  2. never drive engine with any noise. stop at moment. try to find missing part. easiest thru spark plug hole. if valves are not damaged, it will go. if cilinder wall is damaged, its old school cast iron cilinder wall liners which can be machined. no new engine needed.
  3. miro_zs@ joined the community
  4. This can happen if you replace the boot lights with cheapo Chinese LED’s. I know, I’ve done it but I live with it on the basis that I can actually see inside the boot in the dark!
  5. Today
  6. Thanks. Will have a look at this tomorrow. If I can get through there I’ll return the conduit!
  7. hmmm, that i don't know sorry. i do remember reading (back then) that it's "best practice" to stick with the pairs, i.e. 15 with 16; and 17 with 18. however, who knows, perhaps they might work if u interchanged them, i.e. paired 18 with 15.
  8. depends on your driving habits, if you live in colder areas with lot of short starts and stops, short trips, even 0w20 can be ok. i switched to 0w30, 30000 kms is no-go, 15000kms is maximum, i change oil once a year on about 8000-10000 kms, i dont drive much, but my drives are 90% short trips, about 10 kms rush hours. filters are cheap, i take Mann oil filter, Febi, Bluechem or Valeo air and pollen filter for about 8€ each, changing once a year. also aware that on your gearbox service probably has never been done.
  9. At this time, I won’t… My current Kodiaq Mk1 makes an excellent job! 😁 I was only asking myself how long I would need for a 10-80% charge along a holiday trip. 28mn isn’t that long on its own, but if most of the car have such values, it means long queueing to have the battery charged. My holiday trips are all over 500km with 90% motorway. The shortest is around 450km but requires a roof box which shortens the range and makes a battery charge mandatory anyway. Additionally, I may have to tow a horse van 2 or 3 times a year over 300km. I guess battery charge will be necessary in this case too…
  10. Got it, thanks! By the way, do you know if both headlight units should be the same generation? (015-016 or 017-018, in part numbers). Found a good deal for a 015 left unit and a 018 right unit and Im curious if they would work ok.
  11. on the headlight itself, where the wiring harness plugs into, is different between version A and version B. from memory, there r more pins on version B headlights.
  12. @Binx1310 - when i did my front grille DRL light bar, i ran a cable from the BCM, through the firewall and into the engine bay. its located above the passenger (for RHD cars) footwell. there is NO need to remove the glovebox or the fusebox there. u will need to remove the battery though, which u've done, to pull the wire through. no need to remove the airbox either. close up of the grommet ..... grommet located just above where the felt ends...... blue line showing the path
  13. Ok, but what did you mean by "different pin arrangements"?
  14. no, the wiring harness on the car side does not need to change. in other words - it caters for both version A and version B headlight plugs. i didn't have to change or modify anything with the wiring harness when i switched from A to B.
  15. Well good that the problem is solved! I failed to suggest the haldex I thought you had read pages in here and Bap's excellent procedure for checking the pump screen which indeed is a serious f-up as an entire concept, not to mention service/maintenance procedures do not include it ... All good I guess, pity at the tremendous amount of parts and work that was done .... now make sure you rev up a little that thing, life is not under, but upwards of the turbo spin! 😁😅
  16. East or West, your choice. The are very outdated anyway...
  17. All I can say is, it's worked for me! Car seems smoother somehow, and fuel economy has improved. Could be the new DV valve, could be the deletes, could be replacing hoses when installing the catch can. I've been driving around for about ten days since I did all this- on day 3, I got engine light P0411 (secondary air intake incorrect flow). Erased it expecting it to come back but it hasn't yet. One thing I did, because it was playing on my mind, was to buy an upgraded crankcase breather pipe adaptor. The existing 90 degree pipe was pretty new, but the tension of the new hose was pulling it down a bit, cos my 'U' clip didn't clamp very well. (I actually tried making one but it was difficult and no better). So I got the 'upgraded' adaptor and tweaked the hose in this area, cos I wanted to get things as airtight as I could I also made a simple retainer to keep that damn 'U' clip in place (probably overkill, the new fitting seems well seated and doesn't move) This is just one snag I encountered, and dealt with, that others may find useful
  18. I got all the work done after about 2 weeks; I've put my progress in the ' OCC install' thread Bowders wrote (Octavia 'guides' section). No point in repeating it here. After doing it, the whole system makes a lot more sense now. Car is much smoother and fuel economy has improved; I probably do still have air leaks in places but haven't yet done a simple vacuum test (I'm just happy I got it all done without assistance, apart from the guides and help on this forum). Oil leak is still there but much reduced; it's the turbo pipes I think.I'll leave that to a professional, I don't really know where to start and might make things worse
  19. Thanks. When we get some dryer weather I'll pour water onto the windscreen and see the result. There isn't any water in the gulley at the base of the windscreen, but I agree that this MUST be rainwater as there isn't a source of "ordinary" clear water elsewhere.
  20. PS, maybe more important, change to vw 504 00 / 507 00 5w 30 FS III, or even vw502 00 so 5w 40 FS since you are going with fixed service oil and filter. Remember the DQ400e DSG service oil and filter is @40,000 miles. As are spark plugs, and check the air filter every service not at 60,000 miles as per Skoda schedule.
  21. Yesterday
  22. 1.4 tsi PHEV,s came from the factory showing fixed servicing intervals. But then the cars might of got plugged in and charged lots and the engine not run much. Many were never charged and the engine always running. So why many would go with Flexible / variable oil and filter changed. 18,000 / 20,000, 24 months.
  23. @Bap33 This being on 199kW chargers. Are you going to be using Ultra Rapid chargers like that? Instavolts are only 160kW max.(92 pence a kWh) Tesla are 250kW max. there are Osprey 300 kW, There are 350 kW chargers. The Xpeng G9 can charge at 300-525 kW. So 800 volt chargers.
  24. @pab567 which maps should I install? Now it asks for DVD in Nav. Will v17 East be okay? HW: H26 3ТO 035 681 А
  25. Unfortunately a few miles, even at low revs is many thousands of piston cycles in the cylinder - and yours is an 'interference' engine, meaning there is almost no clearance between piston crown and cylinder head!
  26. Update - I spoke to @Breezy_Pete over WhatsApp the other day, and he'd mentioned the PCV system being at fault. After procuring and fitting a known good one from a parts engine my mate has kicking about - I've still got the same issue. I get the fault codes as before, but also it feels almost like it's hunting at idle, and on light throttle it genuinely feels almost like it's misfiring. Throttle body has been swapped for the parts one too. There's no air leaks from the pipework now either as it's all new. Everything I seem to think would be wrong with it, just isn't or has been replaced already.
  27. A reputable dealer would have erased route history for privacy reasons I suspect. The second question depends on if it was specced from new by the buyer. That can be answered by getting the VIN decoded. Maybe the seller can answer that for you. Mine did.
  28. Gowna started following Route Data
  29. Just picked up my nearly new Octavia a couple of days ago and trying to find out what it can and can't do via the infotainment head unit. So a couple of quick ones of I may. is there a way of pulling historical route data to prove where the vehicle was at a particular time and date? I'd there a setting which picks up fixed speed cameras? Many thanks
  30. And one more question.. I want to sell the car. If the new owner makes a new account and Skoda ID, will he benefit again of the 3 month free Care Connect and Infotainment online service? Or is a VIN related one time free service? And secondly, is there anyone in the same position (after update via USB to 1989 the eManagement not working) that succeeded disabling Reduced charging current from the Skoda App? Thank you in advance!
