C pillar and top plastic edge of side trim which you would need to remove to install the torch holder anyway. C pillar clips on and trim is 4 Torx screws. It can be a little fiddly to replace but all very doable. The workshop manual describes clearly how to dismantle. I can send you the relevant pages if you donβt have.
Gaz59 started following Hellos and Goodbyes
Excellent! Does the entire panel has to come off, or it can be only the c pilar trim? While not afraid of dismantling, I am a bit overrun with things and tend not to open up works I need to leave half-way, especially on the family wagon ... π€ͺβ οΈ
Dongle for code reading & coding
We are going offtopic, but just to say I do have a UK address through my forwarder to I have workarounds for shipping and delivery when "normal" is complicated. Otherwise Brexit would have seriously dented (not killed, mind you!) my unstoppable (masochistic perhaps!) passion for Land Rovers and other associated British machinery! π RogueWagon let me rummage in the garage and I'll get back to you via PM, thanks! π
Coulson joined the community
Finally managed to find time to change the oil! Now running Pakelo Krypton Racing in 0W40 let's see how it manages the winter. The previous oil was Fuchs Titan GT1 in 5W40 which after 14 months and 8,750km came out pretty darkish, so good it was to replace. Car had little urban use, most hwy and a couple of them long hauls on a spirited manner π«’ I also put already the winters, it is a wee early but I have time now, surely none later π«£ Front pads have 1/3 left, so to keep in mind. Haldex is neglected and to do, but I lost the package with the bolts and seals so might reorder and if I ever find them ... is a consumable after all. I got a but of a worry as I found oily "wettish" in the area of where the dipstick is, but not sure if it comes from somewhere up, or where can it leak? The bottom engine cover is dry clean, the stuff goes towards the lower arm and seeps along the undercarriage. As far as I could see, the top of the engine (camshaft cover) seems dry. Any ideas at what to look at? The dipstick really? (never happened to me in like over twenty years of motoring).
JD52 started following WINDSCREEN
Hi SkOmk4, Speaking to them yesterday when I went to pick the car up they said that they'll need the car for 2 maybe 3 days as its a large update. The workshop manager explained its an update that goes through all of the cars ECU's and it can take up to 3 days. I checked on the car yesterday and the software version currently installed on mine is 2768. I know logically when there's an update its for the better but coming from many years of owning land rovers the main consensus there is 'if it ain't broke, don't fix it' which mainly (also) goes for updates (and yes, I know firsthand you can't compare any LR to anything else reliability-wise but I love the wife's Octavia just as much). Honestly I'm pretty happy with the infotainment especially reading up on the pre-facelift issues. I had this issue with the screen come up 3-4, maybe 5 times over the past year and they all occured during summer where the car's interior can reach extreme temperatures so didn't really worry me as it went away after you switched tha car off and on again. I booked it in yesterday for next month to get the update and see if that fixes it (although as said above, very rare) The weirdest thing I find in the Octavia is that when my wife and I are both in the car somehow both our phones are connected to the car. No matter which one rings, it goes straight to the car speakers so we need to remember to disconnect one everytime. Apologies for the long post and thank you very much for the info.
So long as you declare as gift and under β¬30 it should be free of any import duty or tax. Would just be postage costs.
The wire for the hatch lights is red/blue and just behind the c pillar trim at a connector. A positap or soldered splice would be suitable. Constant power can be taken from anywhere and there is an earth point behind the trim too. Relatively simple diy job
I could be interested As I only want to change a few little things on mine But Iβm in the Uk So probably doesnβt make much sense for you!
For reference, the holder is given by skoda-parts as number 3T0 947 509 with subsequent suffixes but I think the shape always the same. 9B9 is for black, WC4 for beige. Don't seem to be different between hatch and kombi. As for the cabling, as mentioned must fish somewhere in the wiring to find the relevant signals. Any electrical auto shop should have the male connector to fit the wires. Someday ....
That is exacltly what I've learned after buying OBD11 with a gazillion credits ... yeah, I should have made my homework better, but they had the bundle in offer and I went at it. Useless in my case, since I could not "adapt" or "long code" anything else that I'd already done with VCDS. For me, it is useless ... it stays somewhere in the garage unused. Perhaps I should put it in the marketplace, if someone has interested in it I'd be happy it gets to be of use to another briskodian ...
leolito started following Dongle for code reading & coding
ZSabo17 joined the community
The update they mention for the facelift versions is more that the infotainment unit - it's a package with software updates for many other ECUs on the car - called PV4RC. The update is worth doing - the general opinion is that it addresses several SW gremlins, even though I still have some issues trailing after the update. AFAIK the latest update for the infotainment unit is 2768 for Seat/Cupra - the Skoda one should have the last digit +/-1 - otherwise they are "labeled" the same for VAG siblings sharing the same hardware. There was no major version update for the infotainment over the past year, unless the new models coming out of the factory have a newer version that's still unreleased OTA.
Skoda Fabia 1.2TSI Monte Carlo 09/2011 - Electric Windows Fault
Pete, The Drivers Side Door Switches Illuminate with the lights. The driver side window controls don't operate either side at the moment. The passenger side window controls are not working either. Everything on the Drivers door works perfectly (i.e. Electric Mirror Controls, Electric Mirror, Central Locking & Door Switch For Interior Light.) The car has a full history and the previous owner has spent a fortune maintaining the car, which leads me to believe he has already had a garage look at it. This is why I'm trying to gather as much information as I can, as I expect the repair to be a little cumbersome and not straightforward, as he would have already resolved the issue if is was simple.
Skoda Felicia 1.6 how to replace part number 6U0711248
The ''feeling'' now is better when you change gears? My gear stick sense was very sloppy plus i has a problem in 3rd gear,it was shaking a bit and i always afraid that it will be disengage by itself. π
What summer tyres do you drive on 19'' wheels with your Kodiaq?
We have Maxxis Victra sport 6 suv on our 1.5tsi and never had any issue with them. Seem to grip well in the wet. Not having to handle about of power but we are very happy with them!
Binx1310 started following What summer tyres do you drive on 19'' wheels with your Kodiaq?
Matrix headlights with auto high beam
Do you have your headlights on "Auto"? If so, i think you can press the "Low beam" button, which will turn off the high beam without flashing other drivers
evilsheep started following Matrix headlights with auto high beam
I successfully replace this rubber and 2 pieces of o-rings.
- Strange Electric Window Behaviour - Passenger & Rear Windows Respond Incorrectly
2013 Superb 1.6 electrical issues
Udate, this issue has been traced to the wiring loom from the steering wheel, the column was in the lowest position and is causing an interruption in power to the dashboard kicking in the immobiliser circuit that momentarily cuts power to the engine causing a stall. With the steering wheel in the uppermost position the car runs perfectly. The job now is to have a look at the wiring loom for either a break in a cable, the loom catching when turning the steering wheel as while replacing the starter switch I may have caused the loom to be moved, or a loose plug. At least the car is now driveable again.
Kodiaq 1.5tsi mHev. Owners views? Update: Bought a PHEV Kodiaq Instead
Looking at a bigger car cos of twin grand kids coming next year. Brand new Kodiaq 1.5mHev at only A$49k drive away with 7 year warranty. (25k pounds) Economy at 6l/100 seems to good to be true for a 1700kg car. Anyone got experience on whether power is adequate and real world fuel use around town and on a run? The dealers dangled a PHEV in front of us and we fell for it hook, line and sinker
- Yesterday
Leaking coolant - Superb 2.0 Tsi 4x4 2019
Any signs of water on the oil filler cap (possibly white foam rather than droplets), or on the dipstick?
KenM started following Leaking coolant - Superb 2.0 Tsi 4x4 2019
Software Update available for Bolero?
Hi @pab567, could you please check if there is a software update available for my MIB3 Bolero unit? Currently running: MEN3_EU_SK370_P0393L (MU 1310). Thanks a lot for your help!
redabout started following Software Update available for Bolero?
redabout joined the community
manosand joined the community
WINDSCREEN
Has anyone found a way to mask the millions of tiny craters in the outer glass of the front windscreen in high mileage cars? They cause a multitude of reflections in bright sunlight to the extent that I've had to almost stop once or twice recently when I couldn't see the road. I have had three Octavias since 2002 and all of them have suffered with this problem, the only way I have found is to replace the screen somehow but with all the electronical gubbins linked to the vRS screen, my insurance company won't guarantee that a replacement will have the same connectivity. i have the same problem with my 2000 BMW 740 which still has the original glass in it.....
SwallownAmazon started following WINDSCREEN
List of VCDS Owners (Previously known as VAG-COM) & VCP Owners
Anyone in south wales still active with VCDS? @Lightrofit
