Valve stem seals gone after head gasket repair
A compression test would be irrelevant if the valve stem oil seals need replaced. Compression occurs with the valves on the cylinder which is compressing closed and the oil seals are on the top of the head, not exposed to the compression. Does the engine give blue smoke on overrun and/or first application of throttle? I'm trying to figure out whether further internal damage or oil seals are more likely from first principles diagnostics.
2021 Kodiaq RS - Towbar
OK, for the thickie. If the OP's car is not plated for towing, it is illegal to do so, and fitting a towbar is a waste of time and money, and a possible driving ban if you're caught towing with it.
To XL or not to XL
You're still omitting the load index and speed rating , which are pretty vital here. As a generalisation you can not fit a lower load index than factory ( @xman indicates 94 was standard).
The question is not "is this mechanically possible?" but "is this model plated for towing?"
To XL or not to XL
No and don't know since you've omitted all information about the tyres except that they're "eXtreme Load" version.
Citing ABS and Tracking lights are ON. Stop-Start stopped working.
Easy answer - butter his paws to stop him running away, as per Thelwell's Magnificat!
Towing with a skoda superb?
Great if you don't want to take any tack, feed or bedding in the trailer.
- Door Locks
the truth about electric cars
The EV Operators' Bromance Thread?
Random Thought Time: Why no 7 seater option??
In a standard wb Superb estate, the 3rd row of seats would be in the rear crumple zone; the CX Familaile has an extended wheelbase even relative to the CX Pallas, which brings the 3rd row of seats inside the wheelbase, and leaves some luggage space behind them.
Shout out to Skoda owners
For a tug I'd actually suggest a Kodiak, but make sure it at least has towbar preparation if not a factory bar. Less serious suggestion would be a Toyota "Technical", preferably with a pedestal mounted Browning 0.50 calibre on the bed.
New start/stop Yuasa battery not recognised.......Octavia 2 Bolero will only play with running engine despite new battery. Why ?
Has the new battery been "coded in" to the car so that systems know it's a new battery and not the old Varta?
New Yeti Owner DPF Question
Well, at least the snake oil is clearly doing something this time.
- 1.5TSI Slave Cylinder/Clutch Issue
CUNA heavy oil consumption after engine rebuild
@rares Given the recent rebuilt, my first thoughts are of a seized or broken piston ring, probably an oil control ring.
Yeti 1.2 2016 "gearbox overheated. Stop!" - engine warning light
@Tien As @Austin 7 implies (but doesn't actually say) VAG cars have a track record of generating multiple spurious fault messages when system voltage is low. In this case you have one that clearly appears spurious (because it refers to overheating on a cold transmission), but if it is deleted and recurs on next start, then you do have some sort of problem.
2.0 VRS Diesel BMN Cam belt snapped
It's a diesel; valve(s) will have contacted piston(s). An inspection will be needed to determine the extent of the damage.
replacing rear swing arms alignment?
Only if the tapping for the threads on the new arms starts at the same azimuth angle as that on the old ones. I give you roughly 1/360 that this will be the case.
Skoda octavia mk 01
That suggests an engine sensor issue to me; the instrument cluster only receives data from the Engine Management Unit (EMU). Your best way of checking this is to find someone honest who can use a diagnostic computer, preferably a VAG compatible one such as VCDS or OBD II.
Brake pads replaced after 50k - reasonable distance ?
Someone who does not have a track record for misrepresenting the facts; I have seen "80% remaining" turn into "80% worn" between the mechanic's job sheet and the job invoice.
Can I fit 15s on my MkII 4x4 CR TDi ?
@Mart160plus @Schtum - As a generalisation I would expect genuine VAG 16" wheels of the correct offset to fit over 312mm discs.
Exactly why? The system is called "cruise control", not "automatic hand braking".
Alarm going off after locking
Er, that's what it's there for! As @varaderoguy says, with the added note that I use a keyboard vacuum powered by 2xAA cells (also for cleaning keyboards, PC vent grilles...)
Rob's Ur Quattro
It would bug the H*11 out of me, not because the view doesn't do it, but because there is no sign of road workers to be protected!
Guess the Hire Car.... Mac's 2019 game
A Cupra?
