Amundsen MIB STD2 infotainment system with Android in Superb II
On 13/09/2019 at 23:41, KMDTHY said:
Does anyone know which RVC i should buy. I would like dynamic lines and the model with sprayer to clean the camera lens. Thanks.
There is no OEM RVC high (i.e. with dynamic lines) with sprayer that is compatible with your car as all such cameras are built into 110mm wide trunkc handles and yours is only 90mm. So either you have to cut your trunk lid to enlarge the trunk handle hole or use aftermarket RVC.
Also pls not not all PDC / PLA controllers installed in Superb Mk2 are compatible with RVC.
  • Replies 398
  • Views 167.6k
  • Navigation works with no issues:   Media Player:   Radio (DAB+)   ANDROID   Smartlink is not active (at least yet) :(   Voice commands work OK   Bluetooth HFP works OK
  • A short movie
  • williamshatnerspants
    Looks awesome. I am still trying to get Iron Maiden to play in our car, by have come up against a WIFE1 issue. Seems to work fine when I remove that from the car though.
I'm a owner of a Superb II from 2010, i'm currently using a RNS510 and wanted to change it to some VAG OEM radio unit with android auto support... from your experience on this case what model should i search and buy?
Write to pab567 and quote for a price for a MIB STD2 unit that are reworked and ready for your vehicle.
I am willing to cut the trunk handle to 110mm 🙂
thanks @KMDTHY!!! Didn't know that we was selling...
Pablo have my recommendations. Bought one few years back 🙂
My car Škoda Octavia II 2007 swap to 2012 ☺️
  • Gateway 7N0 907 530 BL
  • BCM 1K0 937 087 D
  • Dash 1Z0 920 843 T flash to fw 1028
  • SoundSystem 5C6 035 456
  • PDC 1K8 919 472 flash to 1K8 919 472 C
A1356668-76BB-4151-93BD-AE002A685A40.thumb.jpg.212f68f11368289bbf24ca2634fe3fbd.jpg 7B53E5CD-BCA1-4C20-A934-727474A8C4A3.thumb.jpg.07a1226f02edc4a4647274c132b1bc4f.jpg
  • RVC from O3 with sprayer to clean the camera lens
camphoto_1804928587.thumb.jpg.a50ab7343c5d5766620c782b164cd579.jpg E74EA949-4757-42C1-BBE6-C4C61EED96C2.thumb.jpg.4d0c6343c91dc84e02f9ae93b10b9af1.jpg
Very similar setup to my YETI :)
With some effort, other car pictures are also possible. One can put there FSO Polonez Leisure as well :)
How? :-)
On 06/10/2019 at 21:47, plasmo said:
How? 🙂
Well, you need to get write access to the internal filesystem of unit. Once you get it, you can alter desired graphics. Search for "mib std pq emmc" on Google.
It's not that easy, but doable.
Hi I have the rns315 Amundsen+ in my 2014 superb can anyone tell me if the 2015 yeti discovery media dab unit would be a straight forward swap. Many thanks
Yes.
7 minutes ago, untaztood said:
Yes.
Thanks for your reply I have noticed under my driver's seat is a Bluetooth module which I thought the Amundsen+ had built in Bluetooth ? Also would it just be a case of pull the old unit out and the discovery would plug straight in or would I need any other wiring ?. Thanks again
Hi guys, just received 5K7035200G, but it just shows logo for like 30 secs and then reboot again. Can you tell me, what can be wrong? Thanks in advance.
  • 7 months later...
Some more pictures of the latest development. As you know SKODA has never launched MIB STD2 PQ with software 04xx so I decided to do it by myself:
- unit SEAT MIB STD2 PQ model number 7N5035680E
- reflashed with VW software MST2_EU_VW_PQ_P0478T
- Components Protection disabled
- all the features activated
- flashed with HMI (Human Machine Interface) from SKODA software MST2_EU_SK_ZR_P0478T from MQB platform
- button backlight LEDs changed to green
Thank you everything is fine
I own a 2010 Superb 2 combi witch came with the the columbus unit and the 10 speakers sound system.
Now, i'm trying to upgrade my installation to have carplay.
Following this topic, il already bought a Bolero (5L0035200 B ) and an USB port (5Q0035726 E).
Now the harness is missing.
Is a harness with this type of connectors will work with my unit ?
On 24/10/2018 at 14:03, pab567 said:
I have installed original VW USB HUB 5G0035953C and enabled 2nd USB :)
Now each of them can be used for SmartLink and powers / charges phone :)
Hi, can you advice me how to activate it in MIB2 Amundsen in Octavia III ?  Thank you.
On 23/11/2018 at 12:17, KMDTHY said:
Yea it does. Like having a new sound system suddently. 🙂
Hi, would it work also at MIB2 Amundsen with Canton 2 system after retrofit from Columbus MIB1 with Canton 1 system ?
Yes, it will work, you simply change adaptation channel with working "Connection 2" to activated. Of course it requires original USB hub to be installed :)
Only this ?  Thank you :).  Yes I have already bought USB hub original Skoda . But now idea wich data cable i should use there
What is the model number of HUB you have bought?
5g0035953d
I have not option Connection 2 in adaptation channels in 5F unit via obd eleven .
