Everything posted by Danoid
That’s what I bought after you mentioned it, very good product. Now and again I give my car a snow foam jobby and beads again nicely Lasted about 6 months then reapplied which is good enough for me
Skoda clutch advice
What’s the mileage? Hopefully it’s just a case of getting use to it I think the test for testing if a clutch is bad is to pull away from 3rd gear, if it doesn’t stall then the clutch is bad
A/C not working
Parts and labour, the wording for the quote was complete high pressure pipes, and they just done the one, which is why I moaned
A/C not working
Oops I didn’t update the thread, so what Skoda changed on mine was the large pipe going from behind the coolant tank to the header tank and that was almost £1k pfft The small pipe near the front still has some oily residue so I went back to the “executive” team and they organised for my car to go back and be checked, went there and the Skoda guy just shouted at me (short man syndrome) and didn’t check it like executive team asked went back to executive team and got it booked at a different garage who checked it for free and no problems, still oily to this day but ac is perfect. I then got a call from executive team and gave me a £500 voucher, so they probably finally figured out the original garage shouldn’t have charged me near £1k for a £250 pipe and Skoda workshop estimates 1 hour to change pipe not 4… I’m still not sure how the gases hit me from the front pipe if it was the back one, weird
EPC indicating turbo underboost
Might be worth trying an Italian tune up if you can do it safely and see if it reoccurs
Will Passat Weathershields Fit?
Are you on about wind deflectors? Plenty of them come up if you use that wording “Skoda superb wind deflectors” Bit old school now because of A/C but each to their own
Audio control knobs
Must admit I’ve got ocd when it comes to the power logo being the correct way up so mines pointing the correct way up and I only use steering wheel controls for volume
Melted Mess !
No I mean there should be one, can’t imagine you’re the only one and pretty sure anything which can potentially cause fire is recall worthy. I don’t think dvsa or vosa accept reports from people which is wrong imo
Melted Mess !
Looks like recall worthy to me
hesitant and uneven start
You should have changed the ah at least as most aftermarket’s are 70ah compared to 68ah and the bem serial
Cannot refuel!!
On my old Passat there was a funky button you could press to vent the tank to get a little more in. Not sure if it’s accessible on a Superb but I wonder if your vent is kaput which is stopping you filling up
Ignition Live/Permanent live 12V sockets
Ah it’s the boot one I’m more interested in but not sure it’s possible, to be honest like you said the front is possible and I’m sure others have asked and it wasn’t. Unless it’s different years can do it, mines a 2016, what’s yours?
Hmm was this the boot one you changed?
Damage to rear bumper and a rear light cluster- Any advice?
My local VW dealer is part of a franchise and they have their own body shop, do anything VAG and even come out to do quotes for free. If your local Skoda franchise isn’t good check your nearest VW and even Audi
Have you got vcds etc? Need to change some things just in case you weren’t aware
If the battery is original replace, others have replaced on newer cars already, mines a 2016 and needs doing as it isn’t going to last in winter for sure
New Superb Mk4 estate owner
Where’s your pictures? 😁
Finally managed to use the wood batten from my old summer house as a test to use in front of my Halfords ramps, it was successful but sketchy in an auto even with auto hold off Without the wood the front bumper would touch the ramp, now it’s all good I can finally start my own oil changes, some other day…
- Air Quality Sensor Faulty
speakers
- speakers
Someone else recently had the same issue, it was the plastic behind the speakers which broke Pretty sure he reckoned it could be caused by the doors closing and over the years just broke if i were you I’d remove one door panel and speaker and investigate, if its had it then get new ones, if they’re fine then not sure- DPF Regeneration every 50 miles
I’d go back to them and say oi- What have you done to your Superb III today?
A while ago I somehow broke the spring on my 12v flap socket in the boot Tried to fix but no chance so £18 lighter for a new one and all installed Horrible job half the plastics had to removed and even more because I dropped the screw for the 12v down so even more plastics had to be removed, blew a fuse when i undone the screw n all Too hot to work so I hate cars again, but it’s all back together- !!!NEED ANSWERS!!! Skoda Superb 3 Headlights
If I were you I’d just fit LED bulbs in your current lights. By the looks of the houses you’re not in UK so you might be in luck Have a look at https://www.osram.com/ecat/NIGHT BREAKER H7-LED-LED lamps (street-legal)-Car lighting-Automotive/com/en/GPS01_3401765/#products There’s a list of countries in Europe where fitting these is legal and the Skoda Superb with halogen housing is on the list of approved in quite a few countries but check the link- TDI Official Oil Consumption Limits
Oh didn’t realise you’re still under warranty, they’ll most likely say that, if you were paying for it all they’d find something, feed them some small lies like you can smell oil - speakers
