VCDS options on Superb III.FL
Vor 3 Stunden sagte Seba800:
Gibt es eine andere Möglichkeit, Start-Stopp auszuschalten?
via Modul
  • Replies 264
  • Views 101.6k
  • Why would you want them off? Auto lights are notorious for people driving around in poor visibility and no rear side lights.   Personally I always code them to be on.
  • https://github.com/olli991/mib-std2-pq-zr-toolbox Here you can find out whether it is suitable for MIB or not
  • Paikesejanku
    Paikesejanku
    Yes, you have to change two values: 09 – Central Electrics - Adaptions Search 'scheinwerferreinigung' (headlight cleaning) Select 'SRA Verzoegerungszeit' and set value to '2000' (don't wor
Hi, thanks for the codes, I have managed to get lane assist working on my FL 20 STYLE combi with vcds.
I wanted to know if there is any way to have the driving profiles menu on my columbus, normal eco sport... I also see that some colleagues has the green browser cursor in nav and mine is red, as well as the driver assistant screen that appears the superb on a road and the assistants on the sides. I don't know why my FL from March 2020 doesn't have these options despite having a digital cockpit and columbus,
thank you very much.
Hi, which post did you follow to do this for the FL please.
Driving Mode is a SWaP feature that requires a FeC code in the 5F.
So it's not an easy job as coding.
Edited by komoornik
Hello, some weeks ago I replaced auto battery for new one.
Today I found my trunk won't open / close with the key. It worked before I replaced a auto battery. Any help please? Have VCDS, maybe it's required to code it again? Do you have a guide for this please?
Superb 3 2020 FL
Anyone manager to resolve the problem with:
23.05.09 NOK
* Disable Ignition On Warnin
Apparently does not seem possible on FL, or nobody has found a way yet.
On 07/09/2023 at 08:05, MartiniB said:
23.03.31          OK
*** Minimize Lane Assist's Ping-Pong Effect
A5 Driver Assistance
            Long coding
                        00020898116E4020089F10001030008001418000000000000000000000000000
            ->         00020898116E4020889F18001030008001438000000000000000000000000000
or         -> Point_of_intervention:
                        early    ->         early_setting_over_menu
            -> HC_Warn_Intensity:
                        No_Setting      ->         Setting_over_Menu
            -> Lane_assist_off_text:
                        disabled           -> enabled
I did this but found it annoying that when you had it turned off it threw a warning on the dash and on vehicle status.
So I removed the last one - “Lane assist off text” which I think is actually the second of the three bold figures in the long coding quote. Much better!
Hi, any way to auto unlock/lock car when I'm coming to car or going away from car please? It's feature of skoda octavia IV I think.
Have S3 2020 FL.
Edited by brsk
If you have Kessi, you can enable the full version using VCDS or Equiv
First time hearing about it. Could you tell something more? I've VCDS
More info please?
I don't have access to VCDS at the moment. However I did this modification with Carista. When I walk away from the car, with the key it automatically locks. It only unlocks when I grab the handle on my return.
Hi
This coding
  • works OK for 36 Driver seat
  • I do not have 06 Passenger seat
  • in cars settings I cannot activate driver_seat_0x10_msg_bus as a Comfort data bus
I've restarted unit after coding and there was new option in menu: seats (or sth like that) and there were two options: driver seat and passenger seat, both cannot be changed.
Is there any other option to activate menu for driver seat only?
Cheers
On 07/09/2023 at 09:05, MartiniB said:
** Easy Entry driver
36 Driver Seat
        Long coding
                        0010000000000500018280808080000000008181000000D440
            ->         0010000200000500018280808080000000008181000000D440
            ->         001000020000050001C280808080000000008181000000D440
            ->         001000020000150001C280808080000000008181000000D440
or         --> Easy_Entry_front:
                        not active        ->         active
            --> Easy_Entry_front_over_MMI:
            --> EasyEntry_Enable_Passenger_over_DriverMMI:
23.03.20          OK
** Easy Entry passenger
06 Passenger Seat
            Long coding
                        0010000000000500018280808080000000008181000000D400
            ->         0010000200001500018280808080000000008181000000D400
            ->         001000020000150001C280808080000000008181000000D400
or         -> Easy_Entry_front:
            -> Easy_entry_front_over_MMI:
23.03.01          OK
* Easy Entry options in Car Settings
5F Multimedia
            Security Access 20103
            Adaptations
            Vehicle menu operation
                        menu_display_seat_configuration
                                    Not activated  ->         activated
                        menu_display_seat_configuration_over_threshold_high
            Vehicle function list BAP
                        driver_seat_0x10
                                    Not activated  ->         Comfort data bus
23.03.20          O
Anyony knows how do this? :O
Sorry, no idea...
On 14.7.2025 at 15:24, brsk said:
Weiß jemand, wie das geht? :O
What do you hope to achieve with this? You set this in the lighting channels in control unit 09.
I want to achieve this effect.
It's the "Urban Joke" Pace Car effect.
I would strongly advise against using these apps
Agreed - I was simply pointing out an option.
I personally would never use any of the OBDEleven Apps.
I only make changes via Long Coding or Adaptations.
Thank you so much. Do you have any verified guide?
Edited by brsk
Sorry no, I don't have any further info apart from the above that it is available on OBDEleven as an App.
I have no interest in such a lighting effect.
U'll have to Google search Urban Joke effect, maybe u'll find instructions on how to enable it.
5 hours ago, soniqua said:
Hi!
I've managed to code (amongst other things) the menu entry for Adaptive Lane Guidance on my 2021 Superb. I don't have Travel Assist, nor do I have the button on the steering wheel.
I can activate Adaptive Lane Guidance, and choose the intervention level, but it doesn't seem to have any effect - I'm still bouncing between lane lines. I'm guessing (but hoping not!) that I need to have Travel Assist, which then lets the car sit properly in the middle of the lane.
I'd appreciate any confirmation from those who have done this, or any other pointers as to how I can get this to work without swapping my steering wheel out.
Any advice or other users enabling Adaptive Lane Assist without Travel Assist?
