Does the Sportline have stiffer suspension?
as above really!
Currently have 2016 2.0TDI SE Business est, love the car but I feel it's just too floaty.
Taking cash instead of company car in a few months, ideally want another Superb as the dog guard and boot liner are a straight swap.
There seems to be a fair few Sportlines second hand at the moment at a reasonable value
  • Replies 210
  • Views 53k
  • So, first thing: JR RS is absolutely right. There are two Eibach Pro-Kits for the Superb, one for the liftback and one for the wagon, with the numbers as he says. I bought the wagon version (for my li
  • As you are running Skoda "lowered ride height" springs, ie. 5Q0411105HE front and 3Q0511115AC rear, you could change to the slightly stiffer 5Q0411105HF (about 5% stiffer) or 5Q0411105HG (about 10% st
  • I suspect you're right. There are a lot of people who set something just as they like it, then can't bear the idea of it being adjusted. Mirrors, seat position, steering wheel. I switch driving m
If you can, get something with DCC (Dynamic Chassis Control) - I have it standard on my L&K and wouldn't be without it.  Keep it in normal most of the time, but occasionally go for floaty comfort, and very rarely pop it into Sport, which really stiffens everything up...
The Sportline has *slightly* firmer suspension, which sits 15mm lower than standard. IME it makes the car less prone to leaning in corners whilst not spoiling comfort. If anything I’d prefer it to be more taut.
Even with 19” wheels the Sportline is still a nice, compliant ride.
Agree with all your points penguin17, shy.:thumbup:
part numbers on my non-Sportline:-
DCC Shocks: 3Q0413031AK
Springs: VW5Q04GL
would b good to get similar part numbers from peeps with Sportline models so we can compare.
I have Sportline without DCC and I found the damping lacked control on bumpy corners and over speed bumps. This was even more of an issue after a remap to 300bhp, so decided to change the shocks to Koni Special Actives. These provide much better control and handling, without impacting the ride comfort. Would certainly recommend these as a cheaper option to coilovers.
A few of us have gone for H&R springs to solve that issue and mine is a sportline. Yes they do lower it further but does sort the floatiness out. However the Koni special actives are next on my list
I look forward to your review once fitted!!😁
+1
H&R or Eibach springs have been the go to for a few of us to firm things up a little.
I put Eibach Prokit springs in my non-Sportline.  Pairs very nicely with the DCC shocks.
It's still very comfortable in Comfort mode.  Normal mode is not firm.
It doesn't eliminate the "bounce" completely, but it helps.
Been more than 6 months - very happy with it.
Plus is looks much nicer being 20mm lower.20190802_210758-COLLAGE.thumb.jpg.dbf48c9f2609bf019ffdc616608e5d05.jpg
Edited by JR RS
Haha mark it’ll not be until later on in the year but you’ll know when it’s done lol
  • 3 months later...
Took delivery of a 2019 1.5TSi Sport Line lask week.
Yes the suspension is stiffer, I think it's a mix of lower profile tyres and slightly lower ride height.
Sportline alone doesn't tell much really, the suspension is still set up towards comfort. The DCC is where the difference is made. Sportline DCC in Sport mode is the firmest of all the available variants, then I believe L&K DCC in Sport comes second, then Sportline non-DCC, then the standard Superb.
Just fitted Koni Special Actives on my 280 Sportline 4x4 and - Wow!  Its what the car should have been like all along.  Only a couple of 100 miles on it since the fit but no more floating and wallowing.  It is slightly stiffer over the small slow speed stuff, but not hard but it is SO much better when pushed.
Kept the springs the same, just a damper change.  If doing it yourself, and it is straight forward, you will need a few bespoke tools and it is possible to do it without removing the front hubs and driveshafts etc.  watch a couple of vids on youtube, just search for Golf Mk7 suspension change 2x4 method.  I needed to get a set of euro tri-square bits (12 point bits), a damper 16mm socket with euro blade fit and a suspension spreader bit.  the rest was just in my normal tools box.
If in doubt..... do it!
  • 11 months later...
we just got a MY2018 Superb Estate 1,4 TSI with DSG and Style trim package - no DCC. Driving characteristics are little bit disappointing. I'm planning to address this issue by replacing the current standard shocks with Koni Special Active or with Bilstein B6 and springs with the ones from the Sportline trim. Changing standard springs to Sportline might be related more to appearance than to ride feel :)
Although I have read many topics here on the forum and searched the web, I've not found the part codes for the Sportline springs (front and rear).
Does anyone have the part number information for the Sportline springs?
Do you have a Hatch or Wagon?
Wagon
4 hours ago, ilivili said:
What OEM part numbers do your current front and rear springs have?
Your current front and rear springs might have OEM part numbers 5Q0411105GJ (2 blue dots) and 3Q0511115AK. If so, you would have an option of going up one weight range on the front and/or rear springs. The increase in spring stiffness by going up one weight range is about 5%, as you would be going up from 11.75mm wire thickness to 12mm wire thickness on the front and 12.25mm wire thickness to 12.5mm wire thickness on the rear.
5Q0411105GK is one weight range higher than 5Q0411105GJ.
3Q0511115AL is one weight range higher than 3Q0511115AK.
Front Springs
(1) 5Q0411105GJ coil spring
2 paint marks
blue
(1) 5Q0411105GK coil spring
1 paint mark
1 paint mark
blue
green
Rear Springs
1 3Q0511115AK coil spring
1 3Q0511115AL coil spring
Sachs 5Q0411105GJ
https://www.autodoc.co.uk/sachs/12794755
Sachs 5Q0411105GK
https://www.autodoc.co.uk/sachs/13786039
Sachs 3Q0511115AK
https://www.autodoc.co.uk/sachs/15244168
Sachs 3Q0511115AL
https://www.autodoc.co.uk/sachs/15244179
For handling I can recommend going stiffer at the rear. Currently have spring assisters in the rear and the added support is great. Turn in is much sharper and the ride isn't affected to much. A stiffer rear spring should do similar things. Having just had special actives fitted I am waiting on how they feel mid to long term before making any further changes. Fully expect to be lowering at some point but the next change will be to swap the assisters out for an upgraded roll bar.
Front Springs
2 paint marks
blue
1 paint mark
1 paint mark
blue
green
Rear Springs
Sachs 5Q0411105GJ
Sachs 5Q0411105GK
Sachs 3Q0511115AK
Sachs 3Q0511115AL
Thank you @Carlston! This information is golden!
It has rained for the past week here in Finland and I have not had a chance to verify the current spring and shock setup. Hopefully I'm able to take a closer look later this week.
Thanks for the feedback @MarkyG82
Our previous car was Audi A3, which of course is not the same at all with Superb from the size perspective, but A3 had similar feel of drive with Volvo V90 and Audi A4 which we drove before we decided to go with the Superb. Feel of those two is something I'm trying to achieve.
Do you already have specific springs on you mind? H&R lowers the car little too much for me.
Probably eibach prokit if I do it.  Been trying to find part numbers for suitable superb sportline springs that would drop into my passat as it's difficult to fine springs for a factory lowered passat with my transmission.  Some Superb prokit springs are listed as compatible with the 280/272 and iV which would suite me fine if I can find factory springs.  The 30-35mm drop is a touch too low for my liking and the 15mm factory drop would be perfect.
Edit:
I do have some upper spring perches ready to fit though which can add up to 10mm to the ride height.  Back end sits too low IMO. The spring assisters I have bring it back in line so will probably fit the new pads when fitting the rear roll bar and keep them there if lowering.
Edited by MarkyG82
I kept the OEM springs and replaced with Koni red dampers - wow what a difference. Everything is firmed up but not harsh. No more wallowing. Recommended
Agreed, though Koni Special Active fitted here, same as others, made such a difference.
Not heard any complaints about them
going to experiment - stiffer Eibach Pro springs without lowering
for rear axle on 2.0 FWD can be installed springs from 2.0 AWD kit
result is perfect:
mm.Lowering
Eibach part code
Outlet
Wire
Length
Coils
AWD
FWD
11-15-007-04-HA
116.0
13.50
303
8,00
-50
-30
11-79-008-01-HA
122.0
13.75
327
8,20
-30
-5
but which Eibach spring will give less lowering on the Front axle?
hardiest for Superb is 11-85-042-03-FA, but the same spring model goes for lighter versions of Audi Q2; VW T-Roc.
what makes me to guess, some of the next springs can give me searched result - stiffer without lowering
Eibach part code
Outlet
Wire
Length
Coils
mm.Lowering
11-85-041-01-VA
136.5
12.25
249
4.75
-40
11-85-042-03-FA
136.5
12.50
248
4.75
-30
11-85-043-01-FA
150.0
13.25
267
5.00
11-85-043-02-FA
150.0
13.50
267
5.00
11-85-043-03-FA
150.0
13.75
262
5.00
Eibach part code
Superb
Passat
Arteon
Golf7
A3
Q2
Tiguan
T-Roc
F11-85-041-01-VA
985
1100
1110
1100
1100
995
1020
F11-85-042-03-FA
1180
1180
1200
1065
F11-85-043-01-FA
1090
1090
F11-85-043-02-FA
1160
1160
F11-85-043-03-FA
1220
just one additional problem, info from seller:
Quote
here are the delivery times from all parts:
Eibach F11-79-008-01-HA  / available
Bilstein 20-267537 / mid-november
Bilstein 23-254343 / end-october
Eibach F11-85-043-02-FA  / end-september
Thats lots of good info but I find it hard to believe that the awd version will lower 20+mm on the same springs.  They are only something like 130kg heavier.
