Software Update available for Bolero?
46 minutes ago, rakchendoor said:
THANK YOU @radoszczak
CAN I DO an UPDATE directly from version 1780 to 1800 OR 1780-1790-1798-1800?
Yes. I have updated directly from 1310 to 1800.
  • Replies 769
  • Views 217.1k
  • StripleRider03
    StripleRider03
    I just updated to 1800, I have a Skoda Slavia in India with the Bolero system. I can confirm that the issue with S23 Ultra is finally resolved! Attaching images.
  • radoszczak
    radoszczak
    Cześć, poniżej link do strony z opisem możliwych FW U Ciebie powinno pójść do wersji 742. https://www.drive2.ru/l/650934799095051499/
  • There are these updates, but not sure if the higher number will apply to your system.   MEN3_EU_SK370_P0113P_0469 MEN3_EU_SK370_P2135P_0742   MEN3_EU_SK370_P1185L_1760 ME
44 minutes ago, xayep said:
Is the update path possible? How did it go? According to mib-helper.com, the latest possible FW is 1760.
My Scala originally came with 0451 and the previous owner updated directly to 0469.
As far as I know infotainment in scala is in two hardware versions. Older hardware is with stock fw 0469, and last possible fw version for this hardware is 742. Newer version of hardware, for example mine scala from 2021 year has stock 1310 fw, and I successfully updated it to 1800 fw. Few lines early in this topic someone tryied to update from xxx firmware version to xxxx, and it fails. Maybe someone with more knowledge will correct me and say more about it. Do not risk update to brick your system. Update only if you have reason,not for fun.
The hardware version of my unit is 033 and I assume Expatica's as well since they both came with FW 0451.
Android Auto works only via bluetooth on my new phone.
Originally I thought it doesn't work at all, but you have to unplug the phone and restart the radio, then bluetooth AA connects and you can plug the phone back in for charging.
Edit: you also have to make sure the bluetooth name is the same as listed on the radio's AA tab. Don't know why, but somehow it works that way.
Since I've found a workaround, I will stay on 0469 since I don't want to mess with it.
Edited by xayep
Spoiler
 i confirm l update 1780 to 1800 with succes without any problem  and i m Very happy android auto work with my samsung s23+ after 2 years i thank all membre to group20241011_175522.thumb.jpg.3ba7528feb109e0522718602d86769ec.jpg20241011_175540.thumb.jpg.a55ac2730985e57ebee99967fb895505.jpg
for to prepar usb it's necessary
1-format in exFAt
2- créat an folder and it must be named the name for update for exemple MEN3_EU_SK370_P3355L_1800
3- it must be extract the files to folder
you can update safely to 0741 and then 0742
I have 1310 installed in my car. After reading on this forum 1800 update is the latest one.
Do anyone have the changelog for updates between 1310 to 1800?
Does the update introduce some new features or only fixes?
Is their a risk to brick something if i download the updates on this forum? The guys where i bought the car wanted 100 USD to install the update.
Can I buy any USB C to USB convertor to plug in my USB memory?
Can I install 1800 update direcly or i need to jump step by step?
Edited by Sweden24
All answers are in this topic. Please take time and read it. Peoples uses their time to wrote about it in the past so you could use this info now. No need to write it over and over again.
Hello,
I have Kamiq 2021 with
MEN3_EU_SK370_P0393L
What I have found is that latest for that is
MEN3_EU_SK370_P1185L ?
Please link for files if possible.
6 minutes ago, Miuzun said:
Hello,
Please read up the whole thread and find yourself download links as they've been posted multiple times.
HINT: There are at least three (3) newer versions than you have found out.
Hi guys, new here👋🏼
Looks like a useful place with some pro people :)
Didn't find any pinned message with guidelines for an upgrade, sorry if I missed anything..
Anyway - got skoda scala 2020 with 0463 software version.
Android auto isn't working with my new phone (Xiaomi Poco F6), while it does work great with many other older phone models, including other Xiaomi phone with same android version (14).
How can I upgrade the car software version?
What are the steps?
Thanks in advance
Cannot edit my previous message..
I'm reading through the whole thread now to find my info.. thanks
This is the update, latest upate is MEN3_EU_SK370_P3355L_1800
On 28/01/2024 at 18:37, DamirKo said:
In my case, I have just got a new Android phone, and AA auto simply doesn't work with it with MIB3 unit on SW 0463.  Worked with previous since 2020...
Due to some posts here and some other sites claiming updating to SW 1800 finaly fixed it for them, I was hoping to get this solved.
Otherwise, without AA this "Bolero" unit is no use to me, could have got a Swing or a Bluetooth adapter ;)
Hey @DamirKo
Did it go well for you? 463-->469-->741+742? (latest version allowed when coming from <469 afaiu)
I also got sw version 463 with 040 hardware version, trying to make sure I'm good to go.
Also, how much time does it approximatly take for an upgrade?
Did you leave the engine running or connected the battery to a charger?
Any other special instructions?
Thanks in advance
I have successfully updated my version to 742, but the AA connectivity issue still persists.
Does anyone know whether I can safely continue upgrade to following versions?
I started with sw463 and hw40.
Attaching the current state of the system
Hello can anyone send me a new version of software for bolero ?
I have Skoda scala 2021 with software 1310. Can I update from 1310 to 1790 and after that to 1800? I'm confused reading all the problems during update.
I'm trying to find it on the Google but without success.
Ok . I found it.
Update passed correctly.
Before update my problem was to not have menu closing and windows.
I was thinking it's maybe software problem but still nothing.
I checked also obdeleven and it seems to be good and menu doesn't appear.
@KomisPL so you upgraded to 1800 successfully ?
Yes. But still don't have a menu closing and opening 😞
Hi guys
I have a 2020 Scala with Bolero updated to MEN3_EU_SK370_P2135P 0742.
Android Auto was working with my old phone but it's not working with my new Xiaomi 14 on Android 14.
I'm afraid to be stuck at 0742, can I upgrade to a newer version ? Do I have a chance to make it works or will I have to buy a wireless AA module ?
Hello, does TPMS work for everyone on firmware 1800? I have a menu displayed as in the screenshot. When the pressure drops, it is not displayed in the menu
On 11/06/2023 at 12:13, varooom said:
You can in stages update to 1798 eventually, these updates are sent by Private Message if you want it.
Can you please send me the stages so i can update
i have the same SW train as @CiccioSkoda51
Good day to all,
I had software MEN3_EU_SK370_P2345L_1790. I managed to update to MEN3_EU_SK370_P3225L_1798, but when I tried to update to MEN3_EU_SK370_P3355L_1800, I got the error "35 No release available."
I would like to know what I should do to get the update to 1800
Why you update from 1790 to 1798 ?
I updated my scala from 1310 directly to 1800 with no problems.
Do you use correct file to update ?
Have you reset device after update (long press power button or menu button, I don't remember).
Here you have 1800 fw that I have updated.
https://easyupload.io/wc1io4
Edited by radoszczak
I updated it to 1798 because I got this error (I tried at the beginning straight to 1800), so I tried upgrading steeply to see if it resolved the problem.
I got the two files (1798 & 1800) from the link found on this topic (https://disk.yandex.ru/d/1V1uBTc8ssc3zA). I'm unsure if the "1800" file was downloaded with an error or when I unzipped them, but I tried with a file from (https://mibsolution.one/) this morning, and it worked.
Thanks anyway for taking the time to reply and for giving the link.
For information, this upgrade (to the 1800 version) fixes my AA connection with my One Plus 11 5G EU.
Thank you to all who were involved in this topic 👌👍
