the 40MPH sign sometimes , especially if I'm in the overtaking lane ! I just carry on and reset the ACC and it recovers about a mile further on.
  14. @red-ireland friend of mine had similar problem. Then he tried with higher quality cable and there was no more issues. Did you try using any carplay bluetooth adapter ? CarPlay requires a high-quality cable that supports both power and data transfer (at least USB 2.0 speeds of 480 Mbps). "Charge-only" cables will not work.
  15. Ride is great. No issues anymore with shocks and springs. B6 damptronics with Eibach pro kit. Racingline links and H&R bars front and rear. I have three sets of Lower front arms on the go at the minute. I’ve been trying different front bushes to stop them eventually making a slight noise when they dry out during the summer. I’ve tried pre fitted, I’ve worked my way through suoerpro, and powerflex. I’m starting with polish now. I have the blue fitted but it’s starting to emit the odd creak again. So I’ll pull them out and try going up to the orange. I’ve also tried all the others refitted with a range of grease from polybush specific to marine grease to no avail. Just the front now though. The front lower with the tts solid bush is quiet. Obviously for reference, it’s always rebuilt with new bolts and tightened on the ground along with setting the adjustable links again everytime. Otherwise the thing drives really well and still makes me chuckle evertime I use it. The rear bar and links were a great help as well to handling and cornering. Yellowstuff rear and blue stuff on the front with their floating discs. Needs tyres on the front, but I’ve PS5’s coming again hopefully next day or two.
  16. Rory replied to BillyParker's topic in Skoda Karoq
    Welcome!
  17. iPhone 12, pixel 8a, oppo find x9 ultra. All of these phones came with USBC and the car is usba so not able to use original cable but most of my other cables are ugreen.
  18. @red-ireland regarding your problem which phone do you have and are you using original cable for connecting to android auto/carplay?
  19. Download link for MST2_EU_SK_ZR_P0480T sent in PM
  20. I have a 2018 skoda octavia and Wondering if there is any update for my unit? @pab567 I have a problem where smartphone disconnect frequently from car play or android auto. Might just be a problem with usb port. Anyone have a doc or video on how to check for loose connection or replace the USB unit? I replaced the original battery less than 2 years ago and the latest one is not dead. I checked for parasitic draw but not found any. Wondering if mib intermittently causes the problem. Thanks Red
  21. Sorry @UndertheRadar didn’t mean to exclude you from that question! Cheers for confirming. Think I need to review your project thread! Cheers @MarioVrs Eibach is a def! Alu subframes all round…?
  22. Hopefully its cured problem. Did read they need coding and 140 euro doesnt seem too bad considering garage prices these days. Glad you got it fixed Alasdair
  23. Same thing happened to me intermittently and annoyingly on minor roads in North Yorkshire. I just pressed on regardless
  24. I fitted mine dry as well as per their instruction. Felt weird doing it, but no issues since.
  25. rudolfo10 joined the community
  26. Lee01 replied to Tim's topic in Hellos and Goodbyes
    @Tim Škoda Owner's ManualsOn this page we offer you the opportunity to download the owner's manual and any other documents for the car. https://share.google/i1QFVJKbklQQ5f3Gr
  27. Yeah so it hummed for a few seconds but on my output tests using obdeleven, it hummed for a long time. I got the connector off, it was much easier than expected, no signs of corrosion. The cable was fine, I learnt that trick a bit late. I got a used pump from a breaker for 70e (including shipping). Got it changed at a garage, the job was very easy as you said, I could have done it on me own. Guy charged me 140 for the job including coding (not sure if that was even required, feel like he fleeced me there). All's well now, hopefully I don't see that error anymore!
  28. Just bought a 2020 superb estate Mk lll from big motoring world. Nice clean car but did not come with owners manual. Where can I get one ?
  29. Tim started following Owners manual
  30. Hi everyone. My son bought a 2023 Skoda Scala 1.0 TST Monte Carlo back in April. It's a beautifiul car. Early in the summer (on one of the days it was 35C) he said that it wouldn't go into gear after having it parked all day, although after a bit of trying it was fine. This didn't happen again until last month when the same issue occured. Over the last few weeks he says it's been happening more often, although it is still only intermittent. As there was no record of the car having it's brake fluid changed at 3 years he had this done at our local garage yesterday, along with the clutch fluid as we know it's shared. The garage said the fluid was low, and now that's all done. He was hopeful that that was the problem sorted but it happened again this afternoon. This time I was able to get into the car and feel it for myself. The gear change felt stiff and required more of a push than usual to get it into gear. Lifting and then reengaging the clutch resolves the issue. A quick search on the web suggests lubricating the linkages in the engine bay with lithium grease - that looks easily doable and worth a go, but I'd appreciate any other thoughts or suggestions. Car has 23,000 miles, full service history - and is no longer under warranty from the garage we bought it from (of course!) Thanks in advance for any advice.
  31. Hello, I am interested. Please send me your number, and I will get in touch.
  32. kokomm joined the community
  33. Tim
    Tim posted a topic in Hellos and Goodbyes
    just bought a superb estate from big motoring world the car is excellent
  34. Tim started following Tim
  35. Here is the breakdown for the facelift LED fog light retrofit on Skoda Superb MK3. On the old pre-facelift fog lights, Pin 1 was the main power wire with a 1.5 mm² cross-section, and the other pin was ground. On the new facelift LED fog lights, the pin layout is different: Pin 1 is for the 0.5 mm² PWM signal wire, and Pin 3 is for the 1.0 mm² main power wire. Because of this, you must swap and re-route the pins during installation. Specifically, you take the original 1.5 mm² power wire from the old fog light harness and move it from Pin 1 to Pin 3 on the new connector. Then, you take the new 0.5 mm² signal wire coming from the headlight and connect it to Pin 1 on the new fog light connector. Because you are splitting the functions between two different pins and wires, you must also change the channel assignments in the BCM (09 Central Electrics) module accordingly. In the BCM adaptations, set Lampentyp for the Signal Channel (Pin 1, 0.5 mm² wire) to 6 - LED-Lichtmodul to deliver the low-current PWM control signal. For the Power Channel (Pin 3, 1.0 mm² wire on channel 55L), set Lampentyp to 32 - Allgemeine LED bis 12W or 36 - LED Kleinleistung to provide a constant 12V power supply without pulse modulation and ensure correct diagnostic fault monitoring.
