S3 owners - electric tailgate / hatch closing from inside
Would you pay for the rear hatch / tailgate to close from the button inside the car? 130 members have voted
  1. 1. Would you pay for the rear hatch / tailgate to close from the button inside the car?
    • Yes, I live in Kent and would be happy to travel to Folkestone and pay for this to be enabled
      17%
    • I don’t live in Kent but would still be happy to travel to Folkestone and pay for this to be enabled
      72%
    • No, I live in Kent but this doesn’t interest me
      9%
  2. 2. How much would you be prepared to pay for this?
Please sign in or register to vote in this poll.
I find the E tailgate is more of a gimmick without the closing function
  • Replies 216
  • Views 108k
  • seriousness aside -  a number of supercars deploy rear wing spoilers at high speeds for increased downforce/stability. bugatti, amongst others also use the rear spoilers as air-brakes too.
  • I've done 450 miles this week so far with another 330 to do tomorrow. Happy to drive to you. Happy to pay for it. Will bring you a pork pie and a decent bottle of melton red ale as a cultural exchange
  • As a disabled driver, I would happily pay a reasonable amount for this.  The non availability drives me bloody mad.  Who in their right mind would design a facility to open the tailgate from inside, o
On 04/06/2023 at 20:39, igrozan said:
Car Skanner has an option for trunk parameters. Now everyone can set the trunk closing from the button in the cabin using the phone and obd. If I haven't tried it. You do everything at your own peril and risk
Have clicked this CarScanner function today and wanted to enable closing tailgate from interior and remote button on module 5Q0959107P [software version 0266, Superb from 2019, no kessy]. Now interior button only unlocks tailgate (its not going up like it used to earlier). But closing with remote when ignition is off works by keeping remote pressed till its closed (it hasnt earlier). Reversing module dataset from backup doesnt help.
Noticed that this function doesnt save option which user changes. Even though I clicked "Apply" and get confirmation that data was accepted it gets back to start after clicking "Refresh".
How can I now make tailgate to open by clicking interior button? Is there a possibility to reset module 6D to factory default? Or type the right coding in anywhere? There is option to include user parameters at the end of this function. Could anyone help me please? I can paste whole current  coding/parametrization of this module.
Edited by msemafor
Hello. I'll go to the garage and take a look. everything should be simple.
And so, I don't have parameter 0266, but you can try this: my original file, as it was from the factory IMG_20230816_092856.thumb.jpg.2ed98e40cf43c8a8ece957888cce6cb2.jpgIMG_20230816_092935.thumb.jpg.bbbeb4f37c07776fef88fb1045ebdaba.jpg
my modified parameters
post what happened
8 hours ago, igrozan said:
post what happened
Thanks @igrozan for your informations.
Have no idea how I did it but now my tailgate works like it should do. Opens and closes with interior button and remote. To close it I have to keep buttons pressed till it locks.
Today morning I clicked "Long coding" --> "Tailgate/bootlid" and clicked "Reset module" and then "Hard reset". After that my tailgate started to work as I wanted it to.
Here is what I have in this feature in CarScanner and in export ECU info to text.
6D. Tailgate/Boot lid
Manufacturer spare part number: 5Q0959107P
Manufacturer ECU software version: 0266
System supplier identifier: 00000000000000
ECU manufacturing date (ASCII): 010101
ECU serial number: 32296305400000
VIN: -----------------
Manufacturer ECU hardware number: 5Q0959107J
System supplier ECU hardware number: A2C7376250000
System supplier ECU hardware version: 0000
System supplier ECU software number: A2C7376250000
System supplier ECU software version: 0000
Exhaust regulation or type approval number: -------
System name: HDSG-Modul
Calibration repair shop code or equipment serial number: f,Q
Calibration date (ASCII): #
ODX file id: EV_DeckLidCONTIAU736
HW ver.: H13
ASAM ver.: 001016
Application software identification (id/version/valid/plausible/used): 720A/028E/1/1/1; 720D/028E/1/1/1; 720E/028E/1/1/1; 7210/028E/1/1/1; 7211/028E/1/1/1; 7215/028E/1/1/1; 7216/028E/1/1/1; 7217/028E/1/1/1; 7218/028E/1/1/1; 7219/028E/1/1/1; 721A/028E/1/1/1; 721B/028E/1/1/1; 721D/028E/1/1/1; 721E/028E/1/1/1; 721F/028E/1/1/1; 7220/028E/1/1/1; 7221/028E/1/1/1; 7222/028E/1/1/1; 7223/028E/1/1/1; 7224/028E/1/1/1;
ECU manufacturing date (HEX): 010101
Programming date (HEX): 3551303935393130374A20
Calibration date (HEX): 230815
Long Coding: 1000
You have version 028E, I have this parameter. It's good that everything works.
I'm not sure about which version I have. It's shown by default when I click this option but I can change it  and after it different version will be shown by default - there is also 0285 version which might be newer software symbol. Of course I'm glad taigate works fine and as I wanted it to. Won't be playing with this anymore.
Hello.  I have 5Q0959107S, I can leave it 1B2D5BFF or better at 1B2D5B5E.  Which is better for me, I don't have a virtual pedal but I do have keyless and remote access.  Could you explain the difference to me?  It is for a superb 3v 2020
17.09.2023 в 03:55, Иисус98 сказал:
Привет. У меня 5Q0959107S, я могу оставить его 1B2D5BFF или лучше 1B2D5B5E. Что для меня лучше: у меня нет виртуальной педали, но есть доступ без ключа и удаленный доступ. Не могли бы вы объяснить мне разницу? Это для превосходного 3v 2020 года.
If you don’t have any options, but you set them, it doesn’t change anything
Edited by igrozan
  • 5 months later...
Hi
I want to use Car scaner for my tailgate parametrization. I have SIII combi 12/2016 and trunk was retrofited.  Control module 6D is 5Q0959107G  H12    0250.
1.  which odb I can buy  - any advise  ?  Plan is to use car scanner and odb to change parameters  like @igrozan mentioned
2. any other option how  to activate center console button open/close  and key close?
2 hours ago, baluchap said:
obd
@msemafor
HI
Are you able to help me pls.  I retrofitted deck lid  to my SIII COMBI   from 12/2016.   Control module is version G, details  below.  I want to  activate closing lid by key. Now its only open it.  Without  KESSY.
I am not able to  do parametrization - because by ODB and CAR SCANNER  I have no options for it - or I can not find them between all the options in menu.
Any help ?
Manufacturer spare part number: 5Q0959107G
Manufacturer ECU software version: 0250
ECU serial number: 30237749000000
Manufacturer ECU hardware number: 5Q0959107G
Repair shop code or tester serial number: 000000000000
Calibration repair shop code or equipment serial number: 09
Calibration date (ASCII): $
HW ver.: H12
ASAM ver.: 001011
Application software identification (id/version/valid/plausible/used): 720A/00C2/1/1/1; 720D/00C2/1/1/1; 720E/00C2/1/1/1; 7210/00C2/1/1/1; 7211/00C2/1/1/1; 7215/00C2/1/1/1; 7216/00C2/1/1/1; 7217/00C2/1/1/1; 7218/00C2/1/1/1; 7219/00C2/1/1/1; 721A/00C2/1/1/1; 721B/00C2/1/1/1; 721D/00C2/1/1/1; 721E/00C2/1/1/1; 721F/00C2/1/1/1; 7220/00C2/1/1/1; 7221/00C2/1/1/1; 7222/00C2/1/1/1; 7223/00C2/1/1/1; 7224/00C2/1/1/1;
Programming date (HEX): 3551303935393130374720
Calibration date (HEX): 240313
Long Coding: 0D80
59 minutes ago, baluchap said:
@msemafor
HI
Any help ?
HW ver.: H12
ASAM ver.: 001011
Long Coding: 0D80
My app is in polish so I'm not sure what names of functionalities are in english version but will try to translate.
After connecting to your car you need to choose the last icon at the bottom of the main screen called "Coding and service" or similar. Then confirm the warning and you'll see categories. There should be "Boot lid" or "Trunk" or similar. Enter there and the last option is "Tailgate dataset customization". Guess it is what you're looking for.
I needed to do a reset of this module after changing parametrization.
Remember that you're doing this on your own resposibility.
On 18/03/2019 at 10:25, JR RS said:
By default - u can close the boot by pressing and holding the boot button on ur key.
It won't work from inside the car when the ignition is on, and u gotta b within 3m to the car.
is this with kessy as it doesnt seem to work on my old fashion key
Yes, my car has KESSY.
yeah seems to be the case it only works on kessy cars
Last week I finally could plug in the thing and see if I am able to do anything with this. I think is not possible as @MartiniB indicated in the VCDS FL topic, but what I saw is that I do not see this "H" "P" "S" or whatever suffix you guys claim to see, most likely I am looking in the wrong place ... any help here?
And also, had anyone 'retrofitted' an earlier module to allow the closing from button function?
FL '21, KESSY, VP
Unintentionally pressed the tailgate button. Pressed again to stop it opening. I decided to drive on a short distance to find somewhere quieter to deal with the tailgate, and found it closed itself when driving off.
  • 4 months later...
can anyone tell me if there is an option to change paramters of 5WC959107A or flash back to a 5Q0 tailgate controller setting to get the tap closure from the console button?
My VCP scan of the tailgate is
Adressword  : 6D (Deck Lid Control Unit} - J605  HDSG-Modul
VAG no.     : SW: 5WC959107A  HW: 5WC959107A
SW version  : 0433
# Coding      : 0D08
ASAM: UDS, EV_DeckLidCONTIAU536 001002
DATASET: V03935356FX
I use VCP and ODIS.
Edited by 26DIPP
On 09/08/2021 at 18:35, AlVal said:
No need for money, if you're local (I'm inbetween Milton keynes/bedford/Northampton) I can try and do yours
Wow you actually found a way to do it? could you please do mine. happy to pay and travel to you.
Detailed info for setting this with carscanner
I have this obd module
https://www.amazon.co.uk/dp/B06XGB4873
And a pro license for carscanner (£8)
Set the mqb profile and connect. Bonnet has to be open and ignition on. Engine off.
Select coding and service
Then luggage compartment
Then scroll to the bottom and choose tailgate dataset customisationIMG_0611.jpeg
Then click on choose other and select one of the superbliftback ones.
Then set the parameters you want and choose apply. (The open/close from remote should be selected)
You may need different settings if you have kessy or virtual pedal.
I have seen on another page that you have to hard reset through the long coding options for it to apply but it worked fine for me without this.
I have also noticed this evening that when you go back in to it it reverts to default rather than showing you your current settings.
I assume this still doesn't apply to FL versions?
Not a clue. Mine is 2016.
There are a whole list of options for a different controller. So maybe it depends on the part number of the controller you have.
Thought so. I don't believe this is available for the FL.
