Have I broken the stereo?
The headunits can be programmed to either use the internal amp or an external one. Pretty sure this applies to all MIB1/2/2.5 Bolero/Amundsen/Columbus headunits... The external amp is normally marketed as Canton and gives you some extra speakers along with a sub in the boot. Any chance car scanner can show the fault codes and current long coding for 5F?
Sounds like car scanner did manage to change something... Might be worth trying to find a VCDS or ODBeleven user to take a look? At a guess, you have an amp aka Canton? If so, it's not compatible with the surround/virtual sub coding so you should undo the change and restart the headunit by holding the power button for 10-15s
How to remove the DSG trim?
At a guess, it'll be the unused pin on the black connector... There won't be any solder as VAG don't solder connectors on. Instead, the wire has probably pulled out of it's crimp and the crimp is still in the black connector
Help with cd player please
I don't believe your car supports any USB CD drive I'm afraid 😞
Pedal Response improvement VCDS
At least based on some of the posts in this thread: https://www.vwroc.com/forums/topic/30625-i-know-this-sounds-ridiculous-but/ It doesn't seem the driving profile switchover actually changes the throttle response
VAG part number description
There are plenty of parts where the letter(s) at the end denote the revision but for something like shocks, that's not normally true. The F certainly doesn't mean front either... Instead, the FH will denote the variant which is likely to be a specific weight range and with PR-codes to match your vehicle build spec. Just as an example, these are some of the options listed from an online catalogue - the FH and FS versions are completely different diameters and certainly not interchangeable: @Carlston tends to know suspension part numbers so may have some insight? Personally, unless it's been obviously superseded, I'd stick with the original part number and definitely keep the both sides matching
USB port
Plenty of hits on google! For example: And this video: Or this one:
USB port
- Hello guys! Can anyone help me if this 2016 (reg 66) Yeti has DAB functionality please?
1) Possibly, press the FM button and see what happens 2) The best way would be to swap the headunit for a DAB version, I've no idea if 3rd party solutions exist 3) It's a Bolero, more specifically a MIB STD2 PQ style Bolero 4) Smartlink can be activated by a dealer, you'll only get Android Auto and Carplay if the build date is after May 2015 If you check the system information for a part number, that'll help answer some of your questions- CD Drive plugs and connectors
The 'cd drive' is the headunit whereas the display side is just a screen with a touchscreen If I remember correctly, the connectors are: - white fakra for AM/FM - black fakra for DAB - pink fakra for the screen - yellow fakra for the USB port - blue fakra for GPS (not fitted above) - purple fakra for GSM (not fitted above) The quadlock has connections for: - power/ground - CAN-bus - speakers - microphone - a few other things depending on equipment You'll need to run most of those wires to your new headunit so maybe consider getting a quadlock extension or similar to make life easier- Completely confused by amundsen connectivity
There are various technologies at play here, such as: - Mirrorlink - Android Auto - Apple CarPlay Depending on your phone, it may support one or more of the above to connect with the radio in your car. To use them, you just need to connect your phone with an appropriate USB cable and follow any onscreen setup instructions. You should then be able to use various music and navigation apps from your phone on the radio display. Skoda tend to group the above together and call it Smartlink. Smartlink+ is an extension which means if your car is connected to wifi or a 3G/4G modem, it can report various stats back to Skoda including fuel level and fault codes. You can access this data either via the MySkoda app or the Skoda Connect website. Skoda Connect are the online services which allow news, weather etc on the radio. Again, it'll need an internet connection and there is also a yearly fee to use it. Personally, I feel Skoda Connect and Smartlink+ are pretty useless. I use Android Auto via Smartlink all the time and it's great- DISABLING FOOTWELL LIGHTS - MK II 1.6 SKODA SUPERB S TDI CR 2012
Pretty sure the footwell light fuse is also used by some exterior lights so no, it's not that simple afaik...- How to clone Amundsen navigation card to larger capacity SD card
I assume that's a 2018 so it'll have a MIB2/MIB2.5 Amundsen fitted. In which case, yes, the only check is the CID is valid but this only applies to the navigation SD card. For music, you can use any SD card and given it has two SD slots, have both the music and navigation cards in at the same time- How To - Reverse Camera Fitting Guide
I used the more expensive OEM version to get that factory feel. I don't like the fact the Chinese one can recode modules to install itself.... I'd much rather do that myself- How to clone Amundsen navigation card to larger capacity SD card
What kind of Amundsen is this for? Your profile suggests a MK2 Octavia but I think you've sold it...- Retrofit Rear Camera Skoda Superb III MY18
Some camera's have a little washer jet attached: When you activate the rear window washer jet, it'll also spray water on the camera lens to remove dirt/grime. it's not 100% effective but tends to work relatively well if the car isn't completely covered in dirt- DISABLING FOOTWELL LIGHTS - MK II 1.6 SKODA SUPERB S TDI CR 2012
Then you only have a basic instrument cluster so you won't be able to change the footwell brightness. You'll either need someone with VCDS or similar to do it for you or remove the bulbs- Amundsen+ DAB issues
Can you post an autoscan so we can see what's what?- Retrofit Rear Camera Skoda Superb III MY18
Assuming you fit an OEM camera, it should be pretty much the same as my 2018 Octavia. Coding is super simple and OBDeleven should easily be able to do it. More details here: https://www.briskoda.net/forums/topic/485897-how-to-reverse-camera-fitting-guide/?do=findComment&comment=5456364- Amundsen MIB2 Firmware Update
It also says connect a battery charger... I wouldn't want a battery charger connected to a running engine. I expect the battery charger instructions say the same 🤣- Bluetooth not working on Bolero
Might be worth posting an autoscan @SKD_VRS to give an idea of any fault codes and how your car is configured...- Amundsen MIB2 Firmware Update
If you have VCDS, OBDeleven or similar, then yes, I would sort the code as it only takes a few minutes. If you don't own anything to fix the code, I wouldn't worry about it- DISABLING FOOTWELL LIGHTS - MK II 1.6 SKODA SUPERB S TDI CR 2012
Do you get an image of the car outline when the doors are open, much like this:- Amundsen MIB2 Firmware Update
The 2049459/10 TPI from Skoda states: I expect the reason is to reduce the chance of a voltage spike/drop causing corruption during the update procedure. There is probably a newer TPI for the 0480 update but I've not seen it yet. It's your headunit so if you want to update it while driving you can, personally, I'd follow the instructions- Mk3 FL LED Headlight Brightness
You can use the adjusters on the headlights to lower them slightly: I'm not sure it'll help though. LED headlights have a very sharp cutoff so if you're on bumpy ground, it'll look like your flashing the car in front... High beam assist should be easy enough to enable, I've done it on my vRS and I'm happy to take a look at yours depending where in Norfolk you're based - Hello guys! Can anyone help me if this 2016 (reg 66) Yeti has DAB functionality please?
