Everything posted by Danoid
To change or not to change (brake disk debate)
I’ve got the 6 speed, unless it’s different on 7 speeds. When I leave my house, just before the junction I begin to let off the accelerator the cars already slowing down and barely need to press the brakes If I do the same thing with eco on and coming to a slow stop I’ve already been applying he brakes for a good 5 seconds. If I do that for the rest of my journey by the end my discs look brand new again
If you’ve got a DSG it’ll use engine braking or DSG holds the revs (not 100% sure) but when you put the car into eco it does a lot of coasting, so when you apply the brakes you need to hold down for longer, which then clears the crap off the rear a lot better. I make it a habit to engage eco at least once a month just to clear the brakes up. so basically with eco on, you’ll be coasting more and able to apply the brakes for longer
If you have DSG, put the car into eco mode and it’ll bring the rears to life. I had my rear disks changed to brembos because of the padding but OE pads done by my local Skoda dealer
Additional Jack Points
The correct lifting on a 4 post is the sills believe it or not
Multiple low voltage warnings on cold days yet starts no issue (car just serviced)
I’d be more inclined to change the battery if you use it every day and still got the warnings. I started my car the other day and got the 12 low charge by driving, warning but I expected that as it was very cold and don’t think I used my car for a few weeks. When I saw that messaged I drove a long route and near the destination I enabled stop/start and it worked fine
I saw UKCA on something earlier too, so I’m not sure if it’s some new logo that’s meant to mean something, I’ll have a google. The both chrome ends jobby looks good but I’m pretty sure that’s for keyless only, but I have the old school (which I prefer) flip key
Finally got round to changing my spare key “cap” interestingly from 2 years ago it’s a new part number with even more icons 😂 2 years ago end cap 2022/23 version but so much better than original New part number of anyone wants it and it was larking £18
- Air Quality Sensor Faulty
Purchased a 2018 Superb Estate 2.0 TDI 150hp DSG (7 speed)
Personally I’d just enjoy it as everything seems to be done
Xenon Headlights - Poor Range
This is fairly common on here as people have manually adjusted the headlight up which I might need to do after fitting new bulbs as the OE bulbs are rather crap to be honest. As it does the dance and stays up that’s good as there was a software fix for some people’s cars where it does the dance but stays down on one side. A few weeks ago I had really bad light output on the left, I thought it had stuck down on mine (my car not affected for software according to Skoda) but I did set to driving mode Eco which then disables cornering function, so I stopped and turned the car off, it done its dance but was still low on the left side. I then used my washer and it cleaned the headlight and was fine. So give that a go next time or clean the headlight yourself. If that doesn’t help, it’s possible your light is affected by the software glitch or even the self levelling arm has broken but I’m not sure if that would through an error on the dash
Fumes in cabin
Ah that’s a shame the pollen filter hasn’t made a difference. If you let your car idling on your drive do you smell fumes then? If you do that would suggest a breather hose but on such a new car I’d like to think that’s unlikely. You can always get an AC bomb cleaner and let it do it’s things. Theres still the potential of there is no smell and you’re imagining it, especially as no one else can smell it 😬
Fumes in cabin
Get this https://catalog.mann-filter.com/EU/eng/catalog/MANN-FILTER Katalog Europa/Vehicles/CARS %2B TRANSPORTERS/SKODA/Superb III (3V)/2.0 TDI DDAA, DFCA (T00000000332484)/Cabin Air Filter/FP 26 009 Also if you have a decent code reader use it and you might find a faulty sensor (air quality?), I’ve seen on here a few people’s air quality sensor has failed. What it’s meant to do is when it detects fumes it puts recirc on automatically or something like that. Cheapest way is changing your pollen filter to that one, but double check it’s the correct one for your car, it is for mine so should be. Or this might sound crazy but you could even be getting covid symptoms, my smell went haywire before I fully came down to it and fumes/smoke was exactly what I could smell the most when no one else could
Quite rapid coolant loss after recent cold-snap
There’s this thread too with a video posted few more angles on that video which you can check and you’ll know if it’s the same issue as you hopefully
Ah that’s somewhat good to hear you can see it. If you won’t be fixing this yourself, you can at least show a mechanic where you can see it leaking from. Id also now get it booked in, top up before you go there but don’t use the car in the meantime
I’m not too familiar with the 1.4tsi but I just found this Have a look round yours and see if you can find it, it’s very obvious on his because of the pink coolant. I’d say aslong as you can see coolant you’ve hit the jackpot and by that I mean it’s not a head gasket or matrix. His accent is funky but sounds like water pump is not belt driven which is good at least
Judging by some others on here it could be leaking at the water pump. When did it last have the cambelt + water pump changed? Personally I’d put a UV dye in the coolant system and go hunting at night with a torch and glasses, as it could be a pipe aswell
DRL advice and options for 2016 Skoda Superb
Have a check at your laws in Australia regarding DRL. As your car is 2016 you should be able to turn them off and it’ll pass. In UK only cars from 2018 have to have working DRL. I’d imagine Australia is similar
This weekend I will be mainly....................
I’m sure I’ve read water usually comes in from light cluster or the boot seal itself. Cant remember reading if the light cluster has a replaceable external gasket or just taking it off and cleaning it is the fix
Discovering AFS headlights after installing LED bulbs
This is the blurp from the government site https://www.gov.uk/government/news/end-of-halogen-light-bulbs-spells-brighter-and-cleaner-future This is for the Osrams, others are the same where they provide such info like Philips https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwjMltP93J_8AhUKQEEAHT1NAJkQFnoECCEQAQ&url=https%3A%2F%2Fwww.osram.com%2Fappsj%2Fpdc%2Fpdf.do%3Fcid%3DGPS01_3043435%26vid%3DPP_EUROPE_Europe_eCat%26lid%3DEN%26mpid%3D&usg=AOvVaw0tuav8lPjPSjU2Up6x_-V2
It’s not just about the draw they use, it’s the materials needed and the waste they produce. Look at any high performing halogens for cars, it’s around 200-250 hours and that’s when failures are most likely to occur. Judging by your replies are you anti led? I don’t really understand where you’re coming from
Yep 😞
The same rules still apply in the other European countries, it’ll just fail their MOTS like ours would. With those Osrams as they’ve been designed for on road you won’t get all the glare of the cheap ones but that ultimately comes down to the people who chose to use non street legal leds. You don’t need to change the headlight either to fit them. There’s no difference between our headlight in this country compared to a superb sold in Germany (other than lhd/rhd). We just need Vosa to pull a finger out Its funny our government recently made it law that halogen bulbs can no longer be sold from September 2023, except for car bulbs which is the biggest waste there is as some only last as little as 200 hours
Would you take a Superb estate over Passat estate if Passat is cheaper?
I’ve had two Passats b5.5, I was looking into getting the B6 and so many issues, so I just stuck with my B5.5 for a while and went for a superb. Im not sure I’ll go back to a Passat again to be honest. I see no reason to get rid of my superb for at least another 7 years. By then it’ll all be electric only (new cars), by 2030 petrol/diesel/hybrid will be seen as the anti Christ. Who knows what my next car will be then but Skoda has my loyalty for now so probably another Skoda. All my cars so far have been taxi cars Audi A6, VW Passat and Superb. So whatever is used as Taxis in 2030 and German will be what I’ll get most likely haha
I meant after market ones, the new Osram night breaker leds are road legal just not in UK They do have a list of cars they’ve certified them on and the superb is one of them, but it would be for halogen headlights as that’s H7/H4 https://www.osram.de/am/night-breaker-led/night-breaker-led-ledcheck.jsp?mkt=/nb-led/ https://www.osram.com/ecat/NIGHT BREAKER H7-LED-LED lamps (street-legal)-Car lighting-Automotive/com/en/GPS01_3401765/ Osram led compared to NBL xenon https://youtu.be/SYBMbS0rES4
Hopefully one day the UK VOSA will wake up and allow road legal (in a few other European countries already) Do you disconnect the ballast to put in the LED bulbs?
