Everything posted by UndertheRadar
280 spark plugs
I just fitted a set of the OEM plugs to my 272 as a lot of tuners I contacted say, even at stage 2 say they are more than capable of running the extra power. At this point I’ve seen no indication from my own car that, that is anything but correct.
Front end creaking.
5Q0407183F
2023 Superb 280tsi DQ381 mapping
DQ381 with revo software for the box and a pedal box. Makes the car a bit more likely to be in the correct gear, but my usual lazy mode driving still causes the box to be too high when needed on the odd occasion. A lot better than the factory settings, and I can actually use sport instead of extra throttle to be in the correct gear for boost without a heavier throttle causing the sudden lift your speaking of. it’s not perfect, but it’s better than the fuel economy chasing settings the OEM software runs, where I constantly found myself in 7th at 30 and a bit mph with a box that was reluctant to change down on a light throttle input for say, a slight incline.
Front end creaking.
Try spraying the anti roll bar bushes with silicone spray and test car. If still there, spray the bushes in the lower arms and test again. Should help narrow down which bush is causing the creak.
Superb MK3 2016 Jerking between 2-3k Rpm
APR do a decent reliable coil pack if you need them rather than OEM, if it’s still there after the plugs are changed.
Plugs or coils was my first guess. sounded like a plug or coil breaking down under load. It’s also similar to what the focus RS does when it damages the BCM. I’d start with a set of OEM plugs though.
Skoda superb sportive estate 2023 suspension to soft
My DCC was tragic at best from factory. As poor a suspension as I’ve ever had In any car I’ve ever driven. Replaced with bilstein, same as others on this site have done, and it completely transformed the car. mine would crash and bang over the slightest bump in the road. Even after being replaced under warranty, the new shocks still had the same characteristics. Small bumps had the impact of a head on collision and felt for sure like the wheel was definitely damaged. on several occasions small bumps that my wife’s focus ST drove over with no noticeable concern, actually hit one that hard the glovebox banged open. The same roads now with the bilsteins are a breeze and the crashing and banging is completely cured. OEM shocks on mine were monroe, if you want to check and see what’s fitted to yours.
Post your Detailing Product or Gadget Recommendation here
Recent purchase and a great piece of kit for getting all the crud and salt off the underside of the vehicle during the winter months. Very simple and quick to use. This one is well made and seems a decent enough quality to hopefully last for years.
Superb 4x4 2.0TDI drivetrain movement
Did you fit upper and lower inserts or just lower, and did it add any NVH?
Replacement passenger front speaker
Hoover the door out so you don’t get any rattles after drilling the rivets.
Frozen windscreen washer jets retro fit heated ?
I’ve heated washer jets and the lines can still freeze. Best to just use a really good winter additive at the correct dilution.
Service Guide?
I do an oil and filter and a pollen filter every year. every other year I do that and the air filter and check coolant. brake fluid and haldex every 3yrs (pump removed and strainer cleaned) dsg service and plugs every 4yrs i do low mileage, so haldex and dsg were both done between 20-30k. I prefer preventative rather than necessary maintenance and I’m happy enough with the additional costs of doing so. That however is up to each individual owner. Should have said, I removed my silica bottle for a genuine non silica bottle as soon as I got the car, which was at about 4 months old. Hence the check coolant every 2yrs as above.
What USB cables do you use to connect your Apple device?
Anker.
How to play music
If you have an iPhone I just use Apple play and control everything like selecting music tracks or albums etc using Siri. I have my entire music collection on my phone so it’s just an all round handy feature.
- 1st SKODA a cloaked GOLF R - WoW
Superb mk3 estate suspension
Bilsteins all round on mine. Great drive and no issues.
2017 superb estate radar
Recent weather may have had an effect. Mine sometimes disables on really bad road conditions, normally from debris getting splashed up against it. Leaves, mucky water etc. Normally either a wash or standing overnight brings it back on again.
Brake pipe leak
At least your sorted and back on the road safely.
Kessy Battery Life
Personally, I just replace the battery in the key every year when I service the car. costs very little and I can forget about it for another year.
Classic cars 80's/90's untaxed for over 20+ years then become SORN.
I have two cars declared sorn at the minute. They have been sorn for quite a while. I declared them sorn once, and they remain that way until such times as I want to tax them again.
Whistle at idle
As above. Whistle at idle on a warm engine. noise coming from down the front of the engine. No distinct variation in pitch when applying slight revs. assuming water pump from previous experience, but haven’t really investigated as to be honest I haven’t got the energy at the minute.
Noise when driving over speed bumps with light braking applied
On my phone that sounds like more of a rumble than a creak but it could be my audio/ability to hear it properly. rumble most likely top mounts on front struts. creaks either bottom bushes or anti roll bar.
Installing a dual dashcam?
Using Blackvue 750s 2ch. No issues and doesn’t stand out on screens when fitted. View on phone rather than screen on camera itself, so blends in far better and doesn’t distract at night.
Best dash cam ideas
I use the blackvue 750s 2ch in our cars and they are fantastic quality, even at night.
Body camera recommendations
Thanks. Nolan’s involved, as is the likes of Belfast live and a few others. None are able to get into it with the investigation ongoing.
