Aftermarket fit of raised boot floor
One considerable advantage of a DIY raised floor is you can increase the load rating - IIRC, the OEM one has a weight limit of 80Kg.
Mk3 Octavia scout cambelt change
@indars are you able to share the condition of your friend's cambelt and tensioner?
Parking light
I'm assuming that you mean the 'marker' lights (switch position immediately after 'Auto') - commonly called side lights, is that correct?
Do the testers even check for a spare wheel nowadays?
Assistance from Australia
You might find it quicker and more comfortable to adapt your driving style - consistent late braking is almost certainly not the fastest way around a corner, why not try - set up the car on the run into the corner, follow the line through it (within your lane) and then accelerate out?
Harder pad compound delays the onset of brake fade (where you run out of braking force due to overheating) They also have the property that once the brake material has been correctly conditioned, the pad (or lining) maintains a fade resistant surface when consistently used firmly.
Parking light
Or indicator stalk UP if parked facing traffic - although that is not legal at night in UK.
I'm still struggling to understand how fitting soft pads help braking with your normal driving style - if, as you say, you are 'heavy' on braking, how do brake pads that are more prone to fade help? Wouldn't harder pads (similar to the old DS11 compound) work better for your style of driving?
the truth about electric cars
I can't see that flex cable standing up to traffic, bet it's not fed off an RCCB either.
Car wont turn over - glow plug fault code
I strongly suggest that you get the battery load tested. Multiple fault codes is often an indication of a failing battery.
- Front assist
Key fob not unlocking driver's door
Hello, welcome to the forum. Does the drivers door lock when the internal lock button on the console is pressed?
Hello, welcome to the forum. I'm a little curious - you say that your usual driving style is 'heavy' on the brakes and normally switch to softer pads - don't you find the softer pads suffer more from brake fade? Road behaviour of your roos sound much the same as sheep on back-country roads in NZ.
1.5tsi ACT cambelt change interval revision?
How old was the TDI at 93K. Was there much damage to the top end?
DRL bulbs
The very valid point that unless the LED replacement has been fully tested and certified as being compliant, there is a distinct possibility of dazzling other road users. Certification is critical, I can't imagine anyone would countenance purchasing, say, a child's toy that may have been coated with leaded paint - or an item that contained asbestos.
DRL bulbs
In which case, the manufacturer should not have an issue in obtaining the necessary certification for them - have they done that?
That would be almost impossible to quantify IMO, but I'd think that the interval difference would be minimal compared to the belt running all the time. I can't see the inertial strain of the cam drive on start-up being significant.
A new user looking for information about Skoda
Hello Simon, welcome to the forum. I'd think it can be summed up in one word - very - although my Octavia is the 1.4 version.
DRL bulbs
I believe the issue is that reflectors and lenses designed for incandescent bulbs are not correctly focused for LEDs - which will often cause unacceptable light scatter/glare.
No Drive to Wheels
I believe that something like this was reported recently - I think a snap-ring locating an inner driveshaft had been damaged.
Clutch and Flywheel Replacement - 2.0 Diesel 150bhp manual (2016)
Ask for independent garage recommendations from members in your area.
Hello, are you aware that VAG have revised the cambelt replacement interval? - IIRC, it is no longer fixed at 5 years. There is extensive information on other sections of the forum.
1.2 Tsi - what is this part and how to remove rust from it?
I'd take a guess that it's a fuel pump driven off the camshaft. Just checked on Google - it's the high pressure injection pump.
Spare wheel kit
Cheapest would probably be a breakers. Nut cover removal tool etc. can be sourced from Amazon or the 'Bay. Rather than packing an impact wrench, why not get a breaker bar and socket - or one of the extending type wheel braces?
When to replace battery?
Actual manufacturer of battery is not critical information - EFB or AGM, capacity in AHs, and a minor change to the existing serial number sequence (to tell battery monitoring unit that the battery has been replaced) are all that is necessary.
