Everything posted by pab567
Retrofitting carplay compatible head unit
Nothing is impossible. Pls share your VIN.
Head unit upgrade
It's determined by glove box unit coding, not by the screen itself, so you can go on
Bluetooth connection
Pls post model number of your BT module and your phone.
Columbus to RNS310 vs bluetooth streaming problem
Wiring - you miss a pair of cable for left channel between BT module and radio.
RNS-510 columbus restart
Have you burn new firmware onto CD or DVD?
Infotainment Model Numbers
Same HW, same SW (04xx), same features...
Amundsen MIB2 Firmware Update
@cedricq check your PM
No, it's not possible.
Amunsen MIB1 Firmware
To get SmartLink (Android Auto + MirrorLink + Apple CarPlay) you must have both glove box and display units exchanged. You can install one of four different glove box units: - MIB2 Bolero - MIB2 Amundsen - MIB2 Columbus - MIB2.5 Columbus You also need to replace display unit: - for MIB2 Bolero you can use either 6.5" model number 5E0919605H or 8" model number 5E0919605N - for MIB2 Amundsen and MIB2 Columbus you can use listed above display as well as 6.5" model number 5E0919605J, 8" model number 5E0919606, 8" model number 5E0919605M - for MIB2.5 Columbus the only display unit that works is 5E0919606D If you would like to have also support for Apple CarPlay or better phone charging (current up to 1.5A comparing to 0.5A) then USB must be replaced as well. The question is what is your budget and which of listed below features are "must have": 1. Video playback from DVD, USB, SD 2. CD playback 3. OEM navigation 4. displaying OEM maps na Virtual Cluster (Active Info Display).
Satnav
Use the left touch button from the first picture to open second window and select GPS to show satellites information.
- Understanding differences between infotainment systems - swing / bolero / amundsen
Fabia Mk3 broken screen.
You can donate The Great Orchestra of Christmas Charity
Android Head unit upgrade from Bolero
The mani connector is QuadLock - the one with 52 pins, connected to original glove box unit. The ones that are in th emid console (4 pins white and 12 pins black) and not relevant for you as they are just for communication between original glove box unit and original display unit.
PM
Head Unit Shenanigans
Check your PM
Quite an old version, recommend yto update SW to 5238 when you get it
Dipped Beam
3T0035680K? This should be slightly older unit, version C12, still with HDD.
Hold your horses. x is not for region but for version - the higher is better. 3T0035681x is also fine. I recommend the units on software 6270 or 6276 as these are so called C14 versions, with more powerful processor, more memory, SSD instead of HDD and more effective GPS chipset.
Yes, it will.
- Dipped Beam
Good news! In such case you will need Columbus RNS510 model number 3T0035686x (x - any letter). This is unit with DAB/DAB+ receiver, be careful NOT to buy any other model number (e.g. 3T0035680x, 3T0035681x) as they don't have DAB/DAB+ receiver. Instead of buying Columbus you can also get some MIB STD2 PQ unit, from Yeti FL, which will then give you more features, e.g. Android Auto and Apple CarPlay, and will allow you sell current BT module as these units have BT module integrated.
Displays are NOT protected, just the glove box units.
