TMC not Working
There might be issues with TMC at the moment, at least based on this post: I'll try and remember to see if mine is working today
12v socket different types?
1Z0 925 069 B from the looks of it
Software Download-Source authorised, searching for SWL image.
Probably means the firmware has become corrupt and needs reloading. @Rustynuts might be able to share some advice.
Help! Yeti dead
Take a close look at the empty spaces in the fuse board: - if it has no contacts, perfect - if it has a single contact, that's fine - if it has contacts on both sides, it's missing a fuse At a complete guess, I'd check fuse 12 (5 amp?) in the engine bay as I think that's the CAN gateway. It would explain both the no start and lack of OBD...
Rear view camera
Is this a continuation of this thread: https://www.briskoda.net/forums/topic/501816-bolero-multimedia/ If so, you did get an answer and possible solution from Pab:
- Wing mirror repeater harness/plug
Front differential service VRS 245
Are you sure? I've just taken a look a few gearbox workshop manuals I have and when replacing front final drive seals, they all point to the gearbox oil section to refill afterwards. There is no mention of a separate front diff oil anywhere I can see... The e-LSD/VAQ/haldex takes separate fluids as it's only used for the hydraulic clutch pack and not the actual diff.
Skoda octavia 2 stereo wiring chart
There are definitely switched lives in the fuse box... I assume you're checking the one at the end of the dash panel?
Lhs rear fog
Depending on the car, either VCDS, VCP or ODIS-e should be able to achieve this without messing about with the wiring 👍
MY17 Superb Retrofitted with Direct TPMS
If I recall, there are two kinds of TPMS sensor: - ones which self learn which position they are in - ones that need programming with a TPMS tool (not VCDS, ODB11, ODIS etc) At least when I last checked, orange versions needed programming but black ones didn't? Might be worth adding part numbers or pictures showing which sensors you've used...
Chain or belt?
I think the TSI is a chain and the TDI is a belt
Rear view camera retrofit
@lukaklaric can you update VCDS to the latest version and clear all fault codes - plenty aren't related to your camera issue and just make it harder to read. Once you've done that, a new autoscan along with a adaption map from 5F would be helpful ApertureS - lowline coding is normally byte 19, bit 4 iirc, that seems to be fine in the provided scan. At this point, the only thing that's concerning me is the software version, it appears to have a version normally used some Audi's and the Touareg. I can't see any obvious scans online of it being fitted to a Octavia/Superb. At a guess, they've flashed the wrong software to it (H18 supports both 4M0...A and 5Q0...B software)... Yours: Address 6C: Back-up Cam. (J772) Labels:* Redir Fail! Part No SW: 4M0 980 556 A HW: 4M0 980 556 A Component: RVC Compact H18 0250 I'd expect something like: Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb Part No SW: 5Q0 980 556 B HW: 4M0 980 556 A Component: RVC Compact H12 0231
MIB2 Amundsen differences between FW 0468, 0478, 0480
You can get the TPI from erwin https://erwin.skoda-auto.cz/erwin/showHome.do but there is a small fee (€7 + tax for an hour?) to access it. There should be one for the 0480 update, at a guess it would be 2049459/11...? I can't remember when I last logged in but at that time, the 0478 update was the latest.
Your thoughts on towing a heavy caravan
Sure, attached it here: D4B80828146-Trailer_operation_as_of_2016.pdf It's something I downloaded from erwin mid 2021 so there might be a newer version but I doubt anything significant has changed regarding a 2018 car.
Just from a cursory glance of some online parts catalogues, there certainly are differences between standard (1D0) and towbar fitted/prep'ed (1D4/1D7/1M5) cars. For example, there are some different hoses and fan configurations for the 1.6TDi Octavia seemingly based on the above PR codes: I'd expect something similar for the Superb with the same engine. Obviously that's not to say all models need upgraded cooling, only that some might depending on the conditions their being used in That view is shared in Skoda's own retrofit towbar guidance:
24320 - Steering C10AC 07 [009] - Mechanical Failure
I didn't notice any symptoms... It was just the fault code so I mentioned it when I took the car for a service and they did the update with no further questions asked
It's just bug fixes and stability normally. Annoyingly there isn't a full change log but the TPI's give a small amount of info. For example, 2049459/10 for the 0478 update states: Which suggests that 0478 fixes those issues I've not seen the 0480 TPI so I can't confirm what fixes it may include. I am running SW:0480 and got a link from @pab567 - they may know more about the differences between versions...
Fuel requirement
Pure ethanol is hygroscopic which means it will absorb moisture from the air. That's just like most brake fluid hence the need to change it every few years. Once mixed in with the other components in petrol, it really shouldn't cause an issue if the car is in regular use. If it's an older vehicle that's laid up for half a year with a steel fuel tank then it might cause a issues. To be honest, it's more likely to finish off old plastic/rubber components but they are probably due for replacement anyway... I use E10 in my '69 Sprite without any negative effects. When I dragged it out of hibernation this spring, it happily started on the first turn of the key with half a tank of months old E10 - no water/rust etc in the fuel filter 👍
Lost key fob
ODIS is the software VAG provide for their dealers. Independents can also use it but there monthly fees etc. Each brand is a separate subscription so I'm not sure if 'any' dealer can do it or not I'm afraid.
Lost key fob
A dealer or someone with ODIS online should be able to... You'll need both keys when they do it as it's a 'learn all keys' rather than 'remove missing key' kinda deal 👍
Alloy question - Audi wheels on mk3
Compare the offset and width against your current wheels using something like https://www.willtheyfit.com/ Otherwise, check the PCD and centre bore also match
Uncoded Headlights
Can you post a full scan from VCDS or similar? Normally I'd expect 1T0907357 and 1Z0941641A to be fitted on a pre-FL car. The latter part is just a ballast rather than a control module and doesn't support being coded. It might be worth adding some pictures of your headlights and any modules you can see too...
Fogs/Sidelights as CH/LH Help
Seems I missed one. Anyway, there are three pairs and one single lamp output that are obviously set as CH/LH at the moment. Leuchte20BR LA71 and Leuchte21BR RC8 which is probably the rear tail/brake lamps: ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake lamp ,16 ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,not active ,16 ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16 ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Coming Home oder Leaving Home aktiv ,16 ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,not active ,16 ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,not active ,16 ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20,not active ,16 ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake lamp ,16 ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,not active ,16 ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,Parking light right ,16 ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Coming Home oder Leaving Home aktiv ,16 ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,not active ,16 ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,not active ,16 ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21,not active ,16 Leuchte23SL HLC10 and Leuchte24SL HRA65 which are probably the sidelights/DRL (same bulb?): ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16 ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Coming Home oder Leaving Home aktiv ,16 ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Daytime running lamps ,16 ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,not active ,16 ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23,not active ,16 ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,not active ,16 ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23,not active ,16 ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16 ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Coming Home oder Leaving Home aktiv ,16 ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Daytime running lamps ,16 ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,not active ,16 ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24,not active ,16 ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,not active ,16 ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24,not active ,16 Leuchte25KZL HA59 which is probably the rear license plate lights: ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,Coming Home oder Leaving Home aktiv ,16 ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,not active ,16 ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25,not active ,16 ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25,not active ,16 ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25,not active ,16 ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25,not active ,16 ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25,not active ,16 Leuchte26NSL LA72 and Leuchte27NSL RC6 which are probably rear tail/fogs based on translating "Nebelschlusslicht wenn kein Anhaenger gesteckt": ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16 ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,not active ,16 ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16 ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,Coming Home oder Leaving Home aktiv ,16 ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,not active ,16 ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26,not active ,16 ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26,not active ,16 ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16 ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,not active ,16 ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,Parking light right ,16 ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,Coming Home oder Leaving Home aktiv ,16 ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,not active ,16 ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,not active ,16 ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27,not active ,16 Given the choice, I'd start with: ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24
At a guess, I'd be taking a look at: ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 All are set to "Coming Home oder Leaving Home aktiv" and probably need to be 'not active'. Not sure if it just the first pair, second pair or both sets that need changing.
