The Mk3 Octavia TDI water pump thread
On 19/12/2022 at 22:15, fatgaz said:
I get the timing belt part but a water pump issues on cars from 35k onwards inst what you should expect these days. My Kia has 110k and still going stong on the original pump.
My O3 has almost 100k miles and still have no issues with the factory fitted water pump(knock on wood :D ).
I changed the coolant once on the 5th year and I don’t plan to change the timing belt and water pump till 130k as this is the mileage interval in which Skoda requires to changed them in my country. No time interval.
So it really depends on the car, maybe I’m lucky, who knows 🤔
  • Replies 275
  • Views 151.8k
  • Had this problem on my 2015 Scout (107000 miles).  Had noticed the temp getting up to 110 occasionally, then last week it got to >130 and got the warning beeps etc.   Heater on HI and it
  • Feb 2014, TDI vRS, first noticed at ~95k km, Dealer is AMAG Suisse, diagnosed fault in 5mins, immediately offered 50% contribution to repair costs.
  • Year of Registration - Feb 2015 Model - 2.0TDi 150PS Problem First appeared - July 2018, 120,000 kms Problem Fixed Today, 30 August 130,000 kms Garage goodwill - Sinnotts in Wicklo
Luck you and hope it continues
On 20/12/2022 at 08:19, PetrolDave said:
The water pump has to be disturbed/removed to replace the timing belt, so it makes sense to replace the water pump rather than try to refit/reseal the old pump.
If you're not changing the pump it doesn't get touched when changing the belt
In most cases no extra labor cost is added, so usually people do both.
Exception is if the car is on low mileage.
On 29/07/2018 at 13:14, metalstock87 said:
I may be wrong in saying this nick, but as ive just gone through the whole water pump (scinario) pretty sure ive read on here, that it was upto and including 2014/64 plate..... not sure on the exact month or date but im guessing you should be alright on a 2015?? almost a 65 plate wich is even later/cdn-cgi/mirage/374a16b8d3782a1b72110b1bac712597d509ee5650b4eab9b3b512d9c28bf528/1280/https://www.briskoda.net/forums/uploads/emoticons/emoticon-0103-cool.gif your best bet would probably be to ring your local SKODA HQ
I have a 68 plate Superb 2.0tdi auto estate and have the warning as discussed. In to garage this Friday for new pump and cambelt for £600
I think you may have missed my point 😁
My water pump just failed 😞. The dashboard showed low coolant and the reservoir was empty. Managed to get the car home after topping it up with water. I suspected that it was the pump straightaway and so started stripping the front end until I could see the pump. I added some water to the reservoir and it immediately leaked out of the centre of the pump. In fact there was a small piece of gasket or seal hanging out from the behind the pump pulley.
Upon removing the pump there was something rattling behind the pulley, the collar was stuck covering the impeller and the plunger on the solenoid valve snapped off in the housing as the plastic seemed brittle. I think that it was not far away from catastrophic bearing failure.
Needless to say I'll be replacing it with a non-collared version since I don't want the overheating problem and I'll look to change it again in about 60k miles, which at the current rate will take me another 20 years.
Here are my details:
  • Year of registration
2013
  • Engine
2.0 TDi CKFC
  • Mileage when fault occurred
69900
  • Dealer name & response (i.e. "don't want to know"/"yep, they all do that"/other)
Didn't bother asking
  • Warranty or goodwill contribution?
I am the warranty 😉
  • Any other info. (Full Skoda service history/independent?)
Car has been regularly serviced, pump was original but has now been replaced with a Gates pump that doesn't have the sliding collar. Belt and idlers all looked in good order but they were replaced too.
Car is 2018, just 83K kilometers (just 51K miles). Two weeks ago while I was in Switzerland a low level for coolant blinked on my dashboard. I topped it and after a while I got the same warning and indeed no coolant enough. It was detected the famous leak of the water pump. The engine oil was just warm (always less than 100°C)
She was brought to an official Skoda dealer in Frauenfeld (CH) which "offered" water pump, belt and even screws replacement for an astonishing 2500 CHF (2200 GBP).
No comment...
No comment...
What happened then? Did you topped up some coolant and return back or accepted the offer? I guess not.. 😂
The labor costs a lot in CH..
It happened that I kindly answered I would have taken my car back without letting them work on it! I must say they were anyway very friendly and even topped the coolant for free.
Then I happily drove back to Italy (I mean +450Km) and - apart from stopping several times to top it up - I had no whatsoever hint of overheating of water nor of oil. Water temp raised progressively to 90°C and holded, maximum oil temp I saw (I kept monitoring water and oil temp) was 107°C while climbing the mountains but the temperature was clearly under car control, and typically was around 100°C (perfect value, would say).
This morning she's recovered in a Skoda garage in Italy.
For sure this pump (?) failure didn't kill the car.
Edited by Genoa1893
Just had my 64 reg 1.6 TDI cam belt/tensioner/water pump replaced.
Belt had some micro cracks but was in pretty good shape. Water pump had been leaking and was on the way out 😳 so I’m glad I had this done early (122K) not the 140K I believe Skoda quote.
Cost all in £485 at independent (parts £305 labour £180).
Wife wasn’t convinced it need done but after the near failure of the water pump and potential impending disaster she’s well pleased 😀 🤣👍
Interesting story, especially being able to drive 500 km with a pump failure. How much did it cost in Italy?
  • 4 months later...
Can anybody please give me some advice? My Octavia Octavia Mk 3 has started to Overheat! At first the problem was intermittent but now it happens regularly.  However... If I put the heater onto full, this takes the temperature back down to 90 so I can control it to an extent but I'm worried about the damage I could cause the engine.
As well as this I'm due to tour round France with it over the summer, so it is imperative that it is reliable.
After reading the thread, It sounds reminiscent of a faulty water pump? The best of my knowledge it has never been replaced. How much would I expect to pay for this if I went to a dealer?
FYI:
2014 plate, Octavia 2.0 TDI
109K miles on the clock (cam belt changed at 75K)
What temp does it reach when overheating?
If I leave it, all the way into the red and then the warning sound comes on. Out the heater on and it goes back to 90.
Put it into dealer and yup, water pump failure - Got the cam belt changed at the same time for £650.
  • Year of registration - 2014
  • Engine 2.0 TDI
  • Mileage when fault occurred - 109,000 miles
  • Dealer name & response (i.e. "don't want to know"/"yep, they all do that"/other) - Johnsons Liverpool
  • Warranty or goodwill contribution? - Nope. Did have a deal on, Cam belt and water pump for £650
  • Any other info. (Full Skoda service history/independent?) - Full independent service history. Cam belt and water pump originally changed by previous owner at 70,000 miles
  • Year of registration - 2015
  • Engine 2.0 TDI 150
  • Mileage when fault occurred - 85,000 miles
  • Dealer name & response (i.e. "don't want to know"/"yep, they all do that"/other) - Listers Skoda Coventry, did the work as belt was due (7 years interval, instead of recommeded 5, but about the 130000km so was done just about time) and pump had to be done as leaking coolant
  • Warranty or goodwill contribution? - Paid £600 for both belt and pump
  • Any other info. (Full Skoda service history/independent?) - Full Skoda history, bought from them.
My engine was not overheating, but I noticed that the coolant started leaking August 2022, put some coolant back in, drove for another maybe ~200km, coolant level went down, the dealer took it in for diagnostics, determined pump was leaking, fortunately not into the engine (oil was fine and everything, just losing coolant), went in for repairs along with other things due like engine oil, dsg oil and brake fluid, aircon etc (bill was just over £1k for all of that service). Car was fine, couple of trips to Poland and back to UK, passed MOT on Friday (04/08/23) and on Sunday it came up again with coolant level low warning, topped up coolant, but went in today and booked in diagnostics to determine if it's the same thing. As mentioned in the thread previously, I noticed an alarming frequency of DPF regens happening recently, could have something to do with overheating the pump assembly. Dealer said parts are still under a 2 year warranty from last change a year ago, so if it's the same problem, I might get away with having it changed for free. I'll let you know, the diagnostics is booked in for end of August.
I can confirm that this is a normal price in an AMAG (vag) garage in Switzerland!
A standard service is around 350chf and a major service around 600chf...
I've been quoted this twice for my Octavia when they try to convince me to get it done early.
The quotes are all fully itemized & you will pay vag prices for every screw, bolt, o ring, gasket etc
Those who can often take their cars to France or Germany for work because they usually offer fixed price services for cars over 3 years old like in the UK.
  • Year of registration - 2013
  • Engine 1.6 TDI
  • Mileage when fault occurred - 56000 miles
  • Dealer name & response (i.e. "don't want to know"/"yep, they all do that"/other) - Not sure, bought privately
  • Warranty or goodwill contribution? - £714 for belt and pump
  • Any other info. (Full Skoda service history/independent?) - Full service history (part Skoda part independent)
Only bought it 2 weeks before this 😭
  • 10 months later...
Hi all,
I've jus bought a 2015 Octavia 2.0 with CKFC engine -It's got 96k miles and no evidence of the timing belt being done, so I'm planning to change this in the next few days. How do I differentiate between the two different water pumps? One seems to be switchable but the other not and both seem available for my car. Can anyone assist with the right one pl
Edited by GizmoThor8303
posted in the wrong section
FYI:
I hope you got this fixed. My 15 model did this, too. Found out the movable sleeve to aid with warm up over the pump was almost seized. New aftermarket pump with sleeve delete and no problems since.
Takes much longer to get heat up now, but at least reliable
On 25/08/2024 at 01:18, GizmoThor8303 said:
Hi all,
AFAIK, all the factory ones have a sleeve. The sleeve is physically visable as it sits outside the impeller.
If you can handle a longer time for the internal heater to warm up, then get a sleeveless one. My last factory sleeve one had the sleeve fail at 60k kms... At 180k kms, my car is now on it's 3rd pump, when it should only be halfway through 2nd...
My details
17 plate Octavia Scout. 184PS diesel
started at 53450
Out of warranty didn't pursue any compensation
All Electric in Woodthorpe Rd in Birmingham changed water pump and belts for £900
Replaced like for like
First time I got warning lights was Christmas day, then about 3 weeks later and 2 days ago. In between the needle solidly at 90 and oil at 100 to 105
I asked mechanic if the bypass sleeve was stuck but at time of taking out, no it wasn't. But he didn't make thing this was odd, just normal behaviour. This is an old geezer who has been doing Skoda for 35yrs
I hope that helps. Please ask questions if I've missed anything useful
2015 2l TDI about 97000 miles.
Garage said the timing belt had been swapped when I got it about 3 years ago so I assumed that was everything.
It was a potential summer job last year that I never got round too.
Just stopped at the lights outside work and the engine tone changed, sounding like the exhaust had blown, accompanied by what I thought was steam.
Limped into the carpark and turned out the steam was smoke with a strong smell of burning plastic and now a squealing noise.
Other than that zero symptoms at all.
Tensioner is a Gates one but the water pump is VW so I guess that wasnt swapped after all.
Interesting
Interesting
