Amundsen MIB2 Firmware Update
Regular update is 0253. But if your unit is hacked then I recommend to leave it as is...
  • Replies 4.7k
  • Views 893k
Hi @pab567 can you post a list of all current firmwares for different hardware versions? This will help people check themselves if there is a newer version available. Will avoid a lot of questions in this thread.... Just a suggestion.
Any chance to get firmware uptade for this unit ?
Thank you
Hello@pab567can you help me with this?
Is there a chance for this model to get updated to the latest version?  I want to update the maps but nothing found when I entered my Vin .I have a cd player and sd card.(it's only 2gb though).I went to Scoda but they said that they recycled the update Cd :(
Here's the info for easy reach:
DEVICE PART NUMBER: 3T0035191
HARDWARE: H12
SOFTWARE: 0212
Thank you in advance!!
Hi @pab567,
could you please have a look, if there is also an update available for me ?
not sure what i'm doing wrong, trying to update the software on my H41, using a sd card formatted as exFAT and tried ms-dos (i have a mac so not sure if that is part of my problem) i have the correct file from pab567 MST2_EU_SK_ZR_P0478T, press an hold menu, launches the software update, it recognises the sd card, press update but then say unable to read file, ignition is on, can't think what else to try? thanks for any help
Format needs to be fat32. ExFat is not recognised by the infotainment unit. Also show hidden files and delete all the hidden files at the root of the SD card. Macs have a habit of adding files to file systems that can confuse some devices.
Hello @pab567,
Is there an update available for this:
Language Finnish
Device Part number: 5Q0035864C
Hardware: H41
Software: 0468
5L0051236BJ
1310
ECE AS 2020
SHIELD: SHIELD 2016-44 (build 309)
Hello @pab567, I'd be very grateful if you can share the latest firmware for my Amundsen (478?)
I've had a couple of occasions where the clock jumps around, I'd like to see if this will fix it.
Hi All,
I have this factory installed, not hacked MIB2 Amundsen.
I have several issues with this unit like performance and missing features in Android Auto.
I was hoping that an software update could fix this.
My dealer has a lot of trouble finding new software, they recommend 0252. In my opinion is this released in 2016. Is there newer software possible in my Head unit? Can I direct my dealer to the right place for this, or can I do it myself?
Thanks in advance
1706616695_WhatsAppImage2021-05-22at14_20_34.thumb.jpeg.e47ae6deafe162d75d6c0dfb1bee0363.jpeg
7 hours ago, Egbert_Superb said:
Hi All,
Thanks in advance
Simple answer: 0252 is latest firmware and if you want Mirrorlink, you will need an FeC code from your Skoda dealer to enable it.
Hi varaderoguy
Thanks for your answer. Although I was hoping for an other answer.
I Already have mirrorlink on my system, I assume its still working after upgrading?
Hello @pab567,
Device Part number: 5Q0035840A
Software: 0245
Hey there,
just found this awesome forum after some research.
I'm having very often disconnects to Carplay or restarts of my system. I was hoping, there might be a firmware update available.
Hardware Part Number: 5q0035874c
Software Version: 0471
(See screenshots attached if details were missed)
Thank you in advance.
Don't forget to tag @pab567
otherwise we won't be able to assist.
thanks for the hint @varaderoguy.
@pab567: are you potentially able to help me out?
good evening everyone i'm new i just bought an octavia 2017 and i don't really know the multimedia system i want to know what type of system is installed (amundsen !? MIB 2 or 2.5!?) and is it there is an update for this system ... thanks
Can confirm 0480 is out in the wild 👍
Are you able to share the update?
Unfortunately not, but hopefully @pab567 soon has it available. 🤞
I will send it to @pab567 as soon he is sending me a reply to my pm.
For MIB1 Bolero and Amundsen (x = any letter)
5E0035812x/5E0035819x/5E0035820x/5E0035840x/5E0035842x/5E0035864x/5E0035874x => MSTD_EU_SK_P6230 (0490)
For MIB2 MQB Bolero and Amundsen
5Q0035819/5Q0035820/5Q0035840/5Q0035842/5Q0035864/5Q0035874 => MST2_EU_SK_ZR_P0138T (0138)
5Q0035819A/5Q0035820A/5Q0035840A/5Q0035842A/5Q0035864A/5Q0035874A => MST2_EU_SK_ZR_P0253T (0253)
5Q0035819B/5Q0035820B/5Q0035840B/5Q0035842B/5Q0035864B/5Q0035874B => MST2_EU_SK_ZR_P0367T (0367)
5Q0035819C/5Q0035820C/5Q0035840C/5Q0035842C/5Q0035864C/5Q0035874C => MST2_EU_SK_ZR_P0478T (0478)
565035819/565035820/565035840/565035842/565035864/565035874 => MST2_EU_SK_ZR_P0478T (0478)
For MIB2 PQ Bolero and Amundsen
5L0035200/5L0035200A/5L0035680/5L0035680A => MST2_EU_SK_PQ_P0138T (0138)
5L0035200B/5L0035200C/5L0035680B/5L0035680C => MST2_EU_SK_PQ_P0253T (0253)
5L0035200D/5L0035200E/5L0035680D/5L0035680E => MST2_EU_SK_PQ_P0363T (0363) however upgrade files are NOT available
For Columbus MIB1 (x = any letter)
5E0035020x/5E0035021x/5E0035043x/5E0035044x => MHIG_EU_SK_K1552 (0411)
For Columbus MIB2 (x = any letter)
3V0035020x/3V0035021x/3V0035043x/3V0035044x => MHI2_ER_SKG11_K3343 (1433)
For Columbus MIB2.5 (x = any letter)
565035020x/565035021x/565035043x/565035044x => MHI2_ER_SKG13_P4526 (1440)
All check your PM.
Well, I don't have any PM from you :(
Hello,
I currently have an octavia:
5Q0035864C
H41
0468
Nav: 5L0051236BR
If I read correctly I would need the firmware MST2_EU_SK_ZR_P0478T (0478) ?
Can you send me a download link?
Would love to update this as well please @pab567
Thanks in advance.
