EPC and MIL light on
2018 Fabia 1.0 TSI 110PS, 24K miles. Wife came home this afternoon and reported amber EPC light on, which resets when engine is shut down then restarted. Went out to check, EPC lights up on switch-on, extinguishes on engine start - so far, so good; started engine, no warning light but EPC warning lit up immediately when engine throttled-up in neutral, light resets if engine shut down then restarted. Took it for a test drive, MIL and EPC lights both came up straight away, engine appears to be running completely normally, no misfires. I have not plugged in OBD reader for DTCs yet - will do that tomorrow if weather permits. Car is booked in for diagnostic on Friday, I'm thinking faulty MAF sensor might be a possibility - but does anyone have thoughts on possible causes?
Cranks but no start after spark plug change
OP might have been very very lucky in avoiding valve damage.
Rowers - can a set of rowing (sculling) blades fit in the Octavia estate?
I'm wondering if that's a misprint - the length of the hatch trunk is shown as being 34mm longer than the combi.
Battery replacement
A BEM code is not necessary, a new serial number can be created by simply changing the last digit of the original number. This will serve to inform the BCM the battery has been replaced and clear any logged battery defects that may be limiting alternator charging rate.
Ea888 crank pulley bolt
Perhaps it was not necessary to remove the crankshaft sprocket - does the manual specify that the sprocket needs to be removed to replace the cam chain?
My car doesn't blow hot air
The charcoal filter version type do look pretty dark when new. For the price of a new, OEM cabin filter, I cannot see any worth in cleaning an old one.
Windscreen washer, if and where… AU
Hello, welcome to the forum. If you have Williams car products available in Oz, I can recommend their screen wash, either concentrated or premix.
Confused about Timing belt change interval.
Hello, welcome to the forum. Assuming your profile details are correct, you have a non-ACT engine - that quoted price would be too high even if you had the much more complicated ACT engine. Strongly suggest checking with an independent specialist - or at least a comparison quote from a different Skoda garage. What engine (size and fuel) do you have?
K0diaq 190 overheating
I'd suggest checking if the radiator cooling fan is working first.
No Cruise Control
Great price for AGM, shame about the cost of adaptation - swings and roundabouts I guess.
No Cruise Control
A bit steep for less than 10 mins coding, but not a bad price for the battery - was that an EFB or AGM? Did replacing the battery restore CC?
Replacement Battery
Unless your vehicle is fitted with Stop-Start, a normal, flooded lead-acid battery is usual. There can however be advantages in fitting an EFB or EFB+ battery for improved performance and life.
SUPERB 4X4 2012 ESTATE DOOR LOOCK SWITCH
Are you aware that to do so is illegal in UK?
Cybertruck!
Is that quoted price tag of £48K a misprint?
Spec needed (not on Erwin), Battery health & charging speeds
18% loss in less than 3 years would be of some concern. Probably impossible to discover- but I wonder if the battery has been abused by constantly charging to 100%?
Help - Told Engine gone, any advice appreciated!
Very difficult to say without knowing if oil pressure has failed for some reason. Engine can be rebuilt, but labour cost is likely to be fairly high, depending on how much damage has occurred - especially if the reported noise is due to damage caused by lack of lubrication. The red 'Oil Can' warning light should show every time the ignition is switched on - then extinguish almost immediately the engine is started - are you sure that this warning light does not show up? The start up warning light test sequence is critical, anyone driving a vehicle really needs to be aware how important it is to check them every time.
Sorry to hear of your problem. Has the low oil pressure light (red) been seen to be lighting correctly when the ignition is switched on - and going out after the engine starts? Has the car EVER been run with the red oil pressure light showing? Are you in the habit of physically checked the engine oil level on a regular basis?
Wet Timing Belt
1.5TSI EA211 & EA211evo cambelt is definitely a dry belt. The change, when specified, is more expensive than the 1.4 (also a dry belt) because there is apparently more work involved with this engine.
Vcds lock doors with engine running?
Hello, welcome to the forum. You haven't posted your location country - but don't do this if you are in UK.
Bizare end for my trusty 2011 Roomster....
More likely sequence of events is the alarm activating after some sort of electrical fault dropping the battery voltage. The alarm has its own self-contained battery that will operate the sounder if battery voltage is removed while alarm is set.
Skoda Fabia 1.4 MPI SE 2012 - start up and stalling issues
Hello, welcome to the forum. Did this problem start shortly after fuelling? If so, fairly rare, but it's possible you have picked up a batch of contaminated fuel.
No Cruise Control
New battery requires to be adapted (coded) into vehicles BCM if you have automatic idle stop (Stop/Start) and if ANY details of its specification are different to original battery. Coding is also advisable to inform vehicles BCM that battery has been replaced so that any recorded battery defects, that may be limiting charging rate, are deleted.
Major Fuel Leak - Due to bolts shearing on the fuel injector rail assembly
The response I received from DVSA was dismissive! In the reply I received, they stated there was considered to be no risk of fire from this type of occurrence, due to the lack of any ignition sources!
Amazing Fuel Efficiency 1.5 Petrol Estate
Agree ^^^ TC boxes have come a very long way since the old GM Hydromatic.
There is an Aisin 8-speed torque converter gearbox used in some markets, including North America and Australia. AFAIK, on 1.4 TSI, non ACT engines.
