  2. Mine has that, plus the extra position for pulling the mirrors in. I wonder if the switch could perhaps only partly connect,so 12V appears but not the current capacity?
  3. Hi all For about a week or so the temperatures have dropped significantly (from 10-15 degrees C during the day down to negative values during the night). When I start my car for the first time in the day either in the morning or later I switch on the ignition, wait a few secs and then press the brake and start the engine and at that moment I get a warning such as ACC unavailable, manoeuvre braking unavailable and they disappear in 1-2 seconds and everything is working. The car is starting normally, the battery is an original VW 75Ah battery fitted brand new 2 years ago by an authorized dealer. My question is could this be a momentary drop in voltage and should I be worried since I have some trips lined up in the next couple of weeks?
  4. specturow started following Battery issue or?
  5. Try doing a heater flap reset... press and hold the A/C and face vent buttons at the same time for a few seconds and the lights on both with start flashing in turn and the flaps will go through a learning procedure to reset their baseline positions.
  6. Today
  7. Does your mirror adjustment switch have a position marked with a little heated mirror symbol? Easy to leave that switch on L or R if you've been adjusting them.
  8. Bet
    Bet posted a topic in Skoda Fabia Mk4 (2021 > )
    I've fluid runs down my glove box and dripping onto the mat, any ideas where it could be coming from? 2023 tsi
  9. Bet started following Bet
  10. Bet joined the community
  11. SW17 joined the community
  12. Fixed servicing I’m assuming going by the mileage data
  13. Hi folks, anyone got any ideas on this? I think my heated door mirrors were working last winter, assume so but can't honestly remember. Pretty sure I would have noticed if not. With the recent cold snap I've noticed they're not heating up, same both sides. I've had both doors apart to test, and in each case I'm getting 12V on the black/red output pin of the door module and earth continuity on the black/blue pin. Wires are continuous, and mirror elements read a useful number of Ohms, somewhere around 5-6 iirc which fits the 27W power consumption. Connecting the mirrors direct to a 12V battery they both work nicely. All the other mirror functions - motors, lights - work as normal. I found a Reset button in VCDS for the door electronics modules, so did that.. no change. Sadly, gone are the days of fuse>wire>switch>mirror, and now there's at least two computers involved(!) which is way above my pay grade, but it seems unlikely for both door modules to have packed in simultaneously (or at least within a very short space of time). For the time being I've wired the mirrors out to a 12V supply with fuse and switch, which works fine but means extra wires running around, but does this ring any bells with anyone?
  14. What would you caption the part you have photographed?
  15. Ahhh. I did wonder if it would be compatible if it was from a different car. But as long as the numbers match I suppose it should be fine. Cheers Still hoping to find an axle with haldex fitted for easier/cheaper fitting but thank you for the very useful info 👍
  16. x128 joined the community
  17. Is that a record of each and every service item carried out? Not just showing annual serviced carried out?. Was it on fixed oil and filter changed or flexible / variable serviced?
  18. Unfortunately I suspect you'll find pretty much every manufacturer has been taken over by the beancounters and the main priority of the manufacturer is now shareholder value, not product or even profit.
  19. Last winter, I noticed that the windscreen was not demisting so quickly as it used to. This car always impressed me by how quickly it would clear the windscreen, but now I had to have the heater on quite a high temperature and high flow (and turn off the flow to the footwell and to the face) to do any good at all. The inside of the car would also get quite humid, with condensation on the windows. Some time later I found that the heater worked much better if I put it onto the recirculation mode. I could hear the airflow increase, and the heat would also build up quicker, clearing the windscreen. However, the system always switches it off recirculation a few seconds after I switch it on for the first time in a journey. I have to press the button again to get it to come on again, but this time it stays on. It's as thought he car thinks I should not be using recirculation. There are no dashboard warnings though. Put it back to normal and the airflow sound would reduce again. I've just had a look at the pollen filter behind the glove box, in case that was blocking the flow. To me, it looks OK. No debris in there, but a few patches where the white cloth looks a bit darker. I gave it a vacuum just in case. I can try getting a new filter, but I think that's not the cause. I now think there's a blockage at the air intake, but have no idea where to look next. Is there another filter to check, elsewhere in the air system?
  20. I am also charging it every month and it works okay.
  21. Knuddi joined the community
  22. Joni5629 started following Coolant overflows
  23. I have problem with my 2015 octavia 2.0tdi 184hv. I can drive the car normally for how long ever I want, but when I floor it a couple of times, the coolant reservior is empty. So the car shoots the coolant from the overflow of the reservior when floored couple of times. Already done: changed reservior cap, changed main waterpump, changed thermostat, checked for combustion gasses in reservior with co2 test and the liquid didnt change color so no co2 there, changed the intercooler, bleeded the system. Tested the electric waterpumps and both seems to work. Car blows hot air on both sides. Ehen floored couple of times, dagbostics says the coolant temperature climbs to 105celsius but it comes down to 92celsius in like five to ten seconds. I did pressure test while it was cool and there was no leakage. Should I just change the HG or could it be radiator or gearbox thermostat or something?
  24. well, normally "5 years later..." means no reply, but in this case i can report that this fix of resoldering the dry solder joints was 100% effective - the car was passed from my wife to my son and he still uses it daily, so after five cold winters and approx 50k further miles the fault has not re-occurred at all 👍
  25. the same here about the battery. my octy vrs 12/2023 , 47100 km --- battery is very weak. i have ctek cs the best on market. charged 20x but now its not possible. EfB is ****ty battery . u need to buy AGM yuassa or exide is the best . maybe it is the problem with ECU. i dont know that . service dealers in croatia are not willing to check anything . they just say u have power . its fine. but its not when i have to charge every month
  26. It has a comprehensive service record . Just seems to be lacking a record of the first box service.
  27. If it works OK then that is all that matters. Were Spark Plugs changed each 40,000 miles or so? Brake fluid changed a couple of times? Check the Air Filter and pollen filter and see if clean / changed or needing done.
  28. That’s true. On the paint or a sticker would have been worse! In this instance paint won’t matter too much as I’ll be changing the mirror cap. If anyone wants a grey LHS one let me know!
  29. It had a service at 89000 , however we don’t know if it’s had an earlier one.complete records show services but not specifically the dsg
  30. mickemelec joined the community
  31. Knowing more than one fella that deals with parts, this is to avoid writing on the "plastic paint" which is far more easy to damage, especially if you use the wrong product. Unfortunately the pen is the cheapest option ... I got a breaker that moved to a barcode sticker type, but the adhesive sucks and it takes a long time to remove ... same problem ultimately ☠️
  32. First thing is to work out whether it's raw diesel or exhaust, because they point to different places. A raw diesel smell is usually a weep somewhere in the fuel system: around the fuel filter housing, especially if it's been serviced recently, the injector return lines, or a fuel line joint. With the engine cold, look for a damp patch or fresh staining. Exhaust fumes on a high-mileage TDI are often a joint blowing between the turbo and the DPF, or at a clamp further back. Sooty marks around a joint are the giveaway. A leak at the front can get pulled into the heater intake under the scuttle, so it can smell worse with the fan on. If it turns out to be exhaust, drive with a window open until it's found and don't sit in it idling. Exhaust fumes getting into the passenger compartment is a major fault on an MOT as well, so it's worth getting it properly sorted.
  33. Better yesterday but then decided to do a regen so think its coincindence with cold weather an car not getting used so much. When it was at high idle there were no fans on when stopping car after a short run until yesterday. Have put battery on charge overnight and will take out for a decent run today to see if everything goes back to normal. Battery is about a year oldish so should be good. If it does it again will get battery checked. Alasdair
  34. Fabia Mk4 spare wheels were also discussed in this 2024 BRISKODA forum topic https://www.briskoda.net/forums/topic/522682-spare-wheel-and-central-tool-holder/ The Skoda optional spare-wheel for a Fabia Mk4 is steel and 15"-diameter fitted with a 185/65 R15 88H tyre. (In my own Fabia's case that tyre is NEXEN-branded.) So there's no doubt that this size of wheel/tyre combination will comfortably fit in a Fabia Mk4's spare-wheel well. When a spare-wheel is ordered as an option for a new Fabia Mk4, it comes with a wheel-changing tool-kit housed in a polystyrene insert as shown in the image in my last posting. It is the top surface of the polystyrene insert (NOT the wheel itself or the tyre on it) that provides support to the underside of the boot's floor. Consequently, if you just put the spare-wheel into the spare-wheel well without the polystyrene insert being present, the boot floor will need to be suitably packed up (or reinforced) to prevent it sagging if a heavy load is placed on it. This was mentioned in this more recent 'space saver' forum topic
  35. I passed by by chance, looking at very impressive set of upgrades and modifications ... very very good, compliments! With some electronic stuff, is not only learning the ropes, but make it also work without any 'ripple effect' ... more than skill, it becomes art 😉 I actually been procrastinating getting in touch with you to see some stuff on my car, but I can't open new fronts of work while I got so many still unresolved ... nevertheless will happen soon! I also got some health stuff I can't get rid of and need to accommodate my life to live with, but such are the cards sometimes we are dealt with, and we just have to play with what we got ☹️ Thanks to our ancestors who created automobiles, we got something to escape to, often with satisfaction! (and some bitter frustrating times as well! 😁) Talk soon ...
